Graylog stop logging himself
Greetings,
I get a lot of messages from 127.0.0.1
How can I disable graylog from sending to himself?
Kindest regards.
Did you use the OVA Image? Then you can configure it with Graylog-ctl - in a limited way:
http://docs.graylog.org/en/2.4/pages/configuration/graylog_ctl.html
If not, just stop ingesting the log messages from localhost.
how can I stop ingesting messages from localhost?
I’m really new to the whole graylog system.
Did you use the OVA or did you have installed Graylog in some other way?
I inherited an already installed system, but I think it was installed from the ova.
