GRAYLOG_SERVER_JAVA_OPTS Argument Issue
Hi Everyone,
I need a small help and clarification
I was trying to deploy Graylog as Docker, and I wanted to set the -Xms5g -Xmx5g
This is the initial value that I password for GRAYLOG_SERVER_JAVA_OPTS was
value: “-Djavax.net.ssl.trustStore=/trust/opensearch-truststore.p12 -Djavax.net.ssl.trustStorePassword=changeit”
and the pod is working but then when i set it to
value: “-Xms5g -Xmx5g -Djavax.net.ssl.trustStore=/trust/opensearch-truststore.p12 -Djavax.net.ssl.trustStorePassword=changeit”
The pod fails. What is the correct way to set the value? I am not able get anything from documents
OS Information: Ubuntu and Kubernetes
Package Version: Graylog 7.0.2+7a367fe
Service logs, configurations, and environment variables: GRAYLOG_SERVER_JAVA_OPTS
Hi @rohanrajnv,
Can you post your logs here? Without logs I can’t tell what’s happening with your instance.
Thanks!
