Graylog Server issue
Hi All
I am using Graylog 3.1.4 on Centos 7 with elasticsearch
Facing logs searching isssue
Error :
Nothing found
graylog search query error.
Unable to perform search query
Hello @raghuveer520
If this is a new install of Graylog I would recommend rebuilding with the newest version, instructions can be found here.
To get more information on this error you should check the log file found at the default location at /var/log/graylog-server/server.log. Similarly on your Elastic node, there will be a log file you can check, most likely at /var/log/elasticsearch.
