./graylog-project.linux bootstrap github://Graylog2/graylog-project.git failure
I used the graylog-project-cli to pull the github project from github on my Linux box on Digital Ocean. But I get a permission denied (public key) problem.
  • OS Information:
    Rocky Linux 8.7
  • Package Version:
    git clone git@github.com:Graylog2/graylog-project.git graylog-project
    Git stderr: Cloning into ‘graylog-project’…
    git@github.com: Permission denied (publickey).
    fatal: Could not read from remote repository.
Please make sure you have the correct access rights
and the repository exists.
Error executing: git clone git@github.com:Graylog2/graylog-project.git graylog-project (exit status 128)
I am not sure of my next move at the moment. I was under the impression that github offered public access with no need for a key?
Can you point to where I can download the public keys so I can bootstrap the plugin code?
Hello @ofentselogger
By chance did you execute the following also?
$ mkdir -p $HOME/bin
$ cp graylog-project.linux $HOME/bin/graylog-project
$ chmod +x $HOME/bin/graylog-project
Then
graylog-project bootstrap github://Graylog2/graylog-project.git
I’m also assuming you see this?
EDIT:
I found this here
Thank you @gsmith. My apologies for my non-thorough approach. Your suggestion has helped me. I just need to complete the git bootstrap part which I will do a bit later in the day. Then I can start developing my new plugin.
Awesome :+1: glad to help.
Thank you again @gsmith. I was successful with the Linux edition. I have even done a second bootstrap just to consolidate my knowledge. But my Internet connection is very slow :slight_smile: Better with the first one in the cloud. The CLI tool makes live easier.
If I have time I will get the Windows one working for future development work. Thank you once again.
Awesome !!!, And No problem really glad i could help.
If you could mark this as resolve that would be great for future searches :+1:
