Graylog pipeline problem
Dear all,
I designed the pipeline to calculate the download speed basic on size and time. The function is fine. However, I want to the speed_kb_sec can change to integer(No decimal point). Can you have any solution about it?
My pipeline is listed in the below:
 has_field("spendtime")
    let time = to_double($message.spendtime);
    let size = to_double($message.bytes);
    let bandwidth = size / time ;
    let bandwidth_kb = to_double(bandwidth / 1024.0);
    set_field("speed_bytes_sec", bandwidth);
    set_field("speed_kb_sec", bandwidth_kb);
For example,
speed_kb_sec:1064.092460042956 (current)
I want to change speed_kb_sec:1064
Many Thanks
You can use the to_long() function for that purpose.
Hi Joechen, Thanks your reply. you means
has_field(“spendtime”)
let bandwidth_kb = to_long (bandwidth / 1024.0);
set_field(“speed_bytes_sec”, bandwidth);
set_field(“speed_kb_sec”, bandwidth_kb);
Sorry for my newbie question.
Yes, that could work.
Thanks Bro! You are many helpful for me.
Joechen, Sorry about that.
If i change to_double to to_long, look like the above reply. The bandwidth_kb will be 0 for all case.
let bandwidth_kb = to_long(bandwidth / 1024.0);
speed_bytes_sec 67548.1865284974
speed_kb_sec 0
It looks like this is a bug in the to_long() function. This will be fixed in Graylog 2.4.0:
https://github.com/Graylog2/graylog-plugin-pipeline-processor/pull/219
Dear joechen
Thanks your reply. If I want to edit the pipeline to avoid to_double/to_long problem. How can I do that?
As an ugly workaround, you could convert bandwidth / 1024.0 to a string (using to_string()), then split on the decimal point using split() or regex(), and then convert the result to a long integer (using to_long()).
Not nice, but it should work for now.
OK. I try to use the ugly workaround first. Hope that it can solve the problem.
deleted. deleted.Thanks!
