Pipeline help convert field numeric field
I am working on getting a field converted from string to numeric. it always comes in as a number but it is set as a string
i created a rule to convert it, but it doesn’t make any changes to the targeted logs. any help creating this pipeline would be very appreciated!
Pipeline rule
rule “IIS time-taken convert”
when has_field(“time-taken”)
//Converts the time-taken to a numeric field
set_field(“time-taken”, to_long($message.time-taken));
targeted field
Your field was previously mapped as string in elastic, so no convert can help. You need to either rotate index, or create custom index mapping for field.
https://docs.graylog.org/en/3.2/pages/configuration/elasticsearch.html#custom-index-mappings
Ah okay, i thought you could do that with Pipelines!
i found another way, in Nxlog i could make that field send as a integer so when graloy gets it, its Long
Thanks again! you post helped me go the right direction!
