Pipeline Rule with unexpected result
Hello everybody,
I created the following pipeline-rule to convert Bytes from a syslog to Megabytes.
rule "Bytes to Megabytes"
has_field("Bytes")
let mbyte = to_long($message.Bytes);
set_field("MBytes", mbyte / 1048576);
Messages are processed by the pipeline and the new field “MBytes“ is inserted.
But when the Bytes value is smaller than 1048576 I always get 0 as result.
Is “long” the wrong data type?
Oh, I see. Long is an integer and therefore the fractional part is discarded. Right?
But when I convert the value to_double I get red cross in the rule source box when trying to devide.
What now?
What happens when you convert 1048576 to double?
rule “Bytes to Megabytes”
has_field(“Bytes”)
let mbyte = to_double($message.Bytes);
set_field(“MBytes”, mbyte / to_double(value:“1048576”));
Great. That’s working.
Thank you Christoph!
Another lesson learned.
