Graylog outputs not working
I’m trying to output the messages hitting one of my streams to a Slack channel, this worked fine on the previous version of Graylog but not in 2.2.1.
These are the error messages I’m seeing:
2017-11-07 15:49:59.835 graylog-server
2017-11-07 15:49:59,788 ERROR: org.graylog2.outputs.OutputRegistry - Output 5a01d621c492254251859204 has crossed threshold of 5 faults in 30 seconds. Disabling for 30 seconds.
2017-11-07 15:49:59.787 graylog-server
2017-11-07 15:49:59,784 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #5
2017-11-07 15:49:59.581 graylog-server
2017-11-07 15:49:59,579 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #4
2017-11-07 15:49:59.072 graylog-server
2017-11-07 15:49:59,045 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #3
2017-11-07 15:49:58.946 graylog-server
2017-11-07 15:49:58,942 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #2
2017-11-07 15:49:58.107 graylog-server
2017-11-07 15:49:58,103 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #1
Could anybody advise please?
Please post the complete logs of your Graylog node(s).
Also make sure that you’re using a version of the Slack plugin which is compatible with your version of Graylog.
Here you go, this is everything captured over a minute (slimmed down slightly to fit within the char limit) when the error happens, the output id is 5a01d621c492254251859204
Slack version is the latest and is compatible with Graylog 2.2.1
2017-11-08_10:58:34.84648 2017-11-08 10:58:34,836 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #1
2017-11-08_10:58:34.85964 com.google.common.util.concurrent.UncheckedExecutionException: com.google.inject.ProvisionException: Unable to provision, see the following errors:
2017-11-08_10:58:34.86021
2017-11-08_10:58:34.86132 1) Error injecting constructor, org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:34.86318   at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:35)
2017-11-08_10:58:34.86418   while locating org.graylog2.plugins.slack.output.SlackMessageOutput annotated with @com.google.inject.internal.UniqueAnnotations$Internal(value=1)
2017-11-08_10:58:34.86637
2017-11-08_10:58:34.86762 1 error
2017-11-08_10:58:34.86927 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2217) ~[graylog.jar:?]
2017-11-08_10:58:34.87005 	at com.google.common.cache.LocalCache.get(LocalCache.java:4154) ~[graylog.jar:?]
2017-11-08_10:58:34.87233 	at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:5060) ~[graylog.jar:?]
2017-11-08_10:58:34.87337 	at org.graylog2.outputs.OutputRegistry.getOutputForIdAndStream(OutputRegistry.java:102) [graylog.jar:?]
2017-11-08_10:58:34.87463 	at org.graylog2.outputs.OutputRouter.getMessageOutputsForStream(OutputRouter.java:44) [graylog.jar:?]
2017-11-08_10:58:34.87550 	at org.graylog2.outputs.OutputRouter.getStreamOutputsForMessage(OutputRouter.java:64) [graylog.jar:?]
2017-11-08_10:58:34.87979 	at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:135) [graylog.jar:?]
2017-11-08_10:58:34.88338 	at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:54) [graylog.jar:?]
2017-11-08_10:58:34.88476 	at com.lmax.disruptor.WorkProcessor.run(WorkProcessor.java:143) [graylog.jar:?]
2017-11-08_10:58:34.88533 	at com.codahale.metrics.InstrumentedThreadFactory$InstrumentedRunnable.run(InstrumentedThreadFactory.java:66) [graylog.jar:?]
2017-11-08_10:58:34.88592 	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_101]
2017-11-08_10:58:34.88661 Caused by: com.google.inject.ProvisionException: Unable to provision, see the following errors:
2017-11-08_10:58:34.88728
2017-11-08_10:58:34.89000 1) Error injecting constructor, org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:34.89155   at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:35)
2017-11-08_10:58:34.89264   while locating org.graylog2.plugins.slack.output.SlackMessageOutput annotated with @com.google.inject.internal.UniqueAnnotations$Internal(value=1)
2017-11-08_10:58:34.89384
2017-11-08_10:58:34.89470 1 error
2017-11-08_10:58:34.89592 	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028) ~[graylog.jar:?]
2017-11-08_10:58:34.89695 	at com.google.inject.assistedinject.FactoryProvider2.invoke(FactoryProvider2.java:776) ~[graylog.jar:?]
2017-11-08_10:58:34.89773 	at com.sun.proxy.$Proxy111.create(Unknown Source) ~[?:?]
2017-11-08_10:58:34.89955 	at org.graylog2.outputs.MessageOutputFactory.fromStreamOutput(MessageOutputFactory.java:51) ~[graylog.jar:?]
2017-11-08_10:58:34.90371 	at org.graylog2.outputs.OutputRegistry.launchOutput(OutputRegistry.java:143) ~[graylog.jar:?]
2017-11-08_10:58:34.90426 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:137) ~[graylog.jar:?]
2017-11-08_10:58:34.90600 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:133) ~[graylog.jar:?]
2017-11-08_10:58:34.90664 	at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:5065) ~[graylog.jar:?]
2017-11-08_10:58:34.90768 	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3716) ~[graylog.jar:?]
2017-11-08_10:58:34.90901 	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2424) ~[graylog.jar:?]
2017-11-08_10:58:34.90995 	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2298) ~[graylog.jar:?]
2017-11-08_10:58:34.91172 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2211) ~[graylog.jar:?]
2017-11-08_10:58:34.91332 	... 10 more
2017-11-08_10:58:34.91388 Caused by: org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:34.91463 	at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:43) ~[?:?]
2017-11-08_10:58:34.91746 	at org.graylog2.plugins.slack.output.SlackMessageOutput$$FastClassByGuice$$87de1066.newInstance(<generated>) ~[?:?]
2017-11-08_10:58:34.91941 	at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89) ~[graylog.jar:?]
2017-11-08_10:58:34.92008 	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111) ~[graylog.jar:?]
2017-11-08_10:58:34.92135 	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90) ~[graylog.jar:?]
2017-11-08_10:58:34.92265 	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268) ~[graylog.jar:?]
2017-11-08_10:58:34.92377 	at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019) ~[graylog.jar:?]
2017-11-08_10:58:34.92588 	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085) ~[graylog.jar:?]
2017-11-08_10:58:34.92704 	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015) ~[graylog.jar:?]
2017-11-08_10:58:34.92851 	at com.google.inject.assistedinject.FactoryProvider2.invoke(FactoryProvider2.java:776) ~[graylog.jar:?]
2017-11-08_10:58:34.92937 	at com.sun.proxy.$Proxy111.create(Unknown Source) ~[?:?]
2017-11-08_10:58:34.93395 	at org.graylog2.outputs.MessageOutputFactory.fromStreamOutput(MessageOutputFactory.java:51) ~[graylog.jar:?]
2017-11-08_10:58:34.93497 	at org.graylog2.outputs.OutputRegistry.launchOutput(OutputRegistry.java:143) ~[graylog.jar:?]
2017-11-08_10:58:34.93823 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:137) ~[graylog.jar:?]
2017-11-08_10:58:34.93940 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:133) ~[graylog.jar:?]
2017-11-08_10:58:34.94147 	at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:5065) ~[graylog.jar:?]
2017-11-08_10:58:34.94241 	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3716) ~[graylog.jar:?]
2017-11-08_10:58:34.94386 	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2424) ~[graylog.jar:?]
2017-11-08_10:58:34.95110 	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2298) ~[graylog.jar:?]
2017-11-08_10:58:34.95296 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2211) ~[graylog.jar:?]
2017-11-08_10:58:34.95371 	... 10 more
2017-11-08_10:58:36.63141 2017-11-08 10:58:36,628 ERROR: org.graylog2.outputs.OutputRegistry - Unable to fetch output 5a01d621c492254251859204, fault #2
2017-11-08_10:58:36.63253 com.google.common.util.concurrent.UncheckedExecutionException: com.google.inject.ProvisionException: Unable to provision, see the following errors:
2017-11-08_10:58:36.63430
2017-11-08_10:58:36.63551 1) Error injecting constructor, org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:36.63720   at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:35)
2017-11-08_10:58:36.63823   while locating org.graylog2.plugins.slack.output.SlackMessageOutput annotated with @com.google.inject.internal.UniqueAnnotations$Internal(value=1)
2017-11-08_10:58:36.63931
2017-11-08_10:58:36.64068 1 error
2017-11-08_10:58:36.64297 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2217) ~[graylog.jar:?]
2017-11-08_10:58:36.64300 	at com.google.common.cache.LocalCache.get(LocalCache.java:4154) ~[graylog.jar:?]
2017-11-08_10:58:36.64749 	at com.google.common.cache.LocalCache$LocalManualCache.get(LocalCache.java:5060) ~[graylog.jar:?]
2017-11-08_10:58:36.64752 	at org.graylog2.outputs.OutputRegistry.getOutputForIdAndStream(OutputRegistry.java:102) [graylog.jar:?]
2017-11-08_10:58:36.64753 	at org.graylog2.outputs.OutputRouter.getMessageOutputsForStream(OutputRouter.java:44) [graylog.jar:?]
2017-11-08_10:58:36.64754 	at org.graylog2.outputs.OutputRouter.getStreamOutputsForMessage(OutputRouter.java:64) [graylog.jar:?]
2017-11-08_10:58:36.64754 	at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:135) [graylog.jar:?]
2017-11-08_10:58:36.64757 	at org.graylog2.buffers.processors.OutputBufferProcessor.onEvent(OutputBufferProcessor.java:54) [graylog.jar:?]
2017-11-08_10:58:36.64817 	at com.lmax.disruptor.WorkProcessor.run(WorkProcessor.java:143) [graylog.jar:?]
2017-11-08_10:58:36.64870 	at com.codahale.metrics.InstrumentedThreadFactory$InstrumentedRunnable.run(InstrumentedThreadFactory.java:66) [graylog.jar:?]
2017-11-08_10:58:36.64933 	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_101]
2017-11-08_10:58:36.65005 Caused by: com.google.inject.ProvisionException: Unable to provision, see the following errors:
2017-11-08_10:58:36.65065
2017-11-08_10:58:36.65933 1) Error injecting constructor, org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:36.66059   at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:35)
2017-11-08_10:58:36.66175   while locating org.graylog2.plugins.slack.output.SlackMessageOutput annotated with @com.google.inject.internal.UniqueAnnotations$Internal(value=1)
2017-11-08_10:58:36.66257
2017-11-08_10:58:36.66332 1 error
2017-11-08_10:58:36.66530 	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1028) ~[graylog.jar:?]
2017-11-08_10:58:36.66801 	at com.google.inject.assistedinject.FactoryProvider2.invoke(FactoryProvider2.java:776) ~[graylog.jar:?]
2017-11-08_10:58:36.66863 	at com.sun.proxy.$Proxy111.create(Unknown Source) ~[?:?]
2017-11-08_10:58:36.66962 	at org.graylog2.outputs.MessageOutputFactory.fromStreamOutput(MessageOutputFactory.java:51) ~[graylog.jar:?]
2017-11-08_10:58:36.67168 	at org.graylog2.outputs.OutputRegistry.launchOutput(OutputRegistry.java:143) ~[graylog.jar:?]
2017-11-08_10:58:36.67258 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:137) ~[graylog.jar:?]
2017-11-08_10:58:36.67428 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:133) ~[graylog.jar:?]
2017-11-08_10:58:36.67510 	at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:5065) ~[graylog.jar:?]
2017-11-08_10:58:36.67679 	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3716) ~[graylog.jar:?]
2017-11-08_10:58:36.67761 	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2424) ~[graylog.jar:?]
2017-11-08_10:58:36.67912 	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2298) ~[graylog.jar:?]
2017-11-08_10:58:36.67994 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2211) ~[graylog.jar:?]
2017-11-08_10:58:36.69426 	... 10 more
2017-11-08_10:58:36.69531 Caused by: org.graylog2.plugin.outputs.MessageOutputConfigurationException: Missing configuration: Couldn't parse icon_url correctly.
2017-11-08_10:58:36.69685 	at org.graylog2.plugins.slack.output.SlackMessageOutput.<init>(SlackMessageOutput.java:43) ~[?:?]
2017-11-08_10:58:36.69837 	at org.graylog2.plugins.slack.output.SlackMessageOutput$$FastClassByGuice$$87de1066.newInstance(<generated>) ~[?:?]
2017-11-08_10:58:36.70214 	at com.google.inject.internal.DefaultConstructionProxyFactory$FastClassProxy.newInstance(DefaultConstructionProxyFactory.java:89) ~[graylog.jar:?]
2017-11-08_10:58:36.70466 	at com.google.inject.internal.ConstructorInjector.provision(ConstructorInjector.java:111) ~[graylog.jar:?]
2017-11-08_10:58:36.70504 	at com.google.inject.internal.ConstructorInjector.construct(ConstructorInjector.java:90) ~[graylog.jar:?]
2017-11-08_10:58:36.70609 	at com.google.inject.internal.ConstructorBindingImpl$Factory.get(ConstructorBindingImpl.java:268) ~[graylog.jar:?]
2017-11-08_10:58:36.70926 	at com.google.inject.internal.InjectorImpl$2$1.call(InjectorImpl.java:1019) ~[graylog.jar:?]
2017-11-08_10:58:36.71161 	at com.google.inject.internal.InjectorImpl.callInContext(InjectorImpl.java:1085) ~[graylog.jar:?]
2017-11-08_10:58:36.71355 	at com.google.inject.internal.InjectorImpl$2.get(InjectorImpl.java:1015) ~[graylog.jar:?]
2017-11-08_10:58:36.71441 	at com.google.inject.assistedinject.FactoryProvider2.invoke(FactoryProvider2.java:776) ~[graylog.jar:?]
2017-11-08_10:58:36.71840 	at com.sun.proxy.$Proxy111.create(Unknown Source) ~[?:?]
2017-11-08_10:58:36.71951 	at org.graylog2.outputs.MessageOutputFactory.fromStreamOutput(MessageOutputFactory.java:51) ~[graylog.jar:?]
2017-11-08_10:58:36.72560 	at org.graylog2.outputs.OutputRegistry.launchOutput(OutputRegistry.java:143) ~[graylog.jar:?]
2017-11-08_10:58:36.72664 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:137) ~[graylog.jar:?]
2017-11-08_10:58:36.72838 	at org.graylog2.outputs.OutputRegistry$2.call(OutputRegistry.java:133) ~[graylog.jar:?]
2017-11-08_10:58:36.72952 	at com.google.common.cache.LocalCache$LocalManualCache$1.load(LocalCache.java:5065) ~[graylog.jar:?]
2017-11-08_10:58:36.73383 	at com.google.common.cache.LocalCache$LoadingValueReference.loadFuture(LocalCache.java:3716) ~[graylog.jar:?]
2017-11-08_10:58:36.73473 	at com.google.common.cache.LocalCache$Segment.loadSync(LocalCache.java:2424) ~[graylog.jar:?]
2017-11-08_10:58:36.73568 	at com.google.common.cache.LocalCache$Segment.lockedGetOrLoad(LocalCache.java:2298) ~[graylog.jar:?]
2017-11-08_10:58:36.74167 	at com.google.common.cache.LocalCache$Segment.get(LocalCache.java:2211) ~[graylog.jar:?]
2017-11-08_10:58:36.74444 	... 10 more
2017-11-08_10:58:36.74676 2017-11-08 10:58:36,667 ERROR: org.graylog2.plugin.inputs.transports.NettyTransport - Error in Input [Beats/599fe30fc4922503acfeeda8] (channel [id: 0x7865c5b1, /x.x.x.33:62448 => /x.x.x.163:5044])
2017-11-08_10:58:36.74742 java.lang.Exception: Unknown beats protocol version: 80
2017-11-08_10:58:36.75052 	at org.graylog.plugins.beats.BeatsFrameDecoder.checkVersion(BeatsFrameDecoder.java:162) ~[?:?]
2017-11-08_10:58:36.75145 	at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:92) ~[?:?]
2017-11-08_10:58:36.75407 	at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:49) ~[?:?]
2017-11-08_10:58:36.75513 	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:500) ~[graylog.jar:?]
2017-11-08_10:58:36.75676 	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.messageReceived(ReplayingDecoder.java:435) ~[graylog.jar:?]
2017-11-08_10:58:36.75785 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) ~[graylog.jar:?]
2017-11-08_10:58:36.75925 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.76027 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.76218 	at org.jboss.netty.channel.SimpleChannelHandler.messageReceived(SimpleChannelHandler.java:142) [graylog.jar:?]
2017-11-08_10:58:36.76322 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88) [graylog.jar:?]
2017-11-08_10:58:36.76570 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.76703 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.76854 	at org.jboss.netty.handler.traffic.AbstractTrafficShapingHandler.messageReceived(AbstractTrafficShapingHandler.java:718) [graylog.jar:?]
2017-11-08_10:58:36.77091 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88) [graylog.jar:?]
2017-11-08_10:58:36.77167 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.77286 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.77437 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.messageReceived(SimpleChannelUpstreamHandler.java:124) [graylog.jar:?]
2017-11-08_10:58:36.77547 	at org.graylog2.plugin.inputs.util.PacketInformationDumper.messageReceived(PacketInformationDumper.java:51) [graylog.jar:?]
2017-11-08_10:58:36.77802 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [graylog.jar:?]
2017-11-08_10:58:36.77971 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.78045 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.78156 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.messageReceived(SimpleChannelUpstreamHandler.java:124) [graylog.jar:?]
2017-11-08_10:58:36.78428 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:70) [graylog.jar:?]
2017-11-08_10:58:36.78663 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.78726 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
2017-11-08_10:58:36.78833 	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:268) [graylog.jar:?]
2017-11-08_10:58:36.79119 	at org.jboss.netty.channel.Channels.fireMessageReceived(Channels.java:255) [graylog.jar:?]
2017-11-08_10:58:36.79291 	at org.jboss.netty.channel.socket.nio.NioWorker.read(NioWorker.java:88) [graylog.jar:?]
2017-11-08_10:58:36.79538 	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.process(AbstractNioWorker.java:108) [graylog.jar:?]
2017-11-08_10:58:36.79788 	at org.jboss.netty.channel.socket.nio.AbstractNioSelector.run(AbstractNioSelector.java:337) [graylog.jar:?]
2017-11-08_10:58:36.79883 	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.run(AbstractNioWorker.java:89) [graylog.jar:?]
2017-11-08_10:58:36.80101 	at org.jboss.netty.channel.socket.nio.NioWorker.run(NioWorker.java:178) [graylog.jar:?]
2017-11-08_10:58:36.80172 	at org.jboss.netty.util.ThreadRenamingRunnable.run(ThreadRenamingRunnable.java:108) [graylog.jar:?]
2017-11-08_10:58:36.80325 	at org.jboss.netty.util.internal.DeadLockProofWorker$1.run(DeadLockProofWorker.java:42) [graylog.jar:?]
2017-11-08_10:58:36.80529 	at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:176) [graylog.jar:?]
2017-11-08_10:58:36.80769 	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_101]
2017-11-08_10:58:36.80840 	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_101]
2017-11-08_10:58:36.80958 	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_101]
2017-11-08_10:58:36.81164 2017-11-08 10:58:36,686 ERROR: org.graylog2.plugin.inputs.transports.NettyTransport - Error in Input [Beats/599fe30fc4922503acfeeda8] (channel [id: 0x7865c5b1, /x.x.x.33:62448 :> /x.x.x.163:5044])
2017-11-08_10:58:36.81341 java.lang.Exception: Unknown beats protocol version: 85
2017-11-08_10:58:36.81516 	at org.graylog.plugins.beats.BeatsFrameDecoder.checkVersion(BeatsFrameDecoder.java:162) ~[?:?]
2017-11-08_10:58:36.81661 	at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:92) ~[?:?]
2017-11-08_10:58:36.81909 	at org.graylog.plugins.beats.BeatsFrameDecoder.decode(BeatsFrameDecoder.java:49) ~[?:?]
2017-11-08_10:58:36.82090 	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.callDecode(ReplayingDecoder.java:500) ~[graylog.jar:?]
2017-11-08_10:58:36.84591 	at org.jboss.netty.handler.codec.replay.ReplayingDecoder.cleanup(ReplayingDecoder.java:554) ~[graylog.jar:?]
2017-11-08_10:58:36.84742 	at org.jboss.netty.handler.codec.frame.FrameDecoder.channelDisconnected(FrameDecoder.java:365) ~[graylog.jar:?]
2017-11-08_10:58:36.85203 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102) ~[graylog.jar:?]
2017-11-08_10:58:36.85321 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.85666 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.85826 	at org.jboss.netty.channel.SimpleChannelHandler.channelDisconnected(SimpleChannelHandler.java:199) [graylog.jar:?]
2017-11-08_10:58:36.85975 	at org.graylog2.plugin.inputs.util.ConnectionCounter.channelDisconnected(ConnectionCounter.java:49) [graylog.jar:?]
2017-11-08_10:58:36.86097 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:120) [graylog.jar:?]
2017-11-08_10:58:36.86325 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.86428 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.86679 	at org.jboss.netty.channel.SimpleChannelHandler.channelDisconnected(SimpleChannelHandler.java:199) [graylog.jar:?]
2017-11-08_10:58:36.86792 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:120) [graylog.jar:?]
2017-11-08_10:58:36.87046 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.87316 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.87389 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.channelDisconnected(SimpleChannelUpstreamHandler.java:208) [graylog.jar:?]
2017-11-08_10:58:36.87508 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102) [graylog.jar:?]
2017-11-08_10:58:36.87739 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.87857 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.88052 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.channelDisconnected(SimpleChannelUpstreamHandler.java:208) [graylog.jar:?]
2017-11-08_10:58:36.88163 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:102) [graylog.jar:?]
2017-11-08_10:58:36.88582 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.88918 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
2017-11-08_10:58:36.88979 	at org.jboss.netty.channel.Channels.fireChannelDisconnected(Channels.java:396) [graylog.jar:?]
2017-11-08_10:58:36.89090 	at org.jboss.netty.channel.socket.nio.AbstractNioWorker.close(AbstractNioWorker.java:360) [graylog.jar:?]
2017-11-08_10:58:36.89565 	at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.handleAcceptedSocket(NioServerSocketPipelineSink.java:81) [graylog.jar:?]
2017-11-08_10:58:36.89955 	at org.jboss.netty.channel.socket.nio.NioServerSocketPipelineSink.eventSunk(NioServerSocketPipelineSink.java:36) [graylog.jar:?]
2017-11-08_10:58:36.90046 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:779) [graylog.jar:?]
2017-11-08_10:58:36.90185 	at org.jboss.netty.channel.SimpleChannelHandler.closeRequested(SimpleChannelHandler.java:334) [graylog.jar:?]
2017-11-08_10:58:36.90413 	at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:260) [graylog.jar:?]
2017-11-08_10:58:36.90525 	at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2017-11-08_10:58:36.90884 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
2017-11-08_10:58:36.91054 	at org.jboss.netty.channel.SimpleChannelHandler.closeRequested(SimpleChannelHandler.java:334) [graylog.jar:?]
2017-11-08_10:58:36.91290 	at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:260) [graylog.jar:?]
2017-11-08_10:58:36.91401 	at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2017-11-08_10:58:36.91630 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendDownstream(DefaultChannelPipeline.java:784) [graylog.jar:?]
2017-11-08_10:58:36.91758 	at org.jboss.netty.channel.SimpleChannelHandler.closeRequested(SimpleChannelHandler.java:334) [graylog.jar:?]
2017-11-08_10:58:36.91944 	at org.jboss.netty.channel.SimpleChannelHandler.handleDownstream(SimpleChannelHandler.java:260) [graylog.jar:?]
2017-11-08_10:58:36.92107 	at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:591) [graylog.jar:?]
2017-11-08_10:58:36.92262 	at org.jboss.netty.channel.DefaultChannelPipeline.sendDownstream(DefaultChannelPipeline.java:582) [graylog.jar:?]
2017-11-08_10:58:36.92413 	at org.jboss.netty.channel.Channels.close(Channels.java:812) [graylog.jar:?]
2017-11-08_10:58:36.92625 	at org.jboss.netty.channel.AbstractChannel.close(AbstractChannel.java:205) [graylog.jar:?]
2017-11-08_10:58:36.92763 	at org.graylog2.plugin.inputs.transports.NettyTransport$RawMessageHandler.exceptionCaught(NettyTransport.java:353) [graylog.jar:?]
2017-11-08_10:58:36.92918 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:130) [graylog.jar:?]
2017-11-08_10:58:36.93017 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.94802 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.95171 	at org.jboss.netty.handler.codec.frame.FrameDecoder.exceptionCaught(FrameDecoder.java:377) [graylog.jar:?]
2017-11-08_10:58:36.95847 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:112) [graylog.jar:?]
2017-11-08_10:58:36.95943 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.96596 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.96902 	at org.jboss.netty.channel.SimpleChannelHandler.exceptionCaught(SimpleChannelHandler.java:156) [graylog.jar:?]
2017-11-08_10:58:36.97139 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:130) [graylog.jar:?]
2017-11-08_10:58:36.97228 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.97353 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.97520 	at org.jboss.netty.channel.SimpleChannelHandler.exceptionCaught(SimpleChannelHandler.java:156) [graylog.jar:?]
2017-11-08_10:58:36.97593 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:130) [graylog.jar:?]
2017-11-08_10:58:36.97733 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.97824 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.98033 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.exceptionCaught(SimpleChannelUpstreamHandler.java:153) [graylog.jar:?]
2017-11-08_10:58:36.98194 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:112) [graylog.jar:?]
2017-11-08_10:58:36.98253 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.98335 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.98511 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.exceptionCaught(SimpleChannelUpstreamHandler.java:153) [graylog.jar:?]
2017-11-08_10:58:36.98615 	at org.graylog2.plugin.inputs.transports.NettyTransport$2$1.exceptionCaught(NettyTransport.java:210) [graylog.jar:?]
2017-11-08_10:58:36.98765 	at org.jboss.netty.channel.SimpleChannelUpstreamHandler.handleUpstream(SimpleChannelUpstreamHandler.java:112) [graylog.jar:?]
2017-11-08_10:58:36.98856 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:564) [graylog.jar:?]
2017-11-08_10:58:36.99117 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:559) [graylog.jar:?]
2017-11-08_10:58:36.99203 	at org.jboss.netty.channel.Channels.fireExceptionCaught(Channels.java:525) [graylog.jar:?]
2017-11-08_10:58:36.99370 	at org.jboss.netty.channel.AbstractChannelSink.exceptionCaught(AbstractChannelSink.java:48) [graylog.jar:?]
2017-11-08_10:58:36.99444 	at org.jboss.netty.channel.DefaultChannelPipeline.notifyHandlerException(DefaultChannelPipeline.java:658) [graylog.jar:?]
2017-11-08_10:58:36.99626 	at org.jboss.netty.channel.DefaultChannelPipeline.sendUpstream(DefaultChannelPipeline.java:566) [graylog.jar:?]
2017-11-08_10:58:36.99700 	at org.jboss.netty.channel.DefaultChannelPipeline$DefaultChannelHandlerContext.sendUpstream(DefaultChannelPipeline.java:791) [graylog.jar:?]
2017-11-08_10:58:36.99882 	at org.jboss.netty.channel.SimpleChannelHandler.messageReceived(SimpleChannelHandler.java:142) [graylog.jar:?]
2017-11-08_10:58:36.99972 	at org.jboss.netty.channel.SimpleChannelHandler.handleUpstream(SimpleChannelHandler.java:88) [graylog.jar:?]
I’ve spotted the problem now!
I put “:rotating_light:” in the Icon URL field and not the Emoji one!
It’s working now
Thanks!
