I have set an output on graylog to send it to another syslog.
But i didn’t receive any log on my syslog server.
Is there any way to check the server log if Graylog has send out to my Syslog?
You can use standard output and link to stream what messages you like to forward to another syslog.
Good day @ramindia.
Thanks for your reply.
I have try setting it to output too.
But if I using a Standard Output and link it to my stream. Where will the log be saved?
The messages sent and stored to that stream will also be sent out the connected output. If the output isnt aending you will see a backup in the output buffer (and eventually storing messages will stop), you may also see errors in server.log
