I have all the streams setup and log messages are showing (local input is just one on UDP 1514)
I created an output and assigned it to each Stream but the receiver Syslog is not able to see any logs.
Please suggest what else to check.
Hello
Yes, the UDP and TCP ports 514 are open and I can do nc to syslog.
I only got a reply from them that they are not able to receive logs. I did check in our firewall (graylog is behind local firewall) and there are no messages being sent but when I test via nc, it works…
so there is no network issue.
the plugin is downloaded from marketplace “graylog-output-syslog-4.2.6.jar”
I also selected the output in each stream. tried changing port to UDP but still no activity on local firewall…
