Graylog nx log help
Hi.
Trying to collect logs and analyze with graylog.
using the system
CentOS Linux 7 (Core)
Graylog
MongoDB
Elastic Search
Java
С помощью winlogbeat # Needed for Graylog
fields_under_root: true
output.logstash:
hosts: [“my ip adress:50443”]
path:
tags:
  • windows
    winlogbeat:
    event_logs:
    • name: Application
    • name: System
    • name: Security
Filebeat # Needed for Graylog
output.logstash:
path:
data: C:\Program Files\Graylog\sidecar\cache\filebeat\data
tags:
  • windows
    filebeat.inputs:
  • type: log
    enabled: true
    paths:
    • C:\logs\log.log
NXlog define ROOT C:\Program Files (x86)\nxlog
Moduledir %ROOT%\modules
CacheDir %ROOT%\data
Pidfile %ROOT%\data\nxlog.pid
SpoolDir %ROOT%\data
LogFile %ROOT%\data\nxlog.log
Module xm_json
Module xm_syslog
Module im_msvistalog
Module om_tcp
Host 10.1.56.43
Port 12201
Exec to_syslog_ietf();
<Route 1>
Path eventlog => out
Now there is another problem.
I see the logs are coming in but are not displayed in the list.
The following settings have been applied.
link screen
Sign in to your account
Going to the system \ sidecars showmessages tab, I don’t see any new logs.
I cleaned the folder where the logs file:///var/lib/graylog-server/journal/ did not help, the logs are not displayed. I’ve read the manual and can’t find how to solve the problem…
Hello && Welcome @Alex25
You will have to wait till Elasticsearch gets done, noticed this.
Depending on your resource this may take some time.
Also when Output Buffer are over 90% chance ar this may be a configuration error in Graylog config file or you don’t have enough resource to handle that many logs.
I would serious look into you Local log file to see if there are any errors or warning.
examples
tail -f /var/log/elasticsearch/graylog.log
curl -XGET http://192.168.1.100:9200/_cluster/health?pretty=true
I don’t read/speak Russian.
Ok
system characteristics
4CPU
16Gb Memory
50 Gb hdd
100 second HDD
What parameters need to be increased to use more resources for processing?
Ok,
well I would stop ingestion logs till the Output buffer clears, Deleting Journal is not good.
Graylog Configuration file /etc/graylog/server.conf
These are the ones you need to know about if they look like this…
processbuffer_processors = 5
outputbuffer_processors = 3
inputbuffer_processors = 2
You should have 10 CPU core on this server, Each one creates a thread, FYI …
Like I said it could be a configuration error OR even a bad GROK or REGEX .
Thanks, I’m checking now.
Grok, I’m not at a meeting, I think everything is there by default …
Some advice , when you see the Output buffer fill like that , chances are something is with Elasticsearch.
I tried to expand the collection of logs in the previous settings, when setting up elasticsearch, I configured the minimum indexes accordingly.
rotate_strategy = number
elasticsearch_shards = 1
elasticsearch_replicas = 0
I have corrected the index settings in the screenshot, because a large number was set by default.
What do you mean wrong with him?
Oh boy,
I would keep those as they were, If you need to correct you index I would do that through the Web UI.
Did you see what I posted above???
Not sure, must be a lack of comminution.
checked . such data is worth it.
checked . such data is worth it. and corrected in the indexes.
I meant that if I see something wrong with the elastic, it takes a long time to process, it’s not clear how to fix it and the reason. :slight_smile:
I stopped collecting logs. I correctly understood that it is necessary to wait for the processing of the logs that have accumulated in the queue …
Awesome, :+1:
Yeah I think the main issue is that your Output buffers are filled, when that go back down to 0% you should see something.
make sure elasticsearch is Good, you can insure this by this command.:point_down:
curl -XGET http://127.0.0.1:9200/_cluster/health?pretty=true
I have more questions.
how to increase buffer processing? :smiling_face:
:laughing:
Man, You want me to come over there and set that up for you. LOL
Go into you Graylog configuration file and look for those configuration I just showed you above. I’ll post it again, Should look like this, Be careful IF you don’t have the resources “CPU”, I would not increase those… I would add more CPU cores to the Graylog server instead.
Why didn’t you just say lol. :rofl: :joy:
Yes, I have these settings…
Thank you for your help.
I will give feedback on the result.
I checked.
Increased the CPU to 10.
I started to run the collection, I see that the collection of logs is in progress.
But in the menu sidercars show message I do not see the logs that are coming.
I only see in the metric that the counter is increasing.
Screenshots attached if it helps…
https://slata365-my.sharepoint.com/:w:/g/personal/a_chernyavskiy_slata_com/EdWyI9mY0EdMnaAltkwUaKcBPQYlp2LyGNPAN4ejR92AOw?e=bhaCgC
I see you using GELF TCP for nxlog input. What does your NXLOG configuration look like?
