Graylog Not connecting to mongodb
I am new to Graylog. I have installed Graylog as per the steps at Red Hat Installation. However, it seems like it is not working as expected with mongo db in Replica set. So, basically, what I am trying to achieve is redundancy. Such that if one server fails, we have a backup server.
Main: 172.29.164.165
Backup: 10.184.162.145
However, it seems like Graylog is not connecting with the mongodb server. When I start Graylog, I get the following continuous error message:
svdt1graylog ~]$ tail -f /var/log/graylog-server/server.log
2025-02-17T14:23:33.956+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46510
2025-02-17T14:23:35.956+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46511
2025-02-17T14:23:37.957+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46512
2025-02-17T14:23:39.957+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46513
2025-02-17T14:23:41.958+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46514
2025-02-17T14:23:43.958+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46515
2025-02-17T14:23:45.959+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46516
2025-02-17T14:23:47.959+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46517
2025-02-17T14:23:49.959+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46518
2025-02-17T14:23:51.960+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46519
2025-02-17T14:23:53.960+03:00 INFO [MongoDBPreflightCheck] MongoDB is not available. Retry #46520
Therefore, Graylog is not binding to port 9000.
Here is my setup:
server configurations
is_leader = true
password_secret = ***********************
root_username = admin
root_password_sha2 = ***************
root_timezone = Africa/Nairobi
http_bind_address = 172.29.164.16:9000
allow_highlighting = false
field_value_suggestion_mode = on
output_batch_size = 500
output_flush_interval = 1
ring_size = 65536
inputbuffer_ring_size = 65536
mongodb_uri = mongodb://172.29.164.165,10.184.162.145/graylog?replicaSet=graylogs_mongodb
integrations_scripts_dir = /usr/share/graylog-server/scripts
sudo systemctl status mongod
MongoDb configurations are okay and the primary and secondary sets are working well with
Despite everything being up the port is still not binding to Graylog therefore, the server is not listening to the port
sudo firewall-cmd --list-ports | grep 9000
8080/tcp 9000/tcp 9010/tcp 9200/tcp 27017/tcp
sudo semanage port -a -t http_port_t -p tcp 9000
Port tcp/9000 already defined, modifying instead
  • OS Information: Redhat 9.5
  • Package Version:Graylog 6
I have enabled the port with firewalld
Restarted my VM server
Reinstalled Graylog and Graylog data node
How can I get Graylog to connect with Replicaset Mongodb setup.
Can you connect to both mongodb servers from each server with mongosh (the mongo client) as in connect to both locsl and remote.
Yes, they can connect. I realized that the issue was with the credentials. when creating a replica set, you will have to create authentication credentials as described here https://go2docs.graylog.org/current/setting_up_graylog/multi-node_setup.html. I created those and included them on my mongodb_uri and it connected to Mongodb. Thank you very much for the help.
