Graylog node shows negative number of unprocessed messages
After journal was full, I cleared journal and from then it started showing a negative number of unprocessed messages. @jochen help plz
did you stopped Graylog, deleted all content from the journal folder and started Graylog again? @aditki
yes when my elastic search was down and there were a lot of unprocessed messages which i didnt want them to be processed. So, i cleared the journal. @jan
so you stopped graylog - delete the journal - and started graylog again?
I see this only if not all content of the journal is deleted - so you might have missed something.
@jan No the node is up when i deleted the journal. i deleted the journal and restarted graylog again. But i guess the elastic search cluster was down then.
