Graylog mongo cluster , cant connect to mongo invalid char
This is my graylog conf
/etc/graylog/server/server.conf
is_leader = true
password_secret = "secret"
root_password_sha2 = "secret"
http_bind_address = 172.16.231.196:9000
elasticsearch_hosts = http://172.16.231.30:9200,http://172.16.231.41:9200
allow_highlighting = true
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://graylog:qwerty12345@sras041.hello.se:27017,graylog:qwerty12345@sras042.hello.se:27017,graylog:qwerty12345@sras043.hello.se:27017/graylog2023?replicaSet=graylog
And this is my mongo conf.
/etc/mongod.conf
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
storage:
  dbPath: /var/lib/mongo
  journal:
    enabled: true
processManagement:
  timeZoneInfo: /usr/share/zoneinfo
net:
  port: 27017
  bindIp: 127.0.0.1, 172.16.231.196  # Enter 0.0.0.0,:: to bind to all IPv4 and IPv6 addresses or, alternatively, use the net.bindIpAll setting.
security:
  authorization: "enabled"
  keyFile: "/etc/mongodb-keyfile"
replication:
   replSetName: "graylog"
And this is what i did when i setup my mongo first time. Running mongosh
rs.initiate()
rs.add("$IP")
rs.add("$IP")
use admin
db.createUser(
    user: "graylog-admin",
    pwd: "abc123",  // replace with a strong password
    roles: [
      { role: "userAdminAnyDatabase", db: "admin" },
      { role: "clusterMonitor", db: "admin" }
db.createUser(
    user: "graylog",
    pwd: "qwerty12345",
    roles: [ { role: "readWrite", db: "graylog2023" } ]
And this is my error from the graylog.log.
I do not know why it complain that i use invalid char when i do not have it.
I can connect to mongo using my user cred.
mongosh mongodb://graylog:qwerty12345@sras041.hello.se:27017/graylog2023
Caused by: java.lang.IllegalArgumentException: The connection string contains invalid user information. If the username or password contains a colon (:) or an at-sign (@) then it must be urlencoded
        at com.mongodb.ConnectionString.<init>(ConnectionString.java:339) ~[graylog.jar:?]
        at com.mongodb.MongoClientURI.<init>(MongoClientURI.java:258) ~[graylog.jar:?]
        at org.graylog2.configuration.MongoDbConfiguration.getMongoClientURI(MongoDbConfiguration.java:53) ~[graylog.jar:?]
        at org.graylog2.configuration.MongoDbConfiguration.validate(MongoDbConfiguration.java:58) ~[graylog.jar:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke0(Native Method) ~[?:?]
        at jdk.internal.reflect.NativeMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at jdk.internal.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source) ~[?:?]
        at java.lang.reflect.Method.invoke(Unknown Source) ~[?:?]
        at com.github.joschi.jadconfig.ReflectionUtils.invokeMethodsWithAnnotation(ReflectionUtils.java:53) ~[graylog.jar:?]
        at com.github.joschi.jadconfig.JadConfig.invokeValidatorMethods(JadConfig.java:233) ~[graylog.jar:?]
        ... 5 more
Red hat 9.2 Plow
graylog graylog-server-5.1.2-1.x86_64
mongodb-org-6.0.6-1.el9.x86_6
Running 3 graylog servers, every graylog server has mongodb.
Can you verify you are URL encoding the : and @ characters?
In the server.conf info you posted, it looks like your mongo connection string is mongodb://graylog:qwerty12345@sras041.hello.se:27017,graylog:qwerty12345@sras042.hello.se:27017,graylog:qwerty12345@sras043.hello.se:27017/graylog2023?replicaSet=graylog
However, the startup error says:
The connection string contains invalid user information. If the username or password contains a colon (:slight_smile: or an at-sign (@) then it must be urlencoded
%3A is urlencoded :
%40 is urlencoded @
You are wrong, the @ and : should be there because it is a delimiter, well if I had them in my username and password I would have to escape them.
But what actually worked, which I find a little strange, is this line.
mongodb_uri = mongodb://USERNAME:PASSWORD@mongodb-node01:27017,mongodb-node02:27017,mongodb-node03:27017/graylog?replicaSet=rs01
I think graylog needs to bold that you only need to enter username and password once at the beginning.
Otherwise, it is natural to enter user and password for each node.
So instead of
mongodb://graylog:qwerty12345@sras041.hello.se:27017,graylog:qwerty12345@sras042.hello.se:27017,graylog:qwerty12345@sras043.hello.se:270plica2023?grayrelogy=gray
I had to use.
mongodb://graylog:qwerty12345@sras041.hello.se:27017,sras042.hello.se:27017,sras043.hello.se:27017/graylog2023?replicaSet=graylog
