Can't connect to MongoDB
MongoDB 4.0.11-1: 192.168.3.22
Graylog 3.0.2-1 : 192.168.3.10
ElasticSearch 6.8.2 : 192.168.3.15
On graylog3 I have this log:
2019-08-06T09:58:40.347+02:00 INFO [cluster] No server chosen by WritableServerSelector from cluster description ClusterDescription{type=REPLICA_SET, connectionMode=SINGLE, serverDescriptions=[ServerDescription{address=192.168.3.22:27017, type=REPLICA_SET_GHOST, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 11]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1138744, setName='null', canonicalAddress=null, hosts=[], passives=[], arbiters=[], primary='null', tagSet=TagSet{[]}, electionId=null, setVersion=null, lastWriteDate=null, lastUpdateTimeNanos=330482575715619}]}. Waiting for 30000 ms before timing out
This message appear after I changer configuration on mongoDB
# mongod.conf
# for documentation of all options, see:
#   http://docs.mongodb.org/manual/reference/configuration-options/
# where to write logging data.
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
# Where and how to store data.
storage:
  dbPath: /data/mongodb
  journal:
    enabled: true
#  engine:
#  mmapv1:
#  wiredTiger:
# how the process runs
processManagement:
  fork: true  # fork and run in background
  pidFilePath: /var/run/mongodb/mongod.pid  # location of pidfile
# network interfaces
net:
  port: 27017
  bindIp: 127.0.0.1,192.168.3.21
#security:
#  authorization: enabled
#operationProfiling:
replication:
  replSetName: rs01
#sharding:
## Enterprise-Only Options
#auditLog:
But mongoDB works well:
[root@mongodb data]# netstat -tlnp
Connexions Internet actives (seulement serveurs)
Proto Recv-Q Send-Q Adresse locale          Adresse distante        Etat        PID/Program name
tcp        0      0 127.0.0.1:199           0.0.0.0:*               LISTEN      3301/snmpd
tcp        0      0 192.168.3.22:27017       0.0.0.0:*               LISTEN      3936/mongod
tcp        0      0 127.0.0.1:27017         0.0.0.0:*               LISTEN      3936/mongod
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      3302/sshd
This is the Graylog configuration:
is_master = true
password_secret =
root_password_sha2 =
http_bind_address = 192.168.3.10:9000
rotation_strategy = count
elasticsearch_hosts = http://192.168.3.15:9200
elasticsearch_max_docs_per_index = 50000000
elasticsearch_max_number_of_indices = 50
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
mongodb_uri = mongodb://192.168.3.22:27017/graylog
root_timezone = Europe/Paris
So, the problem is from mongodb, but I don’t know how to fix it.
Thank you.
Ok …
the probleme is form here :
replication:
  replSetName: rs01
I can’t have this line before completing my cluster.
It’s logical…
Thank you.
FWIW, MongoDB does not permit remote connections unless authentication is turned on and a user is created. Until you create that account, you’ll only be able to connect to the database via the primary node of the replica set and Graylog will not be able to use that MongoDB instance.
