upgraded graylog from 3.3. to 4.3. then upgraded the elastic cluster from 6.8 to 7.10.2.
leader node wont startup after elastic cluster upgrade, migrations keep failing
OS Information:
ubuntu 20.04 -
Package Version:
2x graylog nodes (one leader) - version: 4.3.7-1
3x elastic nodes also running mongodb -
Graylog Version: 4.3.7-1
Java Version: 11 on es nodes, 8 on graylog nodes
Elasticsearch Version: 7.10.2
MongoDB Version: 4.4
Operating System: 20.04
Browser version: chrome 105
2022-10-04T12:49:31.704-04:00 INFO [ServerBootstrap] Graylog server 4.3.7+05bccc7 starting up
2022-10-04T12:49:31.705-04:00 INFO [ServerBootstrap] JRE: Private Build 1.8.0_342 on Linux 5.15.0-1020-aws
2022-10-04T12:49:31.705-04:00 INFO [ServerBootstrap] Deployment: deb
2022-10-04T12:49:31.705-04:00 INFO [ServerBootstrap] OS: Ubuntu 20.04.5 LTS (focal)
2022-10-04T12:49:31.705-04:00 INFO [ServerBootstrap] Arch: amd64
2022-10-04T12:49:31.819-04:00 INFO [ServerBootstrap] Running 44 migrations...
2022-10-04T12:49:32.664-04:00 WARN [RestClient] request [PUT http://ca04vlgraylogdb02.agilitypr.internal:9200/gl-events*,gl-system-events*/_mapping?master_timeout=30s&ignore_unavailable=true&expand_wildcards=open%2Cclosed&allow_no_indices=true&ignore_throttled=false&timeout=30s] returned 1 warnings: [299 Elasticsearch-6.8.23-4f67856 "[types removal] The parameter include_type_name should be explicitly specified in put mapping requests to prepare for 7.0. In 7.0 include_type_name will default to 'false', and requests are expected to omit the type name in mapping definitions."]
2022-10-04T12:49:32.753-04:00 WARN [ServerBootstrap] Exception while running migrations
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: An error occurred:
at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:151) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:111) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:104) ~[?:?]
at org.graylog.storage.elasticsearch7.views.migrations.V20200730000000_AddGl2MessageIdFieldAliasForEventsES7.addGl2MessageIdFieldAlias(V20200730000000_AddGl2MessageIdFieldAliasForEventsES7.java:53) ~[?:?]
at org.graylog.plugins.views.migrations.V20200730000000_AddGl2MessageIdFieldAliasForEvents.upgrade(V20200730000000_AddGl2MessageIdFieldAliasForEvents.java:76) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.lambda$runMigrations$0(ServerBootstrap.java:264) ~[graylog.jar:?]
at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422) ~[graylog.jar:?]
at com.google.common.collect.RegularImmutableSortedSet.forEach(RegularImmutableSortedSet.java:88) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.runMigrations(ServerBootstrap.java:261) ~[graylog.jar:?]
at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:187) [graylog.jar:?]
at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:311) [graylog.jar:?]
at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
Caused by: org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchStatusException: Elasticsearch exception [type=action_request_validation_exception, reason=Validation Failed: 1: mapping type is missing;]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.rest.BytesRestResponse.errorFromXContent(BytesRestResponse.java:187) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.parseEntity(RestHighLevelClient.java:1892) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.parseResponseException(RestHighLevelClient.java:1869) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1626) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequest(RestHighLevelClient.java:1598) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.performRequestAndParseEntity(RestHighLevelClient.java:1565) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.IndicesClient.putMapping(IndicesClient.java:353) ~[?:?]
at org.graylog.storage.elasticsearch7.views.migrations.V20200730000000_AddGl2MessageIdFieldAliasForEventsES7.lambda$addGl2MessageIdFieldAlias$2(V20200730000000_AddGl2MessageIdFieldAliasForEventsES7.java:53) ~[?:?]
at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:109) ~[?:?]
... 10 more
Suppressed: org.graylog.shaded.elasticsearch7.org.elasticsearch.client.ResponseException: method [PUT], host [http://ca04vlgraylogdb02.agilitypr.internal:9200], URI [/gl-events*,gl-system-events*/_mapping?master_timeout=30s&ignore_unavailable=true&expand_wildcards=open%2Cclosed&allow_no_indices=true&ignore_throttled=false&timeout=30s], status line [HTTP/1.1 400 Bad Request]
Warnings: [[types removal] The parameter include_type_name should be explicitly specified in put mapping requests to prepare for 7.0. In 7.0 include_type_name will default to 'false', and requests are expected to omit the type name in mapping definitions.]
{"error":{"root_cause":[{"type":"action_request_validation_exception","reason":"Validation Failed: 1: mapping type is missing;"}],"type":"action_request_validation_exception","reason":"Validation Failed: 1: mapping type is missing;"},"status":400}
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.convertResponse(RestClient.java:302) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:272) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestHighLevelClient.internalPerformRequest(RestHighLevelClient.java:1613) ~[?:?]
checked logs, tried service restarts
any advice on help on how to fix this issue?
