Fresh Install Loop runing migrations
Fresh container LXD using with Ubuntu 22 and after follow the official docs, graylog startup script enter in loop and don’t finish the setup process.
2. Environment:
  • OS Information: Ubuntu 22 Jammy
  • Package Version: Graylog 4.3.7 / Mongodb 4.0.28 / Opensearch 1.3.4
Error from graylog Log:
2022-09-19T13:27:10.048-03:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-09-19T13:27:10.062-03:00 INFO  [ServerBootstrap] Graylog server 4.3.7+05bccc7 starting up
2022-09-19T13:27:10.067-03:00 INFO  [ServerBootstrap] JRE: Private Build 18.0.2-ea on Linux 5.15.0-47-generic
2022-09-19T13:27:10.070-03:00 INFO  [ServerBootstrap] Deployment: deb
2022-09-19T13:27:10.071-03:00 INFO  [ServerBootstrap] OS: Ubuntu 22.04.1 LTS (jammy)
2022-09-19T13:27:10.071-03:00 INFO  [ServerBootstrap] Arch: amd64
2022-09-19T13:27:11.101-03:00 INFO  [ServerBootstrap] Running 62 migrations...
2022-09-19T13:27:12.817-03:00 WARN  [ServerBootstrap] Exception while running migrations
org.graylog.shaded.elasticsearch7.org.elasticsearch.ElasticsearchException: Unable to retrieve cluster information
        at org.graylog.storage.elasticsearch7.ElasticsearchClient.exceptionFrom(ElasticsearchClient.java:151) ~[?:?]
        at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:111) ~[?:?]
        at org.graylog.storage.elasticsearch7.PlainJsonApi.perform(PlainJsonApi.java:38) ~[?:?]
        at org.graylog.storage.elasticsearch7.NodeAdapterES7.version(NodeAdapterES7.java:41) ~[?:?]
        at org.graylog2.indexer.cluster.Node.getVersion(Node.java:33) ~[graylog.jar:?]
        at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:87) ~[graylog.jar:?]
        at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.getReopenedIndices(V20170607164210_MigrateReopenedIndicesToAliases.java:137) ~[graylog.jar:?]
        at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.lambda$upgrade$0(V20170607164210_MigrateReopenedIndicesToAliases.java:81) ~[graylog.jar:?]
        at java.util.stream.ReferencePipeline$7$1.accept(ReferencePipeline.java:273) ~[?:?]
        at java.util.stream.ReferencePipeline$3$1.accept(ReferencePipeline.java:197) ~[?:?]
        at java.util.Spliterators$ArraySpliterator.forEachRemaining(Spliterators.java:992) ~[?:?]
        at java.util.stream.AbstractPipeline.copyInto(AbstractPipeline.java:509) ~[?:?]
        at java.util.stream.AbstractPipeline.wrapAndCopyInto(AbstractPipeline.java:499) ~[?:?]
        at java.util.stream.ForEachOps$ForEachOp.evaluateSequential(ForEachOps.java:150) ~[?:?]
        at java.util.stream.ForEachOps$ForEachOp$OfRef.evaluateSequential(ForEachOps.java:173) ~[?:?]
        at java.util.stream.AbstractPipeline.evaluate(AbstractPipeline.java:234) ~[?:?]
        at java.util.stream.ReferencePipeline.forEach(ReferencePipeline.java:596) ~[?:?]
        at org.graylog2.migrations.V20170607164210_MigrateReopenedIndicesToAliases.upgrade(V20170607164210_MigrateReopenedIndicesToAliases.java:83) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.lambda$runMigrations$0(ServerBootstrap.java:264) ~[graylog.jar:?]
        at com.google.common.collect.ImmutableList.forEach(ImmutableList.java:422) ~[graylog.jar:?]
        at com.google.common.collect.RegularImmutableSortedSet.forEach(RegularImmutableSortedSet.java:88) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.runMigrations(ServerBootstrap.java:261) ~[graylog.jar:?]
        at org.graylog2.bootstrap.ServerBootstrap.startCommand(ServerBootstrap.java:187) [graylog.jar:?]
        at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:311) [graylog.jar:?]
        at org.graylog2.bootstrap.Main.main(Main.java:45) [graylog.jar:?]
Caused by: java.net.ConnectException: Connection refused
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.extractAndWrapCause(RestClient.java:849) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:259) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.elasticsearch.client.RestClient.performRequest(RestClient.java:246) ~[?:?]
        at org.graylog.storage.elasticsearch7.PlainJsonApi.lambda$perform$0(PlainJsonApi.java:40) ~[?:?]
        at org.graylog.storage.elasticsearch7.ElasticsearchClient.execute(ElasticsearchClient.java:109) ~[?:?]
        ... 23 more
        at sun.nio.ch.Net.pollConnect(Native Method) ~[?:?]
        at sun.nio.ch.Net.pollConnectNow(Net.java:672) ~[?:?]
        at sun.nio.ch.SocketChannelImpl.finishConnect(SocketChannelImpl.java:946) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvent(DefaultConnectingIOReactor.java:174) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.DefaultConnectingIOReactor.processEvents(DefaultConnectingIOReactor.java:148) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.reactor.AbstractMultiworkerIOReactor.execute(AbstractMultiworkerIOReactor.java:351) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.conn.PoolingNHttpClientConnectionManager.execute(PoolingNHttpClientConnectionManager.java:221) ~[?:?]
        at org.graylog.shaded.elasticsearch7.org.apache.http.impl.nio.client.CloseableHttpAsyncClientBase$1.run(CloseableHttpAsyncClientBase.java:64) ~[?:?]
        at java.lang.Thread.run(Thread.java:833) ~[?:?]
2022-09-19T13:27:27.161-03:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {}
2022-09-19T13:27:29.119-03:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 4.3.7 [org.graylog.aws.AWSPlugin]
2022-09-19T13:27:29.122-03:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integrations 4.3.7 [org.graylog.enterprise.integrations.EnterpriseIntegrationsPlugin]
2022-09-19T13:27:29.124-03:00 INFO  [CmdLineTool] Loaded plugin: Integrations 4.3.7 [org.graylog.integrations.IntegrationsPlugin]
2022-09-19T13:27:29.126-03:00 INFO  [CmdLineTool] Loaded plugin: Collector 4.3.7 [org.graylog.plugins.collector.CollectorPlugin]
2022-09-19T13:27:29.128-03:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise 4.3.7 [org.graylog.plugins.enterprise.EnterprisePlugin]
2022-09-19T13:27:29.133-03:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES6 Support) 4.3.7 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es6.EnterpriseES6Plugin]
2022-09-19T13:27:29.135-03:00 INFO  [CmdLineTool] Loaded plugin: Graylog Enterprise (ES7 Support) 4.3.7 [org.graylog.plugins.enterprise.org.graylog.plugins.enterprise.es7.EnterpriseES7Plugin]
2022-09-19T13:27:29.137-03:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 4.3.7 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2022-09-19T13:27:29.140-03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 6 Support 4.3.7+05bccc7 [org.graylog.storage.elasticsearch6.Elasticsearch6Plugin]
2022-09-19T13:27:29.141-03:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 4.3.7+05bccc7 [org.graylog.storage.elasticsearch7.Elasticsearch7Plugin]
2022-09-19T13:27:29.214-03:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms1g -Xmx1g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:-OmitStackTraceInFastThrow -Djdk.tls.acknowledgeCloseNotify=true -Dlog4j2.formatMsgNoLookups=true -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2022-09-19T13:27:30.400-03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-09-19T13:27:30.500-03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-09-19T13:27:30.579-03:00 INFO  [connection] Opened connection [connectionId{localValue:1, serverValue:1687}] to localhost:27017
2022-09-19T13:27:30.655-03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=5087934}
2022-09-19T13:27:30.680-03:00 INFO  [connection] Opened connection [connectionId{localValue:2, serverValue:1688}] to localhost:27017
2022-09-19T13:27:30.733-03:00 INFO  [connection] Closed connection [connectionId{localValue:2, serverValue:1688}] to localhost:27017 because the pool has been closed.
2022-09-19T13:27:30.736-03:00 INFO  [MongoDBPreflightCheck] Connected to MongoDB version 4.0.28
2022-09-19T13:27:31.364-03:00 INFO  [SearchDbPreflightCheck] Connected to (Elastic/Open)Search version <OpenSearch:1.3.4>
2022-09-19T13:27:31.552-03:00 INFO  [Version] HV000001: Hibernate Validator null
2022-09-19T13:27:39.826-03:00 INFO  [InputBufferImpl] Message journal is enabled.
2022-09-19T13:27:39.844-03:00 INFO  [NodeId] Node ID: d236b99f-a6d7-4815-a1fc-75e9392550c2
2022-09-19T13:27:40.242-03:00 INFO  [LogManager] Loading logs.
2022-09-19T13:27:40.296-03:00 WARN  [Log] Found a corrupted index file, /var/lib/graylog-server/journal/messagejournal-0/00000000000000000000.index, deleting and rebuilding index...
2022-09-19T13:27:40.392-03:00 INFO  [LogManager] Logs loading complete.
2022-09-19T13:27:40.397-03:00 INFO  [LocalKafkaJournal] Initialized Kafka based journal at /var/lib/graylog-server/journal
2022-09-19T13:27:40.403-03:00 INFO  [cluster] Cluster created with settings {hosts=[localhost:27017], mode=SINGLE, requiredClusterType=UNKNOWN, serverSelectionTimeout='30000 ms', maxWaitQueueSize=5000}
2022-09-19T13:27:40.409-03:00 INFO  [cluster] Cluster description not yet available. Waiting for 30000 ms before timing out
2022-09-19T13:27:40.433-03:00 INFO  [connection] Opened connection [connectionId{localValue:3, serverValue:1689}] to localhost:27017
2022-09-19T13:27:40.435-03:00 INFO  [cluster] Monitor thread successfully connected to server with description ServerDescription{address=localhost:27017, type=STANDALONE, state=CONNECTED, ok=true, version=ServerVersion{versionList=[4, 0, 28]}, minWireVersion=0, maxWireVersion=7, maxDocumentSize=16777216, logicalSessionTimeoutMinutes=30, roundTripTimeNanos=1655181}
2022-09-19T13:27:40.445-03:00 INFO  [connection] Opened connection [connectionId{localValue:4, serverValue:1690}] to localhost:27017
2022-09-19T13:27:40.644-03:00 INFO  [InputBufferImpl] Initialized InputBufferImpl with ring size <65536> and wait strategy <BlockingWaitStrategy>, running 2 parallel message handlers.
2022-09-19T13:27:41.072-03:00 INFO  [ElasticsearchVersionProvider] Elasticsearch cluster is running OpenSearch:1.3.4
2022-09-19T13:27:42.295-03:00 INFO  [ProcessBuffer] Initialized ProcessBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-09-19T13:27:42.428-03:00 INFO  [OutputBuffer] Initialized OutputBuffer with ring size <65536> and wait strategy <BlockingWaitStrategy>.
2022-09-19T13:27:42.444-03:00 INFO  [connection] Opened connection [connectionId{localValue:5, serverValue:1691}] to localhost:27017
2022-09-19T13:27:42.558-03:00 INFO  [connection] Opened connection [connectionId{localValue:6, serverValue:1692}] to localhost:27017
2022-09-19T13:27:42.623-03:00 INFO  [connection] Opened connection [connectionId{localValue:7, serverValue:1693}] to localhost:27017
2022-09-19T13:27:42.709-03:00 INFO  [connection] Opened connection [connectionId{localValue:8, serverValue:1694}] to localhost:27017
2022-09-19T13:27:42.876-03:00 INFO  [connection] Opened connection [connectionId{localValue:9, serverValue:1695}] to localhost:27017
2022-09-19T13:27:49.243-03:00 ERROR [AuditLogger] Unable to write audit log entry because there is no valid license.
2022-09-19T13:27:49.248-03:00 INFO  [ServerBootstrap] Graylog server 4.3.7+05bccc7 starting up
2022-09-19T13:27:49.257-03:00 INFO  [ServerBootstrap] JRE: Private Build 18.0.2-ea on Linux 5.15.0-47-generic
2022-09-19T13:27:49.259-03:00 INFO  [ServerBootstrap] Deployment: deb
2022-09-19T13:27:49.261-03:00 INFO  [ServerBootstrap] OS: Ubuntu 22.04.1 LTS (jammy)
2022-09-19T13:27:49.263-03:00 INFO  [ServerBootstrap] Arch: amd64
2022-09-19T13:27:49.439-03:00 INFO  [connection] Opened connection [connectionId{localValue:10, serverValue:1696}] to localhost:27017
2022-09-19T13:27:50.284-03:00 INFO  [ServerBootstrap] Running 62 migrations...
2022-09-19T13:27:52.004-03:00 WARN  [ServerBootstrap] Exception while running migrations
        ... 23 more
Graylog server.conf:
is_leader = true
password_secret = <REMOVED>
root_password_sha2 = <REMOVED>
root_email = <REMOVED>
http_bind_address = 10.0.1.4:9000
http_publish_uri = http://graylog.mydomain.com/
http_external_uri = http://graylog.mydomain.com/
http_enable_cors = false
http_enable_tls = true
http_tls_cert_file = /etc/graylog/server/graylog.mydomain.com.crt
http_tls_key_file = /etc/graylog/server/graylog.mydomain.com.key
elasticsearch_hosts = https://admin:admin@graylog.mydomain.com:9200
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
Mongodb mongod.conf:
storage:
  dbPath: /var/lib/mongodb
  journal:
    enabled: true
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
net:
  port: 27017
  bindIp: 127.0.0.1
processManagement:
  timeZoneInfo: /usr/share/zoneinfo
Opensearch opensearch.yml
cluster.name: graylog
path.data: /var/lib/opensearch
network.host: 10.0.1.4
http.port: 9200
cluster.initial_master_nodes: ["graylog"]
plugins.security.ssl.transport.pemcert_filepath: graylog.mydomain.com.crt
plugins.security.ssl.transport.pemkey_filepath: graylog.mydomain.com.key
plugins.security.ssl.transport.pemtrustedcas_filepath: ca-certificates.crt
plugins.security.ssl.transport.enforce_hostname_verification: true
plugins.security.ssl.transport.enabled_protocols:
  - "TLSv1.3"
  - "TLSv1.2"
plugins.security.ssl.transport.enabled_ciphers:
  - "TLS_AES_256_GCM_SHA384"
  - "TLS_CHACHA20_POLY1305_SHA256"
  - "ECDHE-RSA-AES256-GCM-SHA384"
  - "ECDHE-RSA-CHACHA20-POLY1305"
  - "DHE-RSA-AES256-GCM-SHA384"
  - "ECDHE-RSA-AES128-GCM-SHA256"
  - "ECDHE-ECDSA-AES256-GCM-SHA384"
  - "ECDHE-ECDSA-CHACHA20-POLY1305"
  - "ECDHE-ECDSA-AES128-GCM-SHA256"
  - "DHE-RSA-AES128-GCM-SHA256"
plugins.security.ssl.http.enabled: true
plugins.security.ssl.http.pemcert_filepath: graylog.mydomain.com-full.crt
plugins.security.ssl.http.pemkey_filepath: graylog.mydomain.com.key
plugins.security.ssl.http.pemtrustedcas_filepath: ca-certificates.crt
plugins.security.ssl.http.enabled_protocols:
  - "TLSv1.3"
  - "TLSv1.2"
plugins.security.ssl.http.enabled_ciphers:
plugins.security.allow_unsafe_democertificates: true
plugins.security.allow_default_init_securityindex: true
plugins.security.authcz.admin_dn:
  - CN=graylog.mydomain.com,OU=mydomain.com,O=mydomain
Tables created on MongoDB:
access_tokens
alarmcallbackconfigurations
alarmcallbackhistory
alerts
archive_backends
archive_catalog
audit_log
cluster_config
cluster_events
collectors
content_packs
content_packs_installations
event_processor_state
forwarders
grants
index_failures
index_field_types
index_ranges
index_sets
licenses
lut_caches
lut_data_adapters
lut_tables
notifications
opensearch_anomaly_detectors
pipeline_processor_pipelines
pipeline_processor_pipelines_streams
pipeline_processor_rules
processing_status
roles
scheduler_triggers
searches
sessions
sidecar_configuration_variables
sidecars
streamrules
streams
system_messages
team_sync_backend_configs
teams
traffic
users
I’m trying getting this up since previous week, on every try I purge the previos instalations to clean the enviroment.
On MongoDB I drop the graylog database using: db.dropDatabase()
On this momment I’m trying get Graylog up without erros at logs, next step will be study about how hardening it.
Someone would point me what I’m missing?
PS.: This is my first contact with MongoDB / Opensearch / Graylog.
It would take some more research but I think this might mean that you intend to be clustered when you aren’t clustered… look into that more (I am short on time at the moment) Also, is your Java at 18? The docs say you need to be at 17…
Graylog 4.3.x and above supports OpenSearch. If you are hunting around in Elasticsearch for commands to run in OpenSearch, make sure you have the ElasticSearch web page set to version 7.10.x since that is when it was forked to OpenSearch.
The docs reference cluster.name: graylog which I also have in my elasticsearch.yml. The config cluster.initial_master_nodes: ["graylog"] is in the documentation but in a section that is referencing a cluster upgrade from Elasticsearch 7.10 to Opensearch…
Delving deeper into Java - Graylog shows different depending on where you are… OpenSearch shows 8,11,14… Honestly I really don’t know if it will be an issue or not, I only saw your 18 and was reading docs earlier in the day where it stated 17 … unlikely to be your issue.
To me ElasticsearchException: Unable to retrieve cluster information means it thinks you want a cluster but there isn’t. found this in OpenSearch docs:
# Unless you have already configured a cluster, you should set
# discovery.type to single-node, or the bootstrap checks will
# fail when you try to start the service.
discovery.type: single-node
@tmacgbay thanks for remember about interoperability, I have skipped this step.
Now, just to make things compatible have installed OpenJDK 11 and used:
apt-mark hold openjdk-11-jre-headless
The hint about:
Did not work for me using opensearch.
On the last test I did a few minutes ago, this time using elasticsearch 7.10.2 the graylog started without errors…
Following the migration guide (title: MIGRATING TO OPENSEARCH), and trying start with opensearch, same error occours.
My hope was about the problem checking occurs only because some table haven’t be created at mongodb, and since elasticsearch did all steps, everything would work… But seems not…
As I’m installing it to validate graylog in my house, I’ll stick with elasticsearch for now to see how graylog could be streamlined when dealing with logs instead use grafana (I got this one up and working in 3 days including study about hardening), later I’ll leave a ticket on GitHub about this issue.
My goal is to find a not too expensive dashboard to sell as a solution to the clients I work with (read they would buy a corporate license after my deployment - that’s why before I test everything in my lab to get a ready-made solution).
Thanks for the help!!!
PS.: I’m unable to post the link from docs,don’t know why…
Reading through all the elasticsearch docs to make sure I made all possible settings to harden it (which seems useless as the OSS version is almost without features and plugins), I seem to have found the solution to the “error” in opensearch in the version 7.17 elasticsearch docs:
If you do not need any discovery configuration, for instance if running a single-node cluster, set discovery.seed_hosts: [] to disable discovery and satisfy this bootstrap check.
Steps from docs 7.10 says:
This bootstrap check ensures that discovery is not running with the default configuration. It can be satisfied by setting at least one of the following properties:
  • discovery.seed_hosts
  • discovery.seed_providers
  • cluster.initial_master_nodes
The method I have did with last one parameter…
Did an new test on opensearch, this time using the hint from elasticsearch 7.17:
And its working with opensearch!!!
Now I can have encryption and extra security features.
Great dig!! Glad you found that!
