Ubuntu 14.04, graylog after upgrade
Hi
Running ubuntu 14.04, upgraded
  • graylog to 2.4.3
  • elasticsearch to 5.6.8
  • mongodb-org to 3.6.3
Had to set path.data in elasticsearch.yml. The graylog-server does not respond. In the log it seems as if it is looping, end with “INFO [Version] HV000001: Hibernate Validator 5.1.3.Final”
From the elasticsearch-log:
[2018-03-22T14:28:24,180][WARN ][o.e.t.n.Netty4Transport  ] [37y1JQC] exception caught on transport layer [[id: 0x63f6d071, L:/0:0:0:0:0:0:0:1:9300 ! R:/0:0:0:0:0:0:0:1:60338]], closing connection
io.netty.handler.codec.DecoderException: java.io.StreamCorruptedException: invalid internal transport message format, got (d,a,d,a)
mongodb is running (when I try mongo --host 127.0.0.1:27017).
# curl -XGET 'localhost:9200/_cluster/health?pretty'
  "cluster_name" : "graylog",
  "status" : "green",
  "timed_out" : false,
  "number_of_nodes" : 1,
  "number_of_data_nodes" : 1,
  "active_primary_shards" : 30,
  "active_shards" : 30,
  "relocating_shards" : 0,
  "initializing_shards" : 0,
  "unassigned_shards" : 0,
  "active_shards_percent_as_number" : 100.0
Any ideas?
Are you sure you’re running Graylog 2.4.3?
Because Hibernate Validator 5.1.3.Final was used by Graylog 1.2.x.
Ok. Where do change that?
You have to upgrade Graylog to a version which supports Elasticsearch 5.x (which is Graylog 2.3.0 and later) or downgrade to an Elasticsearch version supported by the Graylog version you’re running.
In general, please refer to the documentation for installation and upgrade instructions:
http://docs.graylog.org/en/2.4/pages/installation.html
I am running version 2.4.3
~# dpkg -l graylog-server
Desired=Unknown/Install/Remove/Purge/Hold
| Status=Not/Inst/Conf-files/Unpacked/halF-conf/Half-inst/trig-aWait/Trig-pend
|/ Err?=(none)/Reinst-required (Status,Err: uppercase=bad)
||/ Name                            Version              Architecture         Description
ii  graylog-server                  2.4.3-1              all                  Graylog server
Not according to the log snippet you’ve posted.
Maybe you want to provide some more details?
This is what is in the log (looping):
2018-03-23T10:59:40.962+01:00 INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
2018-03-23T10:59:45.426+01:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 2.4.3 [org.graylog.aws.plugin.AWSPlugin]
2018-03-23T10:59:45.428+01:00 INFO  [CmdLineTool] Loaded plugin: Elastic Beats Input 2.4.3 [org.graylog.plugins.beats.BeatsInputPlugin]
2018-03-23T10:59:45.439+01:00 INFO  [CmdLineTool] Loaded plugin: CEF Input 2.4.3 [org.graylog.plugins.cef.CEFInputPlugin]
2018-03-23T10:59:45.440+01:00 INFO  [CmdLineTool] Loaded plugin: Collector 2.4.3 [org.graylog.plugins.collector.CollectorPlugin]
2018-03-23T10:59:45.441+01:00 INFO  [CmdLineTool] Loaded plugin: Enterprise Integration Plugin 2.4.3 [org.graylog.plugins.enterprise_integration.EnterpriseIntegrationPlugin]
2018-03-23T10:59:45.442+01:00 INFO  [CmdLineTool] Loaded plugin: MapWidgetPlugin 2.4.3 [org.graylog.plugins.map.MapWidgetPlugin]
2018-03-23T10:59:45.443+01:00 INFO  [CmdLineTool] Loaded plugin: NetFlow Plugin 2.4.3 [org.graylog.plugins.netflow.NetFlowPlugin]
2018-03-23T10:59:45.452+01:00 INFO  [CmdLineTool] Loaded plugin: Pipeline Processor Plugin 2.4.3 [org.graylog.plugins.pipelineprocessor.ProcessorPlugin]
2018-03-23T10:59:45.453+01:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 2.4.3 [org.graylog.plugins.threatintel.ThreatIntelPlugin]
2018-03-23T10:59:45.833+01:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms2g -Xmx2g -XX:NewRatio=1 -XX:+ResizeTLAB -XX:+UseConcMarkSweepGC -XX:+CMSConcurrentMTEnabled -XX:+CMSClassUnloadingEnabled -XX:+UseParNewGC -XX:-OmitStackTraceInFastThrow -Dlog4j.configurationFile=file:///etc/graylog/server/log4j2.xml -Djava.library.path=/usr/share/graylog-server/lib/sigar -Dgraylog2.installation_source=deb
2018-03-23T10:59:46.066+01:00 INFO  [Version] HV000001: Hibernate Validator 5.1.3.Final
server.conf:
is_master = true
password_secret = 'x'
root_password_sha2 = y
root_timezone = Europe/Oslo
rest_listen_uri = http://192.168.95.27:12900/
rest_transport_uri = http://192.168.95.27:12900/
web_enable = true
web_listen_uri = http://192.168.95.27:9000/
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
allow_highlighting = false
elasticsearch_cluster_name = graylog
elasticsearch_discovery_zen_ping_unicast_hosts = 127.0.0.1:9300
elasticsearch_transport_tcp_port = 9300
elasticsearch_discovery_zen_ping_multicast_enabled = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
message_journal_max_age = 24h
message_journal_max_size = 10gb
rules_file = /etc/graylog/server/rules.drl
transport_email_hostname = zzz.zzzzzz.zz
transport_email_port = 25
transport_email_use_tls = false
transport_email_from_email = graylog@spacetec.no
transport_email_web_interface_url = https://xxx.yyy.zz:9000
elasticsearch.yml:
cluster.name: graylog
path.data: /var/lib/elasticsearch/graylog
Try running Graylog in debug mode (adding --debug or -d to the start script).
Also, what’s in the logs of your Elasticsearch node?
And last but not least, please read the upgrade notes for Graylog 2.3.x and 2.4.x, since you seem to be missing some configuration settings:
I tried to run with debug. What should I be loooking for?
elasticsearch log (some of it):
[2018-03-23T08:20:02,126][INFO ][o.e.n.Node ] [37y1JQC] started
[2018-03-23T08:20:04,260][INFO ][o.e.c.s.ClusterSettings ] [37y1JQC] updating [cluster.routing.allocation.enable] from [ALL] to [all]
[2018-03-23T08:20:05,419][INFO ][o.e.g.GatewayService ] [37y1JQC] recovered [30] indices into cluster_state
[2018-03-23T08:20:12,179][INFO ][o.e.c.r.a.AllocationService] [37y1JQC] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_179][0], [graylog_178][0], [graylog_177][0]] …]).
[2018-03-23T08:20:33,860][INFO ][o.e.n.Node ] [37y1JQC] stopping …
[2018-03-23T08:20:34,045][INFO ][o.e.n.Node ] [37y1JQC] stopped
[2018-03-23T08:20:34,046][INFO ][o.e.n.Node ] [37y1JQC] closing …
[2018-03-23T08:20:34,056][INFO ][o.e.n.Node ] [37y1JQC] closed
[2018-03-23T08:20:37,184][INFO ][o.e.n.Node ] [] initializing …
[2018-03-23T08:20:37,350][INFO ][o.e.e.NodeEnvironment ] [37y1JQC] using [1] data paths, mounts [[/disk1 (/dev/sda1)]], net usable_space [533.6gb], net total_space [1tb], spins? [possibly], types [ext4]
[2018-03-23T08:20:37,350][INFO ][o.e.e.NodeEnvironment ] [37y1JQC] heap size [2gb], compressed ordinary object pointers [true]
[2018-03-23T08:20:37,426][INFO ][o.e.n.Node ] node name [37y1JQC] derived from node ID [37y1JQCvQsueEvMYhTXAwg]; set [node.name] to override
[2018-03-23T08:20:37,426][INFO ][o.e.n.Node ] version[5.6.8], pid[6452], build[688ecce/2018-02-16T16:46:30.010Z], OS[Linux/3.13.0-143-generic/amd64], JVM[Oracle Corporation/Java HotSpot™ 64-Bit Server VM/9.0.4/9.0.4+11]
[2018-03-23T08:20:37,426][INFO ][o.e.n.Node ] JVM arguments [-Xms2g, -Xmx2g, -XX:CMSInitiatingOccupancyFraction=75, -XX:+UseCMSInitiatingOccupancyOnly, -XX:+AlwaysPreTouch, -Xss1m, -Djava.awt.headless=true, -Dfile.encoding=UTF-8, -Djna.nosys=true, -Djdk.io.permissionsUseCanonicalPath=true, -Dio.netty.noUnsafe=true, -Dio.netty.noKeySetOptimization=true, -Dio.netty.recycler.maxCapacityPerThread=0, -Dlog4j.shutdownHookEnabled=false, -Dlog4j2.disable.jmx=true, -Dlog4j.skipJansi=true, -XX:+HeapDumpOnOutOfMemoryError, -Des.path.home=/usr/share/elasticsearch]
[2018-03-23T08:20:38,759][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [aggs-matrix-stats]
[2018-03-23T08:20:38,759][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [ingest-common]
[2018-03-23T08:20:38,759][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [lang-expression]
[2018-03-23T08:20:38,759][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [lang-groovy]
[2018-03-23T08:20:38,759][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [lang-mustache]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [lang-painless]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [parent-join]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [percolator]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [reindex]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [transport-netty3]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] loaded module [transport-netty4]
[2018-03-23T08:20:38,760][INFO ][o.e.p.PluginsService ] [37y1JQC] no plugins loaded
[2018-03-23T08:20:40,892][INFO ][o.e.d.DiscoveryModule ] [37y1JQC] using discovery type [zen]
[2018-03-23T08:20:41,947][INFO ][o.e.n.Node ] initialized
[2018-03-23T08:20:41,947][INFO ][o.e.n.Node ] [37y1JQC] starting …
[2018-03-23T08:20:42,187][INFO ][o.e.t.TransportService ] [37y1JQC] publish_address {127.0.0.1:9300}, bound_addresses {[::1]:9300}, {127.0.0.1:9300}
[2018-03-23T08:20:45,289][INFO ][o.e.c.s.ClusterService ] [37y1JQC] new_master {37y1JQC}{37y1JQCvQsueEvMYhTXAwg}{XLEJWooyTzS9livsyTKPZQ}{127.0.0.1}{127.0.0.1:9300}, reason: zen-disco-elected-as-master ([0] nodes joined)
[2018-03-23T08:20:45,335][INFO ][o.e.h.n.Netty4HttpServerTransport] [37y1JQC] publish_address {127.0.0.1:9200}, bound_addresses {[::1]:9200}, {127.0.0.1:9200}
[2018-03-23T08:20:45,335][INFO ][o.e.n.Node ] [37y1JQC] started
[2018-03-23T08:20:47,687][INFO ][o.e.c.s.ClusterSettings ] [37y1JQC] updating [cluster.routing.allocation.enable] from [ALL] to [all]
[2018-03-23T08:20:48,890][INFO ][o.e.g.GatewayService ] [37y1JQC] recovered [30] indices into cluster_state
[2018-03-23T08:20:56,414][INFO ][o.e.c.r.a.AllocationService] [37y1JQC] Cluster health status changed from [RED] to [GREEN] (reason: [shards started [[graylog_177][0]] …]).
I saw some parameters that removed in 2.3, and removed it. No difference.
This is the plugin directory:
ll /usr/share/graylog-server/plugin/
total 37960
drwxr-xr-x 2 root root 4096 mars 23 09:05 ./
drwxr-xr-x 6 root root 4096 mars 23 09:05 …/
-rw-r–r-- 1 root root 13997198 jan. 24 23:30 graylog-plugin-aws-2.4.3.jar
-rw-r–r-- 1 root root 27034 jan. 24 23:30 graylog-plugin-beats-2.4.3.jar
-rw-r–r-- 1 root root 60153 jan. 24 23:30 graylog-plugin-cef-2.4.3.jar
-rw-r–r-- 1 root root 2971112 jan. 24 23:30 graylog-plugin-collector-2.4.3.jar
-rw-r–r-- 1 root root 4296855 jan. 24 23:30 graylog-plugin-enterprise-integration-2.4.3.jar
-rw-r–r-- 1 root root 6617711 jan. 24 23:30 graylog-plugin-map-widget-2.4.3.jar
-rw-r–r-- 1 root root 705987 jan. 24 23:30 graylog-plugin-netflow-2.4.3.jar
-rw-r–r-- 1 root root 5594731 jan. 24 23:30 graylog-plugin-pipeline-processor-2.4.3.jar
-rw-r–r-- 1 root root 4574666 jan. 24 23:30 graylog-plugin-threatintel-2.4.3.jar
Any error messages in the logs of your Graylog node (they might also come on DEBUG level).
Are Graylog and Elasticsearch running on the same machine?
A lot of info, this is one thing, perhaps:
2018-03-23T14:36:32.386+01:00 DEBUG [PluginProperties] No value found for attribute in JAR manifest of file </usr/share/graylog-server/plugin/graylog-plugin-netflow-2.4.3.jar>
Everything on the same server.
Please don’t just post arbitrary excerpts from the logs.
Should I post the whole log here?
I was not able to post what was logged.
@jochen
Could it be the java version?
java -version
java version “9.0.4”
Java™ SE Runtime Environment (build 9.0.4+11)
Java HotSpot™ 64-Bit Server VM (build 9.0.4+11, mixed mode)
I have tried a lot of different things now, still the same problem
Please use a pastebin service such as https://gist.github.com/ or https://0bin.net/.
Yes. Graylog 2.x doesn’t work with Java 9.
Thanks! That was the problem.
