I’ve been going through the documentation on DockerHub and I got everything converted for k8s. However, we I deploy my Stateful Set and view the logs from my container, I’m getting the following is repeating error message:
Caused by: kafka.common.KafkaException: Failed to acquire lock on file .lock in /usr/share/graylog/data/journal. A Kafka instance in another process or thread is using this directory.
Here’s a copy of my K8s manifest:
apiVersion: apps/v1beta1
kind: StatefulSet
metadata:
namespace: graylog
labels:
component: graylog
role: master
spec:
serviceName: graylog-master
replicas: 1
selector:
matchLabels:
component: graylog
role: master
template:
metadata:
labels:
component: graylog
role: master
spec:
serviceAccountName: graylog
containers:
- name: graylog
image: graylog2/graylog:2.4.3-1
ports:
- containerPort: 9000
protocol: TCP
volumeMounts:
- name: graylog-journal
mountPath: /usr/share/graylog/data/journal
env:
- name: NAMESPACE
valueFrom:
fieldRef:
fieldPath: metadata.namespace
- name: NODE_NAME
valueFrom:
fieldRef:
- name: "GRAYLOG_ELASTICSEARCH_HOSTS"
value: "http://elasticsearch-graylog.svc.cluster.local:9200/"
- name: "GRAYLOT_ELASTICSEARCH_DISCOVERY_ENABLED"
value: "true"
- name: "GRAYLOG_MONGODB_URI"
value: "mongodb://mongodb-graylog-mongodb.graylog.svc.cluster.local:27017/graylog"
- name: "GRAYLOG_PASSWORD_SECRET"
valueFrom:
secretKeyRef:
key: gl_passwd_secret
- name: "GRAYLOG_ROOT_PASSWORD_SHA2"
valueFrom:
secretKeyRef:
key: gl_root_passwd
- name: "GRAYLOG_REST_TRANSPORT_URI"
value: "http://0.0.0.0:9000/api/"
- name: "GRAYLOG_REST_LISTEN_URI"
- name: "GRAYLOG_WEB_LISTEN_URI"
value: "http://0.0.0.0:9000"
- name: "GRAYLOG_ROOT_TIMEZONE"
value: "GMT"
volumeClaimTemplates:
- metadata:
namespace: graylog
spec:
accessModes: [ 'ReadWriteOnce' ]
storageClassName: standard
resources:
requests:
storage: "10Gi"
I have also confirmed that the stateful set is creating a new PVC and that it is mounted. I just don’t understand why/how Kafka can’t acquire this lock on a new container.
