Graylog java.io.IOException: Connection is closed
Howdy Folks,
We are seeing below traceback in our graylog and it seems to happen fairly frequently. I checked our elasticsearch logs and they look good. I saw cpu spike once to 100% for one of the node other nodes were around 60%. Just wondering if any recommendation/suggestion to debug/fix this.
2020-10-20T17:30:20.803Z ERROR [ServerRuntime$Responder] An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: java.io.IOException: Connection is closed
    at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:92) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:162) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1130) ~[graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:711) [graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:444) [graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:434) [graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:329) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
    at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
    at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
    at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
    at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
    at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
    at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
    at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_131]
    at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_131]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_131]
Caused by: java.io.IOException: Connection is closed
    at org.glassfish.grizzly.nio.NIOConnection.assertOpen(NIOConnection.java:445) ~[graylog.jar:?]
    at org.glassfish.grizzly.http.io.OutputBuffer.write(OutputBuffer.java:677) ~[graylog.jar:?]
    at org.glassfish.grizzly.http.server.NIOOutputStreamImpl.write(NIOOutputStreamImpl.java:83) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:229) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:299) ~[graylog.jar:?]
    at com.fasterxml.jackson.core.json.UTF8JsonGenerator._flushBuffer(UTF8JsonGenerator.java:2039) ~[graylog.jar:?]
    at com.fasterxml.jackson.core.json.UTF8JsonGenerator._writeStringSegment2(UTF8JsonGenerator.java:1354) ~[graylog.jar:?]
    at com.fasterxml.jackson.core.json.UTF8JsonGenerator._writeStringSegment(UTF8JsonGenerator.java:1301) ~[graylog.jar:?]
    at com.fasterxml.jackson.core.json.UTF8JsonGenerator.writeString(UTF8JsonGenerator.java:457) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.std.StringSerializer.serialize(StringSerializer.java:49) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.std.MapSerializer.serializeFields(MapSerializer.java:633) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.std.MapSerializer.serialize(MapSerializer.java:536) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.std.MapSerializer.serialize(MapSerializer.java:30) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.BeanPropertyWriter.serializeAsField(BeanPropertyWriter.java:704) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.std.BeanSerializerBase.serializeFields(BeanSerializerBase.java:689) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.BeanSerializer.serialize(BeanSerializer.java:155) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serializeContents(IndexedListSerializer.java:119) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serialize(IndexedListSerializer.java:79) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serialize(IndexedListSerializer.java:18) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ser.DefaultSerializerProvider.serializeValue(DefaultSerializerProvider.java:292) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ObjectWriter$Prefetch.serialize(ObjectWriter.java:1429) ~[graylog.jar:?]
    at com.fasterxml.jackson.databind.ObjectWriter.writeValue(ObjectWriter.java:951) ~[graylog.jar:?]
    at com.fasterxml.jackson.jaxrs.base.ProviderBase.writeTo(ProviderBase.java:625) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:265) ~[graylog.jar:?]
    at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:250) ~[graylog.jar:?]
    at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:106) ~[graylog.jar:?]
    at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:86) ~[graylog.jar:?]
    ... 20 more
Caused by: java.io.IOException: Broken pipe
    at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:1.8.0_131]
    at sun.nio.ch.SocketDispatcher.write(SocketDispatcher.java:47) ~[?:1.8.0_131]
    at sun.nio.ch.IOUtil.writeFromNativeBuffer(IOUtil.java:93) ~[?:1.8.0_131]
    at sun.nio.ch.IOUtil.write(IOUtil.java:51) ~[?:1.8.0_131]
    at sun.nio.ch.SocketChannelImpl.write(SocketChannelImpl.java:471) ~[?:1.8.0_131]
    at org.glassfish.grizzly.nio.transport.TCPNIOUtils.flushByteBuffer(TCPNIOUtils.java:149) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.transport.TCPNIOUtils.writeCompositeBuffer(TCPNIOUtils.java:86) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:129) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:106) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:260) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:169) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:71) ~[graylog.jar:?]
    at org.glassfish.grizzly.nio.transport.TCPNIOTransportFilter.handleWrite(TCPNIOTransportFilter.java:126) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.TransportFilter.handleWrite(TransportFilter.java:191) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.ExecutorResolver$8.execute(ExecutorResolver.java:111) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:284) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:201) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:133) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:112) ~[graylog.jar:?]
    at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:77) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.FilterChainContext.write(FilterChainContext.java:890) ~[graylog.jar:?]
    at org.glassfish.grizzly.filterchain.FilterChainContext.write(FilterChainContext.java:858) ~[graylog.jar:?]
    at org.glassfish.grizzly.http.io.OutputBuffer.flushBuffer(OutputBuffer.java:1059) ~[graylog.jar:?]
    at org.glassfish.grizzly.http.io.OutputBuffer.write(OutputBuffer.java:709) ~[graylog.jar:?]
    ... 20 more
Collapse
