MappableException: java.io.IOException: Connection is closed
Hi using graylog 4.1.6 I find sometimes the follow error that I don’t know how to address
2022-04-12 14:06:25,456 ERROR: org.glassfish.jersey.server.ServerRuntime$Responder - An I/O error has occurred while writing a response message entity to the container output stream.
org.glassfish.jersey.server.internal.process.MappableException: java.io.IOException: Connection is closed
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:67) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor.proceed(WriterInterceptorExecutor.java:139) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.MessageBodyFactory.writeTo(MessageBodyFactory.java:1116) ~[graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime$Responder.writeResponse(ServerRuntime.java:635) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime$Responder.processResponse(ServerRuntime.java:373) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime$Responder.process(ServerRuntime.java:363) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime$1.run(ServerRuntime.java:258) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:248) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:244) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:292) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:274) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:244) [graylog.jar:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:265) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:234) [graylog.jar:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:680) [graylog.jar:?]
	at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:356) [graylog.jar:?]
	at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:200) [graylog.jar:?]
	at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:180) [graylog.jar:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(Unknown Source) [?:?]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source) [?:?]
	at java.lang.Thread.run(Unknown Source) [?:?]
Caused by: java.io.IOException: Connection is closed
	at org.glassfish.grizzly.nio.NIOConnection.assertOpen(NIOConnection.java:441) ~[graylog.jar:?]
	at org.glassfish.grizzly.http.io.OutputBuffer.write(OutputBuffer.java:663) ~[graylog.jar:?]
	at org.glassfish.grizzly.http.server.NIOOutputStreamImpl.write(NIOOutputStreamImpl.java:59) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.CommittingOutputStream.write(CommittingOutputStream.java:200) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$UnCloseableOutputStream.write(WriterInterceptorExecutor.java:276) ~[graylog.jar:?]
	at com.fasterxml.jackson.core.json.UTF8JsonGenerator._flushBuffer(UTF8JsonGenerator.java:2085) ~[graylog.jar:?]
	at com.fasterxml.jackson.core.json.UTF8JsonGenerator.writeFieldName(UTF8JsonGenerator.java:216) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.StdKeySerializers$StringKeySerializer.serialize(StdKeySerializers.java:263) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.MapSerializer.serializeFields(MapSerializer.java:711) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.MapSerializer.serialize(MapSerializer.java:643) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.MapSerializer.serialize(MapSerializer.java:33) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.BeanPropertyWriter.serializeAsField(BeanPropertyWriter.java:727) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.BeanSerializerBase.serializeFields(BeanSerializerBase.java:719) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.BeanSerializer.serialize(BeanSerializer.java:155) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serializeContents(IndexedListSerializer.java:119) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serialize(IndexedListSerializer.java:79) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.impl.IndexedListSerializer.serialize(IndexedListSerializer.java:18) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.MapSerializer.serializeFields(MapSerializer.java:722) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.DefaultSerializerProvider._serialize(DefaultSerializerProvider.java:480) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.DefaultSerializerProvider.serializeValue(DefaultSerializerProvider.java:319) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ObjectWriter$Prefetch.serialize(ObjectWriter.java:1396) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ObjectWriter.writeValue(ObjectWriter.java:913) ~[graylog.jar:?]
	at com.fasterxml.jackson.jaxrs.base.ProviderBase.writeTo(ProviderBase.java:625) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.invokeWriteTo(WriterInterceptorExecutor.java:242) ~[graylog.jar:?]
	at org.glassfish.jersey.message.internal.WriterInterceptorExecutor$TerminalWriterInterceptor.aroundWriteTo(WriterInterceptorExecutor.java:227) ~[graylog.jar:?]
	at org.glassfish.jersey.server.internal.JsonWithPaddingInterceptor.aroundWriteTo(JsonWithPaddingInterceptor.java:85) ~[graylog.jar:?]
	at org.glassfish.jersey.server.internal.MappableExceptionWrapperInterceptor.aroundWriteTo(MappableExceptionWrapperInterceptor.java:61) ~[graylog.jar:?]
	... 20 more
Caused by: java.io.IOException: Broken pipe
	at sun.nio.ch.FileDispatcherImpl.write0(Native Method) ~[?:?]
	at sun.nio.ch.SocketDispatcher.write(Unknown Source) ~[?:?]
	at sun.nio.ch.IOUtil.writeFromNativeBuffer(Unknown Source) ~[?:?]
	at sun.nio.ch.IOUtil.write(Unknown Source) ~[?:?]
	at sun.nio.ch.SocketChannelImpl.write(Unknown Source) ~[?:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOUtils.flushByteBuffer(TCPNIOUtils.java:125) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOUtils.writeCompositeBuffer(TCPNIOUtils.java:64) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:105) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOAsyncQueueWriter.write0(TCPNIOAsyncQueueWriter.java:82) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:236) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:145) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.AbstractNIOAsyncQueueWriter.write(AbstractNIOAsyncQueueWriter.java:47) ~[graylog.jar:?]
	at org.glassfish.grizzly.nio.transport.TCPNIOTransportFilter.handleWrite(TCPNIOTransportFilter.java:102) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.TransportFilter.handleWrite(TransportFilter.java:167) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.ExecutorResolver$8.execute(ExecutorResolver.java:87) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeFilter(DefaultFilterChain.java:260) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.executeChainPart(DefaultFilterChain.java:177) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.execute(DefaultFilterChain.java:109) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.DefaultFilterChain.process(DefaultFilterChain.java:88) ~[graylog.jar:?]
	at org.glassfish.grizzly.ProcessorExecutor.execute(ProcessorExecutor.java:53) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.FilterChainContext.write(FilterChainContext.java:866) ~[graylog.jar:?]
	at org.glassfish.grizzly.filterchain.FilterChainContext.write(FilterChainContext.java:834) ~[graylog.jar:?]
	at org.glassfish.grizzly.http.io.OutputBuffer.flushBuffer(OutputBuffer.java:1068) ~[graylog.jar:?]
	at org.glassfish.grizzly.http.io.OutputBuffer.write(OutputBuffer.java:695) ~[graylog.jar:?]
	at com.fasterxml.jackson.core.json.UTF8JsonGenerator._writeStringSegment2(UTF8JsonGenerator.java:1400) ~[graylog.jar:?]
	at com.fasterxml.jackson.core.json.UTF8JsonGenerator._writeStringSegment(UTF8JsonGenerator.java:1347) ~[graylog.jar:?]
	at com.fasterxml.jackson.core.json.UTF8JsonGenerator.writeString(UTF8JsonGenerator.java:460) ~[graylog.jar:?]
	at com.fasterxml.jackson.databind.ser.std.StringSerializer.serialize(StringSerializer.java:41) ~[graylog.jar:?]
	... 20 more
Can somebody help me to address it?
Gianluca
I found a similar error like yours here.
When this error is shown what is the user doing at that time?
EDIT: Try rotating the active write index (System/Indices/Index Set/Maintenance).
This maybe there results from your other post here. It seams to be point to heap size on ES and Graylog respectively. Can you show these configurations?
How much logs are being ingested?
Hi @gsmith
for ES I have:
ELASTIC -Xms512m -Xmx512m
for Graylog:
GRAYLOG -Xms8g -Xmx32g
About the logs we have to manage 2 milion logs/day but we receive 1 milion in 1h
Maybe I have to increase the ES heap size
Gianluca
It seams in a short span of time you get all you logs :thinking:
My Average is about 500-1000 message per second and total 25 million a day.
Elasticsearch Heap configure.
## JVM configuration
## IMPORTANT: JVM heap size
## You should always set the min and max JVM heap
## size to the same value. For example, to set
## the heap to 4 GB, set:
## -Xms4g
## -Xmx4g
## See https://www.elastic.co/guide/en/elasticsearch/reference/current/heap-size.html
## for more information
# Xms represents the initial size of total heap space
# Xmx represents the maximum size of total heap space
-Xms4g
-Xmx4g
Graylog Heap
GRAYLOG_SERVER_JAVA_OPTS="-Xms3g -Xmx3g  "
I noticed this configuration below because I haven’t seen configuration where the two settings have a very large gap between them.
I assume you have 64+Gb of RAM/Memory?
If not you may want to adjust those setting to either they match or there closer. The reason I say this since there is no information about you setting/ resources I assume you have a lot of RAM this all adds up from Graylog Heap/Elasticsearch Heap/ Operating System need RAM, etc…
Make sure to not use all memory for the JVM heap but leave at least 50% of the system memory for use as disk buffer/cache.
If your machine has 12 GB of memory, you should probably use 4 GB for the ES heap, 2 GB for the Graylog heap, and leave the rest (6 GB) for the operating system to use as disk buffer/cache.
I’m not sure about your environment but I would set your Graylog Heap to either one of these depending on how much memory you have to spend.
Example:
  • GRAYLOG -Xms8g -Xmx8g
  • GRAYLOG -Xms16g -Xmx16g
  • GRAYLOG -Xms32g -Xmx32g
Hope that helps
