Graylog initial setup - Web interface no loading
Hey folks, having some issues with new Graylog install.
Fresh install of Ubuntu 24.03, Mongo and Graylog per the documentation. I cannot get the web interface to load for initial login. I have reviewed a similar issue here but that did not seem to solve my problem. I check with netstat -nl and I do not see the Graylog ports listening on 9000 or 9200, but the Mongo DB port is listening.
  • OS Information: Ubuntu 24.03
  • Package Version: Latest available via apt install
    mongod.conf
# mongod.conf
# for documentation of all options, see:
#   http://docs.mongodb.org/manual/reference/configuration-options/
# Where and how to store data.
storage:
  dbPath: /var/lib/mongodb
#  engine:
#  wiredTiger:
# where to write logging data.
systemLog:
  destination: file
  logAppend: true
  path: /var/log/mongodb/mongod.log
# network interfaces
net:
  port: 27017
  bindIp: 192.168.10.94
# how the process runs
processManagement:
  timeZoneInfo: /usr/share/zoneinfo
Do to character restrictions I’ll put the Graylog conf in a following post.
# GRAYLOG CONFIGURATION FILE
# This is the Graylog configuration file. The file has to use ISO 8859-1/Latin-1 character encoding.
# Characters that cannot be directly represented in this encoding can be written using Unicode escapes
# as defined in https://docs.oracle.com/javase/specs/jls/se8/html/jls-3.html#jls-3.3, using the \u prefix.
# For example, \u002c.
# * Entries are generally expected to be a single line of the form, one of the following:
# propertyName=propertyValue
# propertyName:propertyValue
# * White space that appears between the property name and property value is ignored,
#   so the following are equivalent:
# name=Stephen
# name = Stephen
# * White space at the beginning of the line is also ignored.
# * Lines that start with the comment characters ! or # are ignored. Blank lines are also ignored.
# * The property value is generally terminated by the end of the line. White space following the
#   property value is not ignored, and is treated as part of the property value.
# * A property value can span several lines if each line is terminated by a backslash (‘\’) character.
#   For example:
# targetCities=\
#         Detroit,\
#         Chicago,\
#         Los Angeles
#   This is equivalent to targetCities=Detroit,Chicago,Los Angeles (white space at the beginning of lines is ignored).
# * The characters newline, carriage return, and tab can be inserted with characters \n, \r, and \t, respectively.
# * The backslash character must be escaped as a double backslash. For example:
# path=c:\\docs\\doc1
# If you are running more than one instances of Graylog server you have to select one of these
# instances as leader. The leader will perform some periodical tasks that non-leaders won't perform.
is_leader = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
# ATTENTION: This value must be the same on all Graylog nodes in the cluster.
# Changing this value after installation will render all user sessions and encrypted values in the database invalid. (e.g. encrypted access tokens)
password_secret = 59264-<REMOVED>-757a7
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | sha256sum
# and put the resulting hash value into the following line
root_password_sha2 = e1f92-<REMOVED>-5f6c7
# Default is empty
#root_email = ""
# Default is UTC
root_timezone = UTC
# Set the bin directory here (relative or absolute)
# This directory contains binaries that are used by the Graylog server.
# Default: bin
# Set the data directory here (relative or absolute)
# This directory is used to store Graylog server state.
# HTTP settings
#### HTTP bind address
# Default: 127.0.0.1:9000
http_bind_address = 192.168.10.194:9000
#### HTTP publish URI
# The URI will be published in the cluster discovery APIs, so that other Graylog nodes will be able to find and connect to this Graylog node.
# This configuration setting *must not* contain a wildcard address!
#http_publish_uri = http://192.168.1.1:9000/
#### External Graylog URI
# This setting can be overridden on a per-request basis with the "X-Graylog-Server-URL" HTTP request header.
# Default: $http_publish_uri
#http_external_uri =
#### Enable CORS headers for HTTP interface
# This allows browsers to make Cross-Origin requests from any origin.
# This is disabled for security reasons and typically only needed if running graylog
# with a separate server for frontend development.
# Default: false
#http_enable_cors = false
#### Enable GZIP support for HTTP interface
# This compresses API responses and therefore helps to reduce
#http_enable_gzip = false
#http_max_header_size = 8192
# The size of the thread pool used exclusively for serving the HTTP interface.
#http_thread_pool_size = 64
# HTTPS settings
# Default: false
#http_enable_tls = true
# The password to unlock the private key used for securing the HTTP interface.
# If set to "true", Graylog will periodically investigate indices to figure out which fields are used in which streams.
# It will make field list in Graylog interface show only fields used in selected streams, but can decrease system performance,
# especially on systems with great number of streams and fields.
# requires authentication.
elasticsearch_hosts = http://192.168.10.94:9200
# Maximum number of attempts to connect to elasticsearch on boot for the version probe.
# Default: 0, retry indefinitely with the given delay until a connection could be established
#elasticsearch_version_probe_attempts = 5
# Waiting time in between connection attempts for elasticsearch_version_probe_attempts
# Default: 5s
#elasticsearch_version_probe_delay = 5s
# Maximum amount of time to wait for successful connection to Elasticsearch HTTP port.
# Default: 10 Seconds
# (e. g. during search, index creation, or index time-range calculations)
# Default: 60 seconds
# be tore down.
# Default: inf
# Default: 200
#elasticsearch_max_total_connections = 200
# elasticsearch server).
# Default: 20
#elasticsearch_max_total_connections_per_route = 20
# Maximum number of times Graylog will retry failed requests to Elasticsearch.
# Default: 2
#elasticsearch_max_retries = 2
# Enable automatic Elasticsearch node discovery through Nodes Info,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster-nodes-info.html
# WARNING: Automatic node discovery does not work if Elasticsearch requires authentication, e. g. with Shield.
# Default: false
#elasticsearch_discovery_enabled = true
# Filter for including/excluding Elasticsearch nodes in discovery according to their custom attributes,
# see https://www.elastic.co/guide/en/elasticsearch/reference/5.4/cluster.html#cluster-nodes
# Default: empty
#elasticsearch_discovery_filter = rack:42
# Default: 30s
# Set the default scheme when connecting to Elasticsearch discovered nodes
# Default: http (available options: http, https)
#elasticsearch_discovery_default_scheme = http
# Default: false
# Enable use of "Expect: 100-continue" Header for Elasticsearch index requests.
# If this is disabled, Graylog cannot properly handle HTTP 413 Request Entity Too Large errors.
# Default: true
#elasticsearch_use_expect_continue = true
# Graylog uses Index Sets to manage settings for groups of indices. The default options for index sets are configurable
# for each index set in Graylog under System > Configuration > Index Set Defaults.
# The following settings are used to initialize in-database defaults on the first Graylog server startup.
# Specify these values if you want the Graylog server and indices to start with specific settings.
# The prefix for the Default Graylog index set.
#elasticsearch_index_prefix = graylog
# The name of the index template for the Default Graylog index set.
# The prefix for the for graylog event indices.
#default_events_index_prefix = gl-events
# The prefix for graylog system event indices.
#default_system_events_index_prefix = gl-system-events
#elasticsearch_analyzer = standard
# How many Elasticsearch shards and replicas should be used per index?
#elasticsearch_shards = 1
#elasticsearch_replicas = 0
# Maximum number of attempts to connect to datanode on boot.
#datanode_startup_connection_attempts = 5
# Waiting time in between connection attempts for datanode_startup_connection_attempts
# Default: 5s
# datanode_startup_connection_delay = 5s
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# Time interval to refresh index field types.
# Default: 5s
#index_field_type_refresh_interval = 5s
# Time interval to trigger a full refresh of the index field types for all indexes. This will query ES for all indexes
# and populate any missing field type information to the database.
#index_field_type_periodical_full_refresh_interval = 5m
# You can configure the default strategy used to determine when to rotate the currently active write index.
# Multiple rotation strategies are supported, the default being "time-size-optimizing":
#   - "time-size-optimizing" tries to rotate daily, while focussing on optimal sized shards.
#      The global default values can be configured with
#       "time_size_optimizing_retention_min_lifetime" and "time_size_optimizing_retention_max_lifetime".
#   - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
#   - "size" per index, use elasticsearch_max_size_per_index below to configure
#   - "time" interval between index rotations, use elasticsearch_max_time_per_index to configure
# A strategy may be disabled by specifying the optional enabled_index_rotation_strategies list and excluding that strategy.
#enabled_index_rotation_strategies = count,size,time,time-size-optimizing
# The default index rotation strategy to use.
#rotation_strategy = time-size-optimizing
#elasticsearch_max_docs_per_index = 20000000
# no_retention and elasticsearch_max_number_of_indices. Default is 30GB.
#elasticsearch_max_size_per_index = 32212254720
#  1w  = 1 week
#  1d  = 1 day
#  12h = 12 hours
# Controls whether empty indices are rotated. Only applies to the "time" rotation_strategy.
#elasticsearch_rotate_empty_index_set=false
# Provides a hard upper limit for the retention period of any index set at configuration time.
# This setting is used to validate the value a user chooses for the maximum number of retained indexes, when configuring
# an index set. However, it is only in effect, when a time-based rotation strategy is chosen.
# If a rotation strategy other than time-based is selected and/or no value is provided for this setting, no upper limit
# for index retention will be enforced. This is also the default.
# Default: none
#max_index_retention_period = P90d
# Optional upper bound on elasticsearch_max_time_per_index
#elasticsearch_max_write_index_age = 1d
#no_retention = false
# The following strategies are available:
#retention_strategy = delete
# This configuration list limits the retention strategies available for user configuration via the UI
# The following strategies can be disabled:
#   - none #  No operation is performed. The index stays open. (Not recommended)
# WARNING: At least one strategy must be enabled. Be careful when extending this list on existing installations!
disabled_retention_strategies = none,close
# How many indices do you want to keep for the delete and close retention types?
#elasticsearch_max_number_of_indices = 20
# be enabled with care. See also: https://docs.graylog.org/docs/query-language
allow_highlighting = false
# Sets field value suggestion mode. The possible values are:
#  1. "off" - field value suggestions are turned off
#  2. "textual_only" - field values are suggested only for textual fields
#  3. "on" (default) - field values are suggested for all field types, even the types where suggestions are inefficient performance-wise
field_value_suggestion_mode = on
# Default: 1h
# This value should be set lower than elasticsearch_max_total_connections_per_route, otherwise index optimization
# could deplete all the client connections to the search server and block new messages ingestion for prolonged
# periods of time.
# Default: 10
#elasticsearch_index_optimization_jobs = 10
# Mute the logging-output of ES deprecation warnings during REST calls in the ES RestClient
#elasticsearch_mute_deprecation_warnings = true
# Default: 1h
# Batch size for the Elasticsearch output. This is the maximum accumulated size of messages that are written to
# Elasticsearch in a batch call. If the configured batch size has not been reached within output_flush_interval seconds,
# everything that is available will be flushed at once.
# Each output buffer processor has to keep an entire batch of messages in memory until it has been sent to
# Elasticsearch, so increasing this value will also increase the memory requirements of the Graylog server.
# Batch sizes can be specified in data units (e.g. bytes, kilobytes, megabytes) or as an absolute number of messages.
# Example: output_batch_size = 10mb
output_batch_size = 500
output_flush_interval = 1
# Number of process buffer processors running in parallel.
# By default, the value will be determined automatically based on the number of CPU cores available to the JVM, using
# the formula (<#cores> * 0.36 + 0.625) rounded to the nearest integer.
# Set this value explicitly to override the dynamically calculated value. Try raising the number if your buffers are
# filling up.
#processbuffer_processors = 5
# Number of output buffer processors running in parallel.
# the formula (<#cores> * 0.162 + 0.625) rounded to the nearest integer.
# filling up.
#outputbuffer_processors = 3
# The size of the thread pool in the output buffer processor.
# Default: 3
# Possible types:
#  - yielding
#  - sleeping
#  - blocking
#  - busy_spinning
ring_size = 65536
inputbuffer_ring_size = 65536
# Number of input buffer processors running in parallel.
#inputbuffer_processors = 2
# Manually stopped inputs are no longer auto-restarted. To re-enable the previous behavior, set auto_restart_inputs to true.
#auto_restart_inputs = true
# Enable the message journal.
# The directory which will be used to store the message journal. The directory must be exclusively used by Graylog and
# ATTENTION:
#   If you create a separate partition for the journal files and use a file system creating directories like 'lost+found'
# Default: <data_dir>/journal
message_journal_max_age = 72h
message_journal_max_size = 90gb
# disabled if not set.
# messages end up.
# Time in milliseconds after which a detected stale leader node is being rechecked on startup.
#stale_leader_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# '+'-signs in the username or password need to be replaced by '%2B'
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog?replicaSet=rs01
# DNS Seedlist https://docs.mongodb.com/manual/reference/connection-string/#dns-seedlist-connection-format
#mongodb_uri = mongodb+srv://server.example.org/graylog
# Maximum number of attempts to connect to MongoDB on boot for the version probe.
# Default: 0, retry indefinitely until a connection can be established
#mongodb_version_probe_attempts = 5
# Email transport
#transport_email_enabled = false
#transport_email_hostname = mail.example.com
#transport_email_port = 587
#transport_email_use_auth = true
#transport_email_socket_connection_timeout = 10s
#transport_email_socket_timeout = 10s
# Encryption settings
# ATTENTION:
#    Using SMTP with STARTTLS *and* SMTPS at the same time is *not* possible.
# Use SMTP with STARTTLS, see https://en.wikipedia.org/wiki/Opportunistic_TLS
# Use SMTP over SSL (SMTPS), see https://en.wikipedia.org/wiki/SMTPS
# This is deprecated on most SMTP services!
#transport_email_use_ssl = false
# The User-Agent header for outgoing HTTP connections.
# Default: Graylog
#http_user_agent = Graylog
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
# ATTENTION: If you configure a proxy, make sure to also configure the "http_non_proxy_hosts" option so internal
#            HTTP connections with other nodes does not go through the proxy.
# Examples:
#   - http://proxy.example.com:8123
#   - http://username:password@proxy.example.com:8123
#http_proxy_uri =
# A list of hosts that should be reached directly, bypassing the configured proxy server.
# This is a list of patterns separated by ",". The patterns may start or end with a "*" for wildcards.
# Any host matching one of these patterns will be reached through a direct connection instead of through a proxy.
# Examples:
#   - localhost,127.0.0.1
#   - 10.0.*,*.example.com
#http_non_proxy_hosts =
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Disable the use of a native system stats collector (currently OSHI)
#disable_native_system_stats_collector = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# For some cluster-related REST requests, the node must query all other nodes in the cluster. This is the maximum number
# of threads available for this. Increase it, if '/cluster/*' requests take long to complete.
# Should be http_thread_pool_size * average_cluster_size if you have a high number of concurrent users.
#proxied_requests_thread_pool_size = 64
# The default HTTP call timeout for cluster-related REST requests. This timeout might be overriden for some
# resources in code or other configuration values. (some cluster metrics resources use a lower timeout)
#proxied_requests_default_call_timeout = 5s
# The server is writing processing status information to the database on a regular basis. This setting controls how
# often the data is written to the database.
# Default: 1s (cannot be less than 1s)
#processing_status_persist_interval = 1s
# Configures the threshold for detecting outdated processing status records. Any records that haven't been updated
# in the configured threshold will be ignored.
# Default: 1m (one minute)
#processing_status_update_threshold = 1m
# Configures the journal write rate threshold for selecting processing status records. Any records that have a lower
# one minute rate than the configured value might be ignored. (dependent on number of messages in the journal)
# Default: 1
#processing_status_journal_write_rate_threshold = 1
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = false
# The directory which contains content packs which should be loaded on the first start of Graylog.
# Default: <data_dir>/contentpacks
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
#content_packs_auto_install = grok-patterns.json
# The allowed TLS protocols for system wide TLS enabled servers. (e.g. message inputs, http interface)
# Setting this to an empty value, leaves it up to system libraries and the used JDK to chose a default.
# Default: TLSv1.2,TLSv1.3  (might be automatically adjusted to protocols supported by the JDK)
#enabled_tls_protocols = TLSv1.2,TLSv1.3
# Enable Prometheus exporter HTTP server.
# Default: false
#prometheus_exporter_enabled = false
# IP address and port for the Prometheus exporter HTTP server.
# Default: 127.0.0.1:9833
#prometheus_exporter_bind_address = 127.0.0.1:9833
# Path to the Prometheus exporter core mapping file. If this option is enabled, the full built-in core mapping is
# replaced with the mappings in this file.
# This file is monitored for changes and updates will be applied at runtime.
# Default: none
#prometheus_exporter_mapping_file_path_core = prometheus-exporter-mapping-core.yml
# Path to the Prometheus exporter custom mapping file. If this option is enabled, the mappings in this file are
# configured in addition to the built-in core mappings. The mappings in this file cannot overwrite any core mappings.
# Default: none
#prometheus_exporter_mapping_file_path_custom = prometheus-exporter-mapping-custom.yml
# Configures the refresh interval for the monitored Prometheus exporter mapping files.
# Default: 60s
#prometheus_exporter_mapping_file_refresh_interval = 60s
# An absolute path where scripts are permitted to be executed from.
integrations_scripts_dir = /usr/share/graylog-server/scripts
# Optional allowed paths for Graylog data files. If provided, certain operations in Graylog will only be permitted
# if the data file(s) are located in the specified paths (for example, with the CSV File lookup adapter).
# All subdirectories of indicated paths are allowed by default. This Provides an additional layer of security,
# and allows administrators to control where in the file system Graylog users can select files from.
#allowed_auxiliary_paths = /etc/graylog/data-files,/etc/custom-allowed-path
# Do not perform any preflight checks when starting Graylog
# Default: false
#skip_preflight_checks = false
# Ignore any exceptions encountered when running migrations
# Use with caution - skipping failing migrations may result in an inconsistent DB state.
# Default: false
#ignore_migration_failures = false
# Comma-separated list of notification types which should not emit a system event.
# Default: SIDECAR_STATUS_UNKNOWN which would create a new event whenever the status of a sidecar becomes "Unknown"
#system_event_excluded_types = SIDECAR_STATUS_UNKNOWN
# RSS settings for content stream
#content_stream_rss_url = https://www.graylog.org/post
#content_stream_refresh_interval = 7d
# Maximum value that can be set for an event limit.
# Default: 1000
#event_definition_max_event_limit = 1000
# Optional limits on scheduling concurrency by job type. No more than the specified number of worker
# threads will be executing jobs of the specified type across the entire cluster.
# Default: no limitation
# Note: Monitor job queue metrics to avoid excessive backlog of unprocessed jobs when using this setting!
# Available job types in Graylog Open:
#   check-for-cert-renewal-execution-v1
#   event-processor-execution-v1
#   notification-execution-v1
#job_scheduler_concurrency_limits = event-processor-execution-v1:2,notification-execution-v1:2
# The size of the thread pool that executes search jobs for indexed data. (Data Node/OpenSearch)
# WARNING: This configuration setting should only be changed if you are certain of what you are doing.
#          Modifying this setting without proper knowledge may lead to unexpected behavior or system
#          instability. Proceed with caution.
# Default: 4
#search_query_engine_indexer_jobs_pool_size = 4
# The queue size for the thread pool that executes search jobs for indexed data. (Data Node/OpenSearch)
# A value of "0" means that the queue is unbounded.
# Default: 0
#search_query_engine_indexer_jobs_queue_size = 0
# The size of the thread pool that executes search jobs for data in Data Lake.
# Default: 4
#search_query_engine_data_lake_jobs_pool_size = 4
# The queue size for the thread pool that executes search jobs for data in Data Lake.
# Default: 0
#search_query_engine_data_lake_jobs_queue_size = 0
Hey @Carl,
The Graylog server logs should give some indication, please share a sample containing the startup process.
Sorry had to create another account to reply for some reason.
here is sample of the log, it says it is waiting for MongoDB but the service is started and its logs look ok.
2026-02-13T08:00:17.825-05:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {default propert>
2026-02-13T08:00:19.409-05:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 7.0.4+ac94792 [org.graylog.aws.AWSPlugin]
2026-02-13T08:00:19.410-05:00 INFO  [CmdLineTool] Loaded plugin: Integrations 7.0.4+ac94792 [org.graylog.integrations.I>
2026-02-13T08:00:19.412-05:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 7.0.4+ac94792 [org.graylog.>
2026-02-13T08:00:19.413-05:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 7.0.4+ac94792 [org.graylog.sto>
2026-02-13T08:00:19.414-05:00 INFO  [CmdLineTool] Loaded plugin: OpenSearch 2 Support 7.0.4+ac94792 [org.graylog.storag>
2026-02-13T08:00:19.469-05:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms2g -Xmx2g -XX:+UseG1GC -XX:-OmitStack>
2026-02-13T08:00:19.891-05:00 INFO  [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, >
2026-02-13T08:00:19.896-05:00 INFO  [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, >
2026-02-13T08:00:19.920-05:00 INFO  [cluster] Exception in monitor thread while connecting to server localhost:27017
com.mongodb.MongoSocketOpenException: Exception opening socket
at com.mongodb.internal.connection.SocketStream.lambda$open$0(SocketStream.java:85)
at java.base/java.util.Optional.orElseThrow(Unknown Source)
at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:85)
at com.mongodb.internal.connection.InternalStreamConnection.open(InternalStreamConnection.java:233)
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitor.setupNewConnectionAndGetInitialDescriptio>
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitor.lookupServerDescription(DefaultServerMoni>
at com.mongodb.internal.connection.DefaultServerMonitor$ServerMonitor.run(DefaultServerMonitor.java:203)
Caused by: java.net.ConnectException: Connection refused
at java.base/sun.nio.ch.Net.pollConnect(Native Method)
at java.base/sun.nio.ch.Net.pollConnectNow(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.timedFinishConnect(Unknown Source)
at java.base/sun.nio.ch.NioSocketImpl.connect(Unknown Source)
at java.base/java.net.SocksSocketImpl.connect(Unknown Source)
at java.base/java.net.Socket.connect(Unknown Source)
at com.mongodb.internal.connection.SocketStreamHelper.initialize(SocketStreamHelper.java:76)
at com.mongodb.internal.connection.SocketStream.initializeSocket(SocketStream.java:104)
at com.mongodb.internal.connection.SocketStream.open(SocketStream.java:79)
… 4 more
2026-02-13T08:00:19.954-05:00 INFO  [cluster] Waiting for server to become available for operation { ping: 1 } with ID >
2026-02-13T08:00:49.939-05:00 INFO  [MongoDBPreflightCheck] MongoDB is not available. Retry #1
2026-02-13T08:00:51.940-05:00 INFO  [cluster] Waiting for server to become available for operation { ping: 1 } with ID >
2026-02-13T08:01:07.557-05:00 INFO  [ImmutableFeatureFlagsCollector] Following feature flags are used: {default propert>
2026-02-13T08:01:08.017-05:00 INFO  [CmdLineTool] Loaded plugin: AWS plugins 7.0.4+ac94792 [org.graylog.aws.AWSPlugin]
2026-02-13T08:01:08.018-05:00 INFO  [CmdLineTool] Loaded plugin: Integrations 7.0.4+ac94792 [org.graylog.integrations.I>
2026-02-13T08:01:08.018-05:00 INFO  [CmdLineTool] Loaded plugin: Threat Intelligence Plugin 7.0.4+ac94792 [org.graylog.>
2026-02-13T08:01:08.018-05:00 INFO  [CmdLineTool] Loaded plugin: Elasticsearch 7 Support 7.0.4+ac94792 [org.graylog.sto>
2026-02-13T08:01:08.020-05:00 INFO  [CmdLineTool] Loaded plugin: OpenSearch 2 Support 7.0.4+ac94792 [org.graylog.storag>
2026-02-13T08:01:08.031-05:00 INFO  [CmdLineTool] Running with JVM arguments: -Xms2g -Xmx2g -XX:+UseG1GC -XX:-OmitStack>
2026-02-13T08:01:08.182-05:00 INFO  [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, >
2026-02-13T08:01:08.184-05:00 INFO  [cluster] Exception in monitor thread while connecting to server localhost:27017
… 4 more
2026-02-13T08:01:08.185-05:00 INFO  [client] MongoClient with metadata {“driver”: {“name”: “mongo-java-driver|legacy”, >
2026-02-13T08:01:08.210-05:00 INFO  [cluster] Waiting for server to become available for operation { ping: 1 } with ID >
Within /etc/mongo.conf what interface/ip is mongo listening on? Your Graylog instance is expecting that to be localhost but if it’s not this can be altered
Hey Wine_Merchant
I had set the bindIp to the machines local address.
@Carl if Mongo is installed to the same node that Graylog is then you could bind to localhost or if you wanted it accessible externally then 0.0.0.0.
Within the server.conf update the below option accounting for authentication is enabled
mongodb_uri = mongodb://<Mongo Bind Address>:27017/graylog
@Wine_Merchant Thank you! I went back and checked that in the config and it was missing the port number for the mongo_uri. :man_facepalming:
In the server.log I no longer see the MongDB is not available message.
What I see now is:
026-02-17T08:23:38.439-05:00 ERROR [VersionProbe] Unable to retrieve version from indexer node: Failed to connect to /192.168.10.94:9200. - Connection refused.
This is an excerpt from the datanode.log
It seems you are starting Data node for the first time. The current configuration is not sufficient to
start the indexer process because a security configuration is missing. You have to either provide http
and transport SSL certificates or use the Graylog preflight interface to configure this Data node remotely.
2026-02-17T11:14:12.533-05:00 INFO  [JerseyService] Starting Data node REST API
2026-02-17T11:14:12.535-05:00 INFO  [DatanodeBootstrap] Services started, startup times in ms: {GracefulShutdownService>
2026-02-17T11:14:12.535-05:00 INFO  [DatanodeBootstrap] Graylog DataNode datanode up and running.
2026-02-17T11:14:13.180-05:00 INFO  [Version] HV000001: Hibernate Validator 9.0.1.Final
2026-02-17T11:14:13.526-05:00 INFO  [NetworkListener] Started listener bound to [0.0.0.0:8999]
2026-02-17T11:14:13.528-05:00 INFO  [HttpServer] [HttpServer] Started.
2026-02-17T11:14:13.528-05:00 INFO  [JerseyService] Started REST API at <0.0.0.0:8999>
This looks like the underlying Opensearch service that Data Node is a wrapper for has not started, upon startup of the Graylog node you should be prompted to generate certificates for the Data Node which it doesn’t seem has occurred.
Could you please comment out elasticsearch_hosts = http://192.168.10.94:9200 within the Graylog server.conf and then bounce the Graylog service, tail the log file to see next steps. If this fails, as you are at the beginning of the setup, you could drop the current Graylog Mongo DB instance for a fresh start.
@Wine_Merchant You are a gentleman and a scholar. I restarted after making that change and got the Graylog logo in the log with my temp password etc. I was able to start the setup created the certs the however the process did not complete. I had an unrelated issue I caused with my ubuntu install and decide to start fresh.
Fresh install following the doc and with what I learned in this post I got it running pretty quickly. Note that the install doc does not mention adding the mongodb port to the URI, while it should probably be self explanatory the previous hand holding the in the doc makes you assume each step mentioned is complete. Who ever updates that next may want to pop it in :slight_smile:
One thing I did differently this time was consistently define the local IP of my host not leaving any 0.0.0.0 or localhost references, the consistency made the install go more smoothly, in my case at least.
I am now configuring my inputs.
Thanks again for all the patients and assistance.
