i managed to uninstall the Threat inteligence Plugin ā file is existing on the server in the Plugin folder.
When i restart the server of restart the the plugin is not reinstalling?
What is the correct way to get it back?
also as info i have clicked under System - Content Packs - delete all versions
I have installed a new instace and extracted the json files
Hello && Welcome
There is an easier way to get plugins back.
sudo apt-get install graylog-integrations-plugin
Thanks for this info
