Hi everyone, I hope you are well.
I’m newbie with Graylog and I made a mistake that I’d like to fix it.
Specifically, I’ve uninstalled the Alien Vault - Open Threat Exchange (OTX) plugin / content pack and so far, I couldn’t install again.
I’ve been Googling and trying to reinstall a version that I found in Github but I wasn’t successful.
Thank you for your response. I’m using Graylog 4.3.5 and you are right to assume that (default content pack).
I’ve already reinstalled “graylog-integrations-plugins” and “graylog-server” and it didn’t work.
EDIT: Since this is a issue on a default Content pack installation, I moved this post to Graylog Central Category. In your configuration section → System/Configurations scroll down and enable it?
hi @gsmith,
It is odd as you say. I’ve already reinstalled “graylog-integrations-plugins” and “graylog-server” directly and with Graylog service stopped.
The OS is Ubuntu 22.04.1 LTS + Graylog 4.3.5+32fa802 and there are installed the following packages related top GL:
graylog-4.3-repository/stable,now 1-5 all [installed]
