Graylog Enterprise LicenseChecker
Hi all,
My test installation is complaining about “Graylog Enterprise License Violation”:
2018-02-13T13:25:54.072+01:00 WARN  [LicenseReportPeriodical] Unable to connect to license server: Verbindungsaufbau abgelehnt (Connection refused).
2018-02-13T13:30:53.846+01:00 WARN  [LicenseChecker] License violation - Failed to report license status to Graylog, Inc. - consecutive failures: 73, limit: 72
What URL is it trying to connect to? Can I configure proxy settings somewhere for the LicenseChecker?
Regards,
Daniel
If settings http_proxy_uri in the Graylog configuration file doesn’t work. try setting the http.proxyHost/http.proxyPort and https.proxyHost/https.proxyPort system properties in the JVM settings of your Graylog installation.
you could set the proxy in your server.conf
the URL that is requested is https://api.graylog.com/report
regards
Jan
Thanks for the quick response guys :slight_smile:
I have to use basic auth for the proxy so I didn’t get it working via the http_proxy_uri in the server.conf. Is there a special format to use when proxy-basic-auth is required?
I added th following default java options for the JVM:
GRAYLOG_SERVER_JAVA_OPTS="... -Djdk.http.auth.tunneling.disabledSchemes= -Dhttp.proxyUser=user -Dhttp.proxyPassword=password -Dhttp.proxyHost=myproxy -Dhttp.proxyPort=8080 -Dhttps.proxyUser=user -Dhttps.proxyPassword=password -Dhttps.proxyHost=myproxy -Dhttps.proxyPort=8080"
But I still keep getting:
2018-02-13T21:38:56.046+01:00 WARN  [LicenseReportPeriodical] Unable to connect to license server: Failed to authenticate with proxy.
2018-02-13T21:43:55.889+01:00 WARN  [LicenseChecker] License violation - Failed to report license status to Graylog, Inc. - consecutive failures: 85, limit: 72
Does anyone else have an idea what I can change so that the communication via the proxy works? yum for example works flawlessly over the proxy.
Any help appreciated :blush:
Please create a bug report at https://github.com/Graylog2/graylog2-server/issues if the proxy settings aren’t working for you.
Thanks Jochen. I created a corresponding bug report
https://github.com/Graylog2/graylog2-server/issues/4594
