I’ve configured the GeoIp resolver as documented here using MaxMind’s cities and ASNs databases.
Graylog doesn’t create the expected geolocation fields.
OS Information: Alpine Linux 3.20, Docker 26.1.3
Package Version: Graylog Enterprise 6, Graylog Datanode 6, running on docker-compose
- Configured the settings as in the screenshot.
- Copied the 2 database files in the right folder
- Set fields src-ip and dst-ip in index as IP type
- Checked docker logs
Provide steps to troubleshoot the problem.
