Geolocation not working
I have exactly followed official document, but there shows no fields generated
I want to analyse source ip on world map,
like this my message has certain ip address field
followed document
If document is not enough what should I do?
let me fix this plz
Which document? This one here? you don’t show the IP broken out into a separate field…
Hello @ushiii111798
I concur with @tmacgbay perhaps some more information on what/how this was configured. The documentation that was used, etc… Help us, help you :+1:
gl2_source_ip contains IP address. And the link is exactly the one I followed
The official document from graylog homepage.
Graylog doesn’t automatically pull the IP address out of the message, you need to either use Extractors or functions in the pipeline to do that. Once it is extracted to a separate field then its possible to geolocation going.
Other that saying that you followed documentation, you are not giving us that much information to help you… I would suggest reading through This document and/or this document to figure out how to give relevant information when asking a question and even showing your work for what you have tried. The net result would be more complete answers that may help you achieve your goal faster…
