Geolocation (again) problems
After setting up the geolocation processor as in Geolocation, and adding an extractor for the IIS logs to have a field (called source_ip), I still cannot find the geolocation fields to use.
  • OS Information:
Distributor ID: Ubuntu
Description: Ubuntu 20.04.5 LTS
Release: 20.04
Codename: focal
  • Package Version:
    Graylog 4.3.9+e2c6648 on graylog01 (Private Build 17.0.4 on Linux 5.4.0-131-generic)
ii elasticsearch-oss 7.10.2 amd64 Distributed RESTful search engine built for the cloud
ic graylog-4.2-repository 1-4 all Package to install Graylog 4.2 GPG key and repository
ii graylog-4.3-repository 1-6 all Package to install Graylog 4.3 GPG key and repository
ii graylog-enterprise-integrations-plugins 4.3.9-1 all Graylog Enterprise Integrations plugins
ii graylog-enterprise-plugins 4.3.9-1 amd64 Graylog Enterprise plugins
ii graylog-integrations-plugins 4.3.9-1 all Graylog Integrations plugins
ii graylog-server 4.3.9-1 all Graylog server
ii mongodb-org 4.0.28 amd64 MongoDB open source document-oriented database system (metapackage)
ii mongodb-org-mongos 4.0.28 amd64 MongoDB sharded cluster query router
ii mongodb-org-server 4.0.28 amd64 MongoDB database server
ii mongodb-org-shell 4.0.28 amd64 MongoDB shell client
ii mongodb-org-tools 4.0.28 amd64 MongoDB tools
cat /etc/graylog/server/server.conf | egrep -v “^\s*(#|$)”
is_master = true
password_secret = xxx
root_password_sha2 = xxx
root_timezone = America/New_York
http_bind_address = 10.0.0.55:9000
http_external_uri = https://logs.domain.com/
http_enable_cors = true
rotation_strategy = count
retention_strategy = delete
elasticsearch_shards = 4
elasticsearch_replicas = 0
allow_highlighting = false
output_batch_size = 500
output_flush_interval = 1
processbuffer_processors = 5
outputbuffer_processors = 3
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
path.data: /var/lib/elasticsearch
path.logs: /var/log/elasticsearch
cluster.name: graylog
  • I upgraded from 4.2 to the latest 4.3.9 and followed the instructions at Geolocation
  • Old topic Geolocation not working tried to cover the same problem but no solution was posted
  • Older topics use a different way of adding geolocation fields to log entries using lookup tables, but it was not described in the instructions, so I assumed it is no longer valid for v3.5.9
Please share/advise what can be wrong
Hello @mhammady
Is it possible to show the GeoIP configuration ( i.e. Pipeline, data table , etc…) made and perhaps a sample of the logs?
Also post your Message Processors Configuration (system/Configurations) as well as your Geo-Location Processor setting on the same page.
I think this is one where you want the Message Filter Chain to come before the Pipeline Processor…
@gsmith & @tmacgbay
Thank you for your response. I didn’t create any pipeline or LUT… It was not mentioned in the Geolocation document!!!
In fact, the 1st paragraph on the geolocation using pipeline and LUTs document mentions “Geolocation can be automatically built into the Graylog platform by using the “GeoIP Resolver” plugin with a MaxMind database. However, you can further improve your ability to extract meaningful and useful data by leveraging the functionality of pipelines and lookup tables”, so I was expecting that by setting up only the geolocation processor, it will be able to create the geolocation fields automatically without the need of adding additional pipelines or LUTs…
Was I mistaken in this assumption? Shall I follow Implementing Geolocation with Graylog Pipelines - Graylog or How to Set Up Graylog GeoIP Configuration - Graylog instructions and disregard the Geo-Location Processor plugin?
My Message Processors Configuration:
My Geo-Location Processor:
Message Filter Chain should be before Pipeline Processor.
Hi @gsmith, I just tried that but I still cannot see the geolocation fields. please note that I removed the enterprise add-ons as it was giving many log errors caused by lack of license.
My current Message Processors Configuration is as follows:
hey,
It may take a few minutes, but that what does need to happen when using pipelines.
Can you post you pipeline/rule?
@gsmith , As I mentioned earlier, I didn’t create a pipeline or LUTs. As the geolocation document mentioned, I just added the processor plugin information. Also, I added a message extractor to the input to make sure that there will be a valid IP field (I named it source_ip) to be used for geolocation…
hey @mhammady
Have a look here, this may help.
EDIT: here is mine.
Thank you @gsmith
I’m familiar with this technique, but I was hoping that I can use the GeoIP addon as is… this document does not depend on the addon, it creates a LUT to be used in a pipeline. I appreciate you sharing your configuration though… I shall disable the Geolocation plugin and start building the LUT and its pipeline…
Thanks again for your help
Hey,
:+1:
Its probably for the better. I understand the plugin is easier but later on if you upgrade it may not work. This way if you build it, it should stay working without any problems. My setup went through GL version 2.5 thru 4.3 and its still working good.
Hi @gsmith
I did create the LUts and the pipeline, but I’m getting this in the /var/log/graylog-server/server.log
WARN [LookupTableService] Lookup table < geoip > does not exist
The new fields are not added, so I assume it is related to this error.
Of course, I downloaded the latest MaxMind lite (free) DBs and added them to the /etc/graylog/server/
Server restart didn’t solve this problem…
Any idea why this is happening?
hey,
You need to create the lookup tables , what direction are you using?
Thanks for the quick reply. I created the lookup table as follows…
Ok i tested this against mine, Not sure if this will help ya. but here is where i seen different settings
Data adapter file path
/usr/share/elasticsearch/modules/ingest-geoip/GeoLite2-City.mmdb
You cache is same as mine
Perhaps match the table correctly.
Reason I stated this was from this error
@mhammady
If you created a piepline like this…
rule "GeoIP lookup: srcip"
  has_field("somefield")
let geo = lookup("geoip", to_string($message.srcip));
 set_field("src_ip_geo_location", geo["coordinates"]);
 set_field("src_ip_geo_country", geo["country"].iso_code);
 set_field("src_ip_geo_city", geo["city"].names.en);
 debug(geo);
Make sure the correct naming convention is the same.
Specially this part, noticed it states "geoip "
hi @mhammady
how did you pull the public ip to the logs?
i followed the same steps (pipeline rules adapter lookup table…) but why is my ip address private? can you help?
@er213 this log is for IIS. If I understood your question correctly, your problem is showing the real IP in the IIS log, then you need to add the X-Forwarded-For as a custom field in IIS. This has nothing to do with Graylog
Hi @gsmith … Thank you SO MUCH for your help. It worked now for me. The problem was in the name of the LUT. In all examples it was geoip, but when I created it, I created the table with the name GeoIPtbl
All what I needed to do is to update my lookup line to be
let geo = lookup("GeoIPtbl", to_string($message.source_ip));
how can i do this, I’m new to networking, can you help @mhammady
