Graylog / ElasticSearch Index Error - Graylog Dead
how can I identify the “problem messages” or find the messages?
the input which I have identified with some playing around (starting and stoping) should be the GELF input TCP, but I don’t can’t find the problem messages, if i check “show received messages”. there are also no empty messages dropped.
it also looks like as the problem messages can’t be many. the input receives about 200 to 12.000 messages per sec and only shows every few seconds a problem within parsin.
I’ve tried to idenitfy the problem messages via the Letter-ID (example: e1d09650-371311e8-a23f-f403433d1b68) and the graylog-api browser "Messages: Single Messages / /message/§index}/§messageid} but always got the error, that he couldn’t find it.
“type”: “ApiError”,
“message”: “Message 1193e9a6-3714-11e8-a23f-f403433d1b68 does not exist in index graylog_144”
Is there any way to do the following tasks:
  1. verify the input, where the problem messages are received
  2. identifiy the problem messages within graylog-GUI or REST-API
  3. Show connected Clients on GELF Input (only X connections are active is shown, but not which exactly)
I still have also the problem with the “wrong graylog-pipeline-processor-plugin”. on the filesystem it is shown as version 2.4.3 (like graylog), but in the GUI, Database etc it is shown as 2.2.0 and I still face java parsing errors.
    at org.graylog2.syslog4j.server.impl.event.CiscoSyslogServerEvent.<init>(CiscoSyslogServerEvent.java:37) ~[graylog.jar:?]
    at org.graylog2.inputs.codecs.SyslogCodec.parse(SyslogCodec.java:128) ~[graylog.jar:?]
    at org.graylog2.inputs.codecs.SyslogCodec.decode(SyslogCodec.java:96) ~[graylog.jar:?]
    at org.graylog2.shared.buffers.processors.DecodingProcessor.processMessage(DecodingProcessor.java:150) ~[graylog.jar:?]
    at org.graylog2.shared.buffers.processors.DecodingProcessor.onEvent(DecodingProcessor.java:91) [graylog.jar:?]
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:74) [graylog.jar:?]
    at org.graylog2.shared.buffers.processors.ProcessBufferProcessor.onEvent(ProcessBufferProcessor.java:42) [graylog.jar:?]
    at java.lang.Thread.run(Thread.java:748) [?:1.8.0_151]
any idea with the graylog-processor-pipeline or java-errors?
how can I see the error messages?
can I please get an Info, how I can identify the Problem messages?
