Graylog + elastic + kibana same machine
In my central log collection system I’m already deployed Elasticsearch and Kibana and it’s been feeded by syslog-ng using http destination. It is working fine, but I would like to give a chance to test Graylog as well. Do you think Graylog can be installed on the same server (CentOS 7) where Elastic/Kibana is running? I don’t care about the performance, my question regards to the compatibility of the two products
Laszlo
yes - it is possible.
Let me add something. Yes, it is possible only if you are running a very old version of ES, so it is not really possible. Finally I’ve installed on a separated machine
