Hi Team, I have a quick question regarding Graylog…is it possible to scaleup or scale down server size dynamically in graylog ?
Hello && Welcome
Yes you can.
What do you mean scaling down dynamically?
Are you referring to the scaling down from a cluster to one node? if so, yes you can.
@gsmith thanks for the reply…what would be the approach to scale down to one node? (I’m a newbie to graylog)
++ can we reduce instance size/type dynamically? if so…any sources/links to follow
Just a side note, I have down scaled my 6 node cluster before. It was tricky because that I didn’t lose all my data/indices from Elasticsearch. After that it was more reconfiguring my Graylog configuration files and MongoDb configuration file. Good luck
EDIT:
Yes you can.
as for links and resource not that I know of. They mostly up scale environments. Maybe another community member might jump in.
I did a quick search and found this.
