We are planning to scale down our existing graylog environment to a smaller cluster as we are phasing out of Graylog. In order to do so, are there any standard guidelines to be followed? Is even scaling down a graylog + elasticsearch cluster possible?
gsmith
(GSmith)
November 12, 2021, 5:40am
#2
Hello && Welcome
Here is a post that a community member executed to reduce there cluster.
How can I configure graylog in a single node? . Graylog was working as a 2 node cluster (was like that when I arrived this company) but now for reducing cloud cost I have to use only one server. Cluster had a public LB ip and the 2 nodes added. Now I remove one of the nodes and changed the configuration of graylog as follow: I just remove the other node IP form mongo and elastic search configuration and left the rest as it was.
# GRAYLOG CONFIGURATION FILE
hope that helps
system
(system)
Closed
November 26, 2021, 5:41am
#3
