Graylog doesn't process messages
My graylog stopped processing messages completely and all the buffers are on 0%.
Tried deleting the disk journal and it didn’t change anything.
Using graylog v3.3.5
Was wondering if there was a fix for it or just a way to import the old data on a freshly installed graylog server
Did you check the logs for either graylog or elasticsearch?
just deleting things for the sake of deleting things is bound to cause more problems than it fixes.
Is your journal filling back up? have you stopped and started graylog? are you sure the messages are reaching the server?
