This is my docker-compose file and it is working with Traefik. Inputs of graylog are : GelfTCP - gelfUdp -syslogUDP- syslogTCP.
It is working with Syslog, not Gelf. I also change the timezone of my VMs to Europe.
I also use this command for sending logs from one of my VMs to another one which graylog and traefik are working on it:
echo -n -e ‘{ “version”: “1.1”, “host”: “example.org”, “short_message”: “A short message”, “level”: 5, “_some_info”: “foo” }’"\0" | nc -u -w0 X 12201
Docker-compose file
version: '3.7'
services:
image: mongo:4
volumes:
- /mnt/Ubuntu/mongo:/data/db
environment:
- TZ=Europe/Berlin
networks:
- internal
# Elasticsearch: https://www.elastic.co/guide/en/elasticsearch/reference/6.x/docker.html
elasticsearch:
image: docker.elastic.co/elasticsearch/elasticsearch-oss:7.10.0
volumes:
- elastic:/usr/share/elasticsearch/data
environment:
- http.host=0.0.0.0
- transport.host=localhost
- network.host=0.0.0.0
- TZ=Europe/Berlin
ulimits:
memlock:
soft: -1
hard: -1
networks:
- internal
graylog:
image: graylog/graylog:4.0
volumes:
- /mnt/Ubuntu/graylog/data:/usr/share/graylog/data
- /mnt/Ubuntu/graylog/config:/usr/share/graylog/data/config
environment:
- GRAYLOG_PASSWORD_SECRET= X
- GRAYLOG_ROOT_PASSWORD_SHA2= X
- GRAYLOG_HTTP_EXTERNAL_URI= X
- TZ=Europe/Berlin
restart: always
depends_on:
- mongodb
- elasticsearch
deploy:
labels:
#http
- traefik.http.routers.graylog.service=graylog-svc
- traefik.http.routers.graylog.rule=Host("")
- traefik.http.services.graylog-svc.loadbalancer.server.port=9000
- traefik.http.routers.graylog.entrypoints= web,websecure
#tls
- traefik.http.routers.graylog.tls=true
- traefik.http.routers.graylog.tls.certresolver=le
#tcp
- traefik.tcp.routers.graylogtcp.entrypoints= syslogtcp
- traefik.tcp.routers.graylogtcp.service=graylogtcp-svc
- traefik.tcp.services.graylogtcp-svc.loadbalancer.server.port=1514
- traefik.tcp.routers.graylogtcp.rule=HostSNI(`*`)
#udp
- traefik.udp.routers.graylogudp.service=graylogudp-svc
- traefik.udp.routers.graylogudp.entrypoints= syslogudp
- traefik.udp.services.graylogudp-svc.loadbalancer.server.port=1514/udp
#GELF TCP
- traefik.tcp.routers.grayloggelftcp.rule=HostSNI(`*`)
- traefik.tcp.routers.grayloggelftcp.service=grayloggelftcp-svc
- traefik.tcp.routers.grayloggelftcp.entrypoints= gelftcp
- traefik.tcp.services.grayloggelftcp-svc.loadbalancer.server.port=12201
#GELF UDP
- traefik.udp.routers.grayloggelfudp.service=grayloggelfudp-svc
- traefik.udp.routers.grayloggelfudp.entrypoints= gelfudp
- traefik.udp.services.grayloggelfudp-svc.loadbalancer.server.port=12201/udp
- traefik.enable=true
- traefik.docker.network=public
- traefik.docker.network=internal
- traefik.http.routers.graylog.middlewares=graylog-header
- traefik.http.middlewares.graylog-header.headers.customrequestheaders.X-Graylog-Server-URL= X
- traefik.http.middlewares.graylog-header.headers.customresponseheaders.X-Graylog-Server-URL= X
# Volumes for persisting data, see https://docs.docker.com/engine/admin/volumes/volumes/
networks:
- public
- internal
networks:
internal:
external: true
public:
external: true
volumes:
elastic:
external: true
and this is my Traefik yml file:
version: '3.3'
services:
traefik:
image: traefik:v2.3
ports:
- 443:443
- 80:80
- 9000:9000
- 1514:1514
- 1514:1514/udp
- 12201:12021
- 12201:12201/udp
volumes:
- letsencrypt-certificates:/letsencrypt-certificates/
networks:
- internal
- public
command:
- --entrypoints.web.address=:80
- --entrypoints.websecure.address=:443
- --entrypoints.graylogweb.address=:9000
- --entrypoints.syslogtcp.address=:1514
- --entrypoints.syslogudp.address=:1514/udp
- --entrypoints.gelftcp.address=:12201
- --entrypoints.gelfudp.address=:12201/udp
- --providers.docker
- --providers.docker.swarmMode=true
- --providers.docker.endpoint=tcp://tasks.docker-socket-proxy:2375 #make secure tasks.[servicename]:[port]
- --providers.docker.exposedbydefault=false
- --api
- --certificatesResolvers.le.acme.email= X
- --certificatesResolvers.le.acme.storage=/letsencrypt-certificates/acme.json
- --certificatesResolvers.le.acme.tlsChallenge=true
deploy:
labels:
- traefik.http.middlewares.admin.basicauth.users=X
- traefik.http.middlewares.redirect-to-https.redirectscheme.scheme=https
- traefik.http.routers.force-https.rule=hostregexp(`{host:.+}`)
- traefik.http.routers.force-https.entrypoints=web
- traefik.http.routers.force-https.middlewares=redirect-to-https
# Traefik dashboard
- traefik.http.routers.traefik.rule=Host(" ")
- traefik.http.routers.traefik.service=api@internal
- traefik.http.routers.traefik.entrypoints=websecure
- traefik.http.routers.traefik.tls.certresolver=le
- traefik.http.routers.traefik.middlewares=admin
- traefik.http.services.traefik.loadbalancer.server.port=8080
image: tecnativa/docker-socket-proxy
hostname: docker-socket-proxy
environment:
- CONTAINERS=1
- NETWORKS=1
- SERVICES=1
- SWARM=1
- TASKS=1
volumes:
- /var/run/docker.sock:/var/run/docker.sock:ro
networks:
- internal
deploy:
resources:
limits:
cpus: '1'
memory: 500M
mode: replicated
replicas: 1
volumes:
networks:
internal:
external: true
public:
external: true
