Graylog Dashboard Metadata in MongoDb
All,
Graylog’s dashboards metadata in MongoDb is not showing on my instance. The Graylog server has been upgraded since version 1.3 never had any real issues. Today I was in the process of querying some metadata in mongo and came across empties Documents.
First, here is a screen shot of my dashboards on the Web UI (some not all).
Next, let’s log into Mongo shell.
[root@graylog mongo]#  mongo --port 27017 -u username -p 'some_password'
MongoDB shell version v4.4.15
connecting to: mongodb://127.0.0.1:27017/?compressors=disabled&gssapiServiceName=mongodb
Implicit session: session { "id" : UUID("57bec8d4-6685-4f80-b775-200341ee6d41") }
MongoDB server version: 4.4.15
The server generated these startup warnings when booting:
        2022-07-29T20:24:14.175-05:00: You are running on a NUMA machine. We suggest launching mongod like this to avoid performance problems: numactl --interleave=all mongod [other options]
mongo > show databases;
admin    0.000GB
config   0.000GB
graylog  0.034GB
local    0.000GB
test     0.000GB
mongo > use graylog
switched to db graylog
Now I will list the collections, Looking for dashboards.
mongo > show collections
access_tokens
alarmcallbackconfigurations
alarmcallbackhistory
alerts
archive_backends
archive_catalog
audit_log
auth_service_backends
cluster_config
cluster_events
collector_configurations
collectors
content_packs
content_packs_installations
dashboards
decorators
event_definitions
event_notification_status
event_notifications
event_processor_state
export_jobs
forwarder_input_profiles
forwarder_input_states
forwarders
grants
graylog
grok_patterns
index_failures
index_field_types
index_ranges
index_sets
inputs
ldap_settings
licenses
lut_caches
lut_data_adapters
lut_mongodb_data_adapter
lut_tables
nodes
notifications
opensearch_anomaly_detectors
outputs
pipeline_processor_pipelines
pipeline_processor_pipelines_streams
pipeline_processor_rules
processing_status
roles
saved_searches
scheduler_job_definitions
scheduler_triggers
searches
security_views
sessions
sidecar_collector_actions
sidecar_collectors
sidecar_configuration_variables
sidecar_configurations
sidecars
streamrules
streams
system.profile
system_messages
team_sync_backend_configs
teams
traffic
users
view_sharings
views
Now lets see all the dashboard metadata in Mongo :smiley:
As you can see from the screenshot there is none, :thinking:
Not sure what’s going on.
What I have tried was restarting MongoDb, Graylog service hoping this would populate the metadata, No Joy.
Executed the following command, No Joy.
sudo mongod --repair --dbpath /var/lib/mongo
Even rebooted the server, No Joy
Here is the log file for MongoDb after restarting service.
MongoDb_Logs
{"t":{"$date":"2022-07-29T21:10:02.668-05:00"},"s":"I",  "c":"CONTROL",  "id":23285,   "ctx":"main","msg":"Automatically disabling TLS 1.0, to force-enable TLS 1.0 specify --sslDisabledProtocols 'none'"}
{"t":{"$date":"2022-07-29T21:10:02.680-05:00"},"s":"W",  "c":"ASIO",     "id":22601,   "ctx":"main","msg":"No TransportLayer configured during NetworkInterface startup"}
{"t":{"$date":"2022-07-29T21:10:02.681-05:00"},"s":"I",  "c":"NETWORK",  "id":4648601, "ctx":"main","msg":"Implicit TCP FastOpen unavailable. If TCP FastOpen is required, set tcpFastOpenServer, tcpFastOpenClient, and tcpFastOpenQueueSize."}
{"t":{"$date":"2022-07-29T21:10:02.682-05:00"},"s":"I",  "c":"STORAGE",  "id":4615611, "ctx":"initandlisten","msg":"MongoDB starting","attr":{"pid":92877,"port":27017,"dbPath":"/var/lib/mongo","architecture":"64-bit","host":"graylog.enseva-labs.net"}}
{"t":{"$date":"2022-07-29T21:10:02.683-05:00"},"s":"I",  "c":"CONTROL",  "id":23403,   "ctx":"initandlisten","msg":"Build Info","attr":{"buildInfo":{"version":"4.4.15","gitVersion":"bc17cf2c788c5dda2801a090ea79da5ff7d5fac9","openSSLVersion":"OpenSSL 1.0.1e-fips 11 Feb 2013","modules":[],"allocator":"tcmalloc","environment":{"distmod":"rhel70","distarch":"x86_64","target_arch":"x86_64"}}}}
{"t":{"$date":"2022-07-29T21:10:02.683-05:00"},"s":"I",  "c":"CONTROL",  "id":51765,   "ctx":"initandlisten","msg":"Operating System","attr":{"os":{"name":"CentOS Linux release 7.9.2009 (Core)","version":"Kernel 3.10.0-1160.71.1.el7.x86_64"}}}
{"t":{"$date":"2022-07-29T21:10:02.683-05:00"},"s":"I",  "c":"CONTROL",  "id":21951,   "ctx":"initandlisten","msg":"Options set by command line","attr":{"options":{"config":"/etc/mongod.conf","net":{"bindIp":"127.0.0.1","port":27017},"operationProfiling":{"mode":"all","slowOpThresholdMs":5},"processManagement":{"fork":true,"pidFilePath":"/var/run/mongodb/mongod.pid"},"security":{"authorization":"enabled"},"storage":{"dbPath":"/var/lib/mongo","journal":{"enabled":true}},"systemLog":{"destination":"file","logAppend":true,"path":"/var/log/mongodb/mongod.log"}}}}
{"t":{"$date":"2022-07-29T21:10:02.686-05:00"},"s":"I",  "c":"STORAGE",  "id":22270,   "ctx":"initandlisten","msg":"Storage engine to use detected by data files","attr":{"dbpath":"/var/lib/mongo","storageEngine":"wiredTiger"}}
{"t":{"$date":"2022-07-29T21:10:02.686-05:00"},"s":"I",  "c":"STORAGE",  "id":22315,   "ctx":"initandlisten","msg":"Opening WiredTiger","attr":{"config":"create,cache_size=5263M,session_max=33000,eviction=(threads_min=4,threads_max=4),config_base=false,statistics=(fast),log=(enabled=true,archive=true,path=journal,compressor=snappy),file_manager=(close_idle_time=100000,close_scan_interval=10,close_handle_minimum=250),statistics_log=(wait=0),verbose=[recovery_progress,checkpoint_progress,compact_progress],"}}
{"t":{"$date":"2022-07-29T21:10:03.675-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147003:675785][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY_PROGRESS] Recovering log 5723 through 5724"}}
{"t":{"$date":"2022-07-29T21:10:03.696-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147003:696519][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY_PROGRESS] Recovering log 5724 through 5724"}}
{"t":{"$date":"2022-07-29T21:10:03.889-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147003:889576][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY | WT_VERB_RECOVERY_PROGRESS] Main recovery loop: starting at 5723/91741184 to 5724/256"}}
{"t":{"$date":"2022-07-29T21:10:03.986-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147003:986868][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY_PROGRESS] Recovering log 5723 through 5724"}}
{"t":{"$date":"2022-07-29T21:10:04.004-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147004:4645][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY_PROGRESS] Recovering log 5724 through 5724"}}
{"t":{"$date":"2022-07-29T21:10:04.096-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147004:96780][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY | WT_VERB_RECOVERY_PROGRESS] Set global recovery timestamp: (0, 0)"}}
{"t":{"$date":"2022-07-29T21:10:04.096-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147004:96904][92877:0x7fcc548b8bc0], txn-recover: [WT_VERB_RECOVERY | WT_VERB_RECOVERY_PROGRESS] Set global oldest timestamp: (0, 0)"}}
{"t":{"$date":"2022-07-29T21:10:04.124-05:00"},"s":"I",  "c":"STORAGE",  "id":22430,   "ctx":"initandlisten","msg":"WiredTiger message","attr":{"message":"[1659147004:124074][92877:0x7fcc548b8bc0], WT_SESSION.checkpoint: [WT_VERB_CHECKPOINT_PROGRESS] saving checkpoint snapshot min: 1, snapshot max: 1 snapshot count: 0, oldest timestamp: (0, 0) , meta checkpoint timestamp: (0, 0) base write gen: 20820946"}}
{"t":{"$date":"2022-07-29T21:10:04.266-05:00"},"s":"I",  "c":"STORAGE",  "id":4795906, "ctx":"initandlisten","msg":"WiredTiger opened","attr":{"durationMillis":1580}}
{"t":{"$date":"2022-07-29T21:10:04.267-05:00"},"s":"I",  "c":"RECOVERY", "id":23987,   "ctx":"initandlisten","msg":"WiredTiger recoveryTimestamp","attr":{"recoveryTimestamp":{"$timestamp":{"t":0,"i":0}}}}
{"t":{"$date":"2022-07-29T21:10:04.270-05:00"},"s":"I",  "c":"STORAGE",  "id":4366408, "ctx":"initandlisten","msg":"No table logging settings modifications are required for existing WiredTiger tables","attr":{"loggingEnabled":true}}
{"t":{"$date":"2022-07-29T21:10:04.279-05:00"},"s":"I",  "c":"STORAGE",  "id":22262,   "ctx":"initandlisten","msg":"Timestamp monitor starting"}
{"t":{"$date":"2022-07-29T21:10:04.332-05:00"},"s":"W",  "c":"CONTROL",  "id":22167,   "ctx":"initandlisten","msg":"You are running on a NUMA machine. We suggest launching mongod like this to avoid performance problems: numactl --interleave=all mongod [other options]","tags":["startupWarnings"]}
{"t":{"$date":"2022-07-29T21:10:04.375-05:00"},"s":"I",  "c":"STORAGE",  "id":20536,   "ctx":"initandlisten","msg":"Flow Control is enabled on this deployment"}
{"t":{"$date":"2022-07-29T21:10:04.387-05:00"},"s":"I",  "c":"FTDC",     "id":20625,   "ctx":"initandlisten","msg":"Initializing full-time diagnostic data capture","attr":{"dataDirectory":"/var/lib/mongo/diagnostic.data"}}
{"t":{"$date":"2022-07-29T21:10:04.388-05:00"},"s":"I",  "c":"REPL",     "id":6015317, "ctx":"initandlisten","msg":"Setting new configuration state","attr":{"newState":"ConfigReplicationDisabled","oldState":"ConfigPreStart"}}
{"t":{"$date":"2022-07-29T21:10:04.392-05:00"},"s":"I",  "c":"NETWORK",  "id":23015,   "ctx":"listener","msg":"Listening on","attr":{"address":"/tmp/mongodb-27017.sock"}}
{"t":{"$date":"2022-07-29T21:10:04.392-05:00"},"s":"I",  "c":"NETWORK",  "id":23015,   "ctx":"listener","msg":"Listening on","attr":{"address":"127.0.0.1"}}
{"t":{"$date":"2022-07-29T21:10:04.392-05:00"},"s":"I",  "c":"NETWORK",  "id":23016,   "ctx":"listener","msg":"Waiting for connections","attr":{"port":27017,"ssl":"off"}}
{"t":{"$date":"2022-07-29T21:10:04.643-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50146","connectionId":1,"connectionCount":1}}
{"t":{"$date":"2022-07-29T21:10:04.647-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn1","msg":"client metadata","attr":{"remote":"127.0.0.1:50146","client":"conn1","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.654-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50148","connectionId":2,"connectionCount":2}}
{"t":{"$date":"2022-07-29T21:10:04.654-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50150","connectionId":3,"connectionCount":3}}
{"t":{"$date":"2022-07-29T21:10:04.655-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn2","msg":"client metadata","attr":{"remote":"127.0.0.1:50148","client":"conn2","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.655-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50152","connectionId":4,"connectionCount":4}}
{"t":{"$date":"2022-07-29T21:10:04.655-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn3","msg":"client metadata","attr":{"remote":"127.0.0.1:50150","client":"conn3","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.655-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50154","connectionId":5,"connectionCount":5}}
{"t":{"$date":"2022-07-29T21:10:04.656-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50156","connectionId":6,"connectionCount":6}}
{"t":{"$date":"2022-07-29T21:10:04.656-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn4","msg":"client metadata","attr":{"remote":"127.0.0.1:50152","client":"conn4","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.656-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50158","connectionId":7,"connectionCount":7}}
{"t":{"$date":"2022-07-29T21:10:04.656-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn6","msg":"client metadata","attr":{"remote":"127.0.0.1:50156","client":"conn6","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.657-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn5","msg":"client metadata","attr":{"remote":"127.0.0.1:50154","client":"conn5","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.657-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50160","connectionId":8,"connectionCount":8}}
{"t":{"$date":"2022-07-29T21:10:04.657-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn7","msg":"client metadata","attr":{"remote":"127.0.0.1:50158","client":"conn7","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.657-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn8","msg":"client metadata","attr":{"remote":"127.0.0.1:50160","client":"conn8","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.665-05:00"},"s":"I",  "c":"NETWORK",  "id":22943,   "ctx":"listener","msg":"Connection accepted","attr":{"remote":"127.0.0.1:50162","connectionId":9,"connectionCount":9}}
{"t":{"$date":"2022-07-29T21:10:04.666-05:00"},"s":"I",  "c":"NETWORK",  "id":51800,   "ctx":"conn9","msg":"client metadata","attr":{"remote":"127.0.0.1:50162","client":"conn9","doc":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"}}}
{"t":{"$date":"2022-07-29T21:10:04.667-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn8","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":9}}
{"t":{"$date":"2022-07-29T21:10:04.667-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn3","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":12}}
{"t":{"$date":"2022-07-29T21:10:04.667-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn2","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":12}}
{"t":{"$date":"2022-07-29T21:10:04.667-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn7","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":10}}
{"t":{"$date":"2022-07-29T21:10:04.668-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn4","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":11}}
{"t":{"$date":"2022-07-29T21:10:04.668-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn5","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":11}}
{"t":{"$date":"2022-07-29T21:10:04.667-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn6","msg":"Slow query","attr":{"type":"command","ns":"admin.$cmd","command":{"ismaster":1,"client":{"driver":{"name":"mongo-java-driver|legacy","version":"3.12.1"},"os":{"type":"Linux","name":"Linux","architecture":"amd64","version":"3.10.0-1160.71.1.el7.x86_64"},"platform":"Java/Red Hat, Inc./1.8.0_332-b09"},"saslSupportedMechs":"graylog.mongo_admin","$db":"admin"},"numYields":0,"reslen":384,"locks":{},"protocol":"op_query","durationMillis":10}}
{"t":{"$date":"2022-07-29T21:10:04.670-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn5","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50154","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.670-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn6","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50156","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn3","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50150","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn9","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50162","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn8","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50160","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn7","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50158","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn2","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50148","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.671-05:00"},"s":"I",  "c":"ACCESS",   "id":20250,   "ctx":"conn4","msg":"Authentication succeeded","attr":{"mechanism":"SCRAM-SHA-256","speculative":false,"principalName":"mongo_admin","authenticationDatabase":"graylog","remote":"127.0.0.1:50152","extraInfo":{}}}
{"t":{"$date":"2022-07-29T21:10:04.681-05:00"},"s":"I",  "c":"COMMAND",  "id":51803,   "ctx":"conn7","msg":"Slow query","attr":{"type":"command","ns":"graylog.roles","command":{"find":"roles","$db":"graylog"},"planSummary":"COLLSCAN","keysExamined":0,"docsExamined":22,"cursorExhausted":true,"numYields":0,"nreturned":22,"reslen":7395,"locks":{"FeatureCompatibilityVersion":{"acquireCount":{"r":1}},"ReplicationStateTransition":{"acquireCount":{"w":1}},"Global":{"acquireCount":{"r":1}},"Database":{"acquireCount":{"r":1}},"Collection":{"acquireCount":{"r":1}},"Mutex":{"acquireCount":{"r":1}}},"storage":{"data":{"bytesRead":7417,"timeReadingMicros":79},"timeWaitingMicros":{"schemaLock":6203}},"protocol":"op_msg","durationMillis":9}}
For testing, I created a new dashboard, No Joy. Unable to find Metadata in MongoDb about dashboards.
Am I just going crazy but how does this functions without any saved settings in Mongo, OR is Graylog saving these settings some other place that I do not know about.
  • Graylog Server 4.3.3 12 cores, 12 GB RAM, 500GB HDD
  • Elasticsearch 7.10
  • MongoDb 4.4.15
  • CentOS 7 (latest)
I must be tired, I just found it under “VIEWS” :laughing:
mongo > db.views.find().pretty();
"_id" : ObjectId("62e36711ce8c7a2e9c0c4611"),
        "type" : "DASHBOARD",
        "title" : "Sources",
        "summary" : "Sources",
        "description" : "Sources",
        "search_id" : "62e1f883f74e2d1cce726e85",
        "properties" : [ ],
        "requires" : {
        "state" : {
                "a1647eb6-a064-4fe6-b459-1e4267d3f659" : {
                        "titles" : {
                                "tab" : {
                                        "title" : "Sources Overview"
                                "widget" : {
                                        "4a02a354-84b8-4b5b-a7c7-ceb8c5976a3a" : "Messages for source:graylog.domain.com",
                                        "6c127c5d-be75-4157-b43f-ac0194ac0586" : "Selected sources",
                                        "98b9b950-9fb9-42ae-9d48-21e67b828496" : "Selected sources (copy)",
                                        "212ea3e2-4484-4df2-8abd-266b9e660799" : "Messages for source:graylog.domain.com",
                                        "4fa48004-28f5-41de-b6c0-f4d4651013ad" : "Field Statistics for EventID",
                                        "00637e63-d728-4b3e-932b-7c8696b4855d" : "Messages over time",
                                        "8f9dc4b3-5ccf-429b-93b1-58d062f9607c" : "Messages for source:graylog.domain.com",
                                        "9c8c9d14-5c29-4a17-a958-d9ac80eff0a2" : "Number of Sources",
                                        "3f125c6c-adda-4945-ae70-284620351b13" : "Messages for source:graylog.domain.com",
                                        "55296df7-5c21-41a3-ab78-dd684219b74e" : "Messages for source:graylog.domain.com",
                                        "81011bcc-93e2-412c-84e8-759c791b76a9" : "Messages for source:graylog.domain.com",
                                        "85eba10b-8922-48cb-9e82-7bc963540035" : "Message Count 1 Day",
                                        "7d11ff08-2ed6-471e-b606-254a1ea382db" : "Messages for source:graylog.domain.com",
                                        "e3664cb9-9c47-46b2-894b-4c3a0587345f" : "Messages for source:graylog.domain.com",
                                        "8aef2d13-da5c-4ac9-b71b-b20762735685" : "Messages for source:graylog.domain.com",
                                        "92d63811-e4dd-47db-bd3b-db03c8a9bd53" : "Messages per Source"
