Hi guys
I have a project with 700 Windows clients and 50 Windows servers
I want to use winlogbeat with Sidecar,
does anyone have an idea?
Is there a better way to run it?
Thank you very much for your help
Hi guys
use the configuration management that you have available to configure winlogbeat?
hi John
Thanks for answering the question
I don’t know exactly what you mean …!
The number of clients is very high
I need a roadmap
In our company…
We use graylog sidecar, with pre config with servername, etc. preset, and with silent config.
You can hand it out with GPO, SCCM, etc
After that, you can set the computer’s config on the Graylog 's webpage.
So no client handwork needed.
One GPO/SCCM config, one graylog config, and a manual bingibg on the graylog’s WUI.
I have good experience with WAPT for client configuration management (deployment), which is scriptable in python:
https://www.wapt.fr/en/doc/wapt-concept/index.html
hi macko003
Your solution is great
thank you so much
hi shoothub
thanks for your good guide
WAPT server is similar to Puppet & Anisible
