Unique sidecar multiple beats
Hi folks,
Scenario: 1 network of linux and windows servers.
It’s possibile to use a single sidecar (probably installed on a dedicated vm) and deploy (for example) the same winlogbeat configuration on multiple machines (where winlogbeat is obviously installed).
It’s possible to do it?
What other solutions are there for not having to install the sidecar on each server?
Thanks.
just use winlogbeat without sidecar and manage it with your own configuration management or manually.
Ok thanks!
other ideas?
