zoulja
(Zoulja)
1
I have Graylog behind NAT and proxy
It listens on 127.0.0.1 and requests are routed to this IP:port from public IP
It’s pretty much the same as described in https://docs.graylog.org/en/4.0/pages/configuration/web_interface.html?highlight=proxy#making-the-web-interface-work-with-load-balancers-proxies
The problem is that inside of index page of Graylog absolute path is used, like
<link rel="shortcut icon" href="http://127.0.0.1:9000/assets/favicon.png">
<script src="http://127.0.0.1:9000/config.js">
<script src="http://127.0.0.1:9000/assets/vendor.594b2a39cb22b445205e.js">
Browser obviously fails to load resources from 127.0.0.1
What’s the reason of using absolute path and how to correct it?
gsmith
(GSmith)
2
Not sure if you seen this post. Looks like it has some information that might help.
Hope that helps
zoulja
(Zoulja)
3
Thank you, unfortunately I don’t have Nginx, it’s just port forwarding
I’ve created Graylog behind a proxy and src parameter · Issue #10632 · Graylog2/graylog2-server · GitHub to try to address this issue
