Graylog and Sophos XG
Graylog configuration with Sophos XG. Not able to view logs in Graylog but Sophos is already communicating with it.
  • OS Information:
  • Package Version:
    5.2
    Syslog UDP
TCPdump in Sophos firewall and confirmed there is traffic going out to Graylog server
How to setup Graylog for Sophos XG.
I already contacted Sophos and confirmed the Syslog settings are correct and TCPdump confirmed there is traffic pushing to graylog.
We have currently a open source graylog, do we need an enterprise license for this one to work?
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on any, link-type LINUX_SLL (Linux cooked v1), capture size 262144 bytes
11:57:01.640561 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.notice, length: 406
11:57:11.632641 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1039
11:57:19.740425 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 997
11:59:18.165663 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 994
11:59:33.816713 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1039
12:00:49.422381 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 998
12:01:21.824721 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1035
12:02:55.576706 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1040
12:05:03.769621 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 993
12:07:09.536762 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1034
12:09:05.083914 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.notice, length: 405
^C
11 packets captured
12 packets received by filter
0 packets dropped by kernel
SFV1C4_VM01_SFOS 20.0.0 GA-Build222# tcpdump -nni any host 103.243.110.203
12:10:05.206963 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.notice, length: 406
12:10:22.891366 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.notice, length: 405
12:15:20.197181 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 998
12:17:33.640967 PortB, OUT: IP 203.31.65.156.33110 > 103.243.110.203.514: SYSLOG daemon.info, length: 1040
Are you sure your syslog input is running correctly, some machines dont like assigning ports less than 1024, so you can always try and move it like 1514.
Second are you sure your tcp or udp match on sending and input, these vendors like to not say clearly which protocol they are using for their syslog, and of course if they dont match then nothing is going to work.
I just changed it to 1514 but still no inputs received.
Below are the inputs configured in the graylog. No messages received
Is that tcp dump from the sophos side or from the server running graylog, my first guess is its a connection or firewall issue if that dump is from thr sophos side only.
