What configuration should be done on sophos and graylog to get logs from sophos
Hi @adiya_v
You could setup a syslog receiver on graylog and in graylog you can setup syslog to send messages to your graylog server.
Kind Greetings,
Arie
I did’t get this, can’t we create a syslog tcp input in graylog?
for sophos what should be the input?
You can try syslog UDP and see if that works for your needs
then what should be the configuration in sophos?
check their documentation
sophos send udp or tcp traffic?
