Graylog and LDAP: NullPointerException
After upgrading to Graylog 3.0 everyone is able to authenticate and use the platform fine, but my server logs have a lot of NullPointerExceptions in them related to LDAP. I’m not entirely sure where to start debugging this one since everything seems to work except - there’s a lot of log noise. When I test the connection on the LDAP settings page, it works fine and picks up all my groups as well.
I’m using OpenLDAP 2.4.47. Our user object type is inetOrgPerson (all accounts are also posixAccount and shadowAccount - we search by inetOrgPerson since those are human users), and the groups have objectClass posixGroup which have memberUid as attributes.
Setting Value
User BaseDN ou=users,dc=blah
User Search Pattern (&(objectClass=inetOrgPerson)(uid={0}))
Display Name Attribute uid
Group BaseDN ou=groups,dc=blah
Group Search Pattern (&(objectClass=posixGroup)(cn=gl-*))
Group Name Attribute cn
Stack trace follows:
2019-05-29T18:47:40.231Z WARN  [LdapNetworkConnection] null
java.lang.NullPointerException: null
	at org.apache.directory.ldap.client.api.LdapNetworkConnection.messageReceived(LdapNetworkConnection.java:2040) ~[graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain$TailFilter.messageReceived(DefaultIoFilterChain.java:997) ~[graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain.callNextMessageReceived(DefaultIoFilterChain.java:641) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain.access$1300(DefaultIoFilterChain.java:48) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain$EntryImpl$1.messageReceived(DefaultIoFilterChain.java:1114) [graylog.jar:?]
	at org.apache.mina.filter.codec.ProtocolCodecFilter.messageReceived(ProtocolCodecFilter.java:236) [graylog.jar:?]
	at org.apache.mina.filter.ssl.SslHandler.flushScheduledEvents(SslHandler.java:326) [graylog.jar:?]
	at org.apache.mina.filter.ssl.SslFilter.filterClose(SslFilter.java:712) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain.callPreviousFilterClose(DefaultIoFilterChain.java:767) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain.access$1600(DefaultIoFilterChain.java:48) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain$EntryImpl$1.filterClose(DefaultIoFilterChain.java:1141) [graylog.jar:?]
	at org.apache.mina.core.filterchain.IoFilterAdapter.filterClose(IoFilterAdapter.java:145) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain$TailFilter.filterClose(DefaultIoFilterChain.java:1025) [graylog.jar:?]
	at org.apache.mina.core.filterchain.DefaultIoFilterChain.fireFilterClose(DefaultIoFilterChain.java:760) [graylog.jar:?]
	at org.apache.mina.core.session.AbstractIoSession.closeNow(AbstractIoSession.java:353) [graylog.jar:?]
	at org.apache.directory.ldap.client.api.LdapNetworkConnection.close(LdapNetworkConnection.java:883) [graylog.jar:?]
	at org.graylog2.security.realm.LdapUserAuthenticator.$closeResource(LdapUserAuthenticator.java:133) [graylog.jar:?]
	at org.graylog2.security.realm.LdapUserAuthenticator.doGetAuthenticationInfo(LdapUserAuthenticator.java:133) [graylog.jar:?]
	at org.apache.shiro.realm.AuthenticatingRealm.getAuthenticationInfo(AuthenticatingRealm.java:571) [graylog.jar:?]
	at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doMultiRealmAuthentication(ModularRealmAuthenticator.java:219) [graylog.jar:?]
	at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doAuthenticate(ModularRealmAuthenticator.java:269) [graylog.jar:?]
	at org.apache.shiro.authc.AbstractAuthenticator.authenticate(AbstractAuthenticator.java:198) [graylog.jar:?]
	at org.apache.shiro.mgt.AuthenticatingSecurityManager.authenticate(AuthenticatingSecurityManager.java:106) [graylog.jar:?]
	at org.apache.shiro.mgt.DefaultSecurityManager.login(DefaultSecurityManager.java:274) [graylog.jar:?]
	at org.apache.shiro.subject.support.DelegatingSubject.login(DelegatingSubject.java:260) [graylog.jar:?]
	at org.graylog2.shared.security.ShiroSecurityContext.loginSubject(ShiroSecurityContext.java:107) [graylog.jar:?]
	at org.graylog2.shared.security.ShiroAuthenticationFilter.filter(ShiroAuthenticationFilter.java:48) [graylog.jar:?]
	at org.glassfish.jersey.server.ContainerFilteringStage.apply(ContainerFilteringStage.java:132) [graylog.jar:?]
	at org.glassfish.jersey.server.ContainerFilteringStage.apply(ContainerFilteringStage.java:68) [graylog.jar:?]
	at org.glassfish.jersey.process.internal.Stages.process(Stages.java:197) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:318) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
	at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
	at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
	at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
	at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
	at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
	at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
	at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
	at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1142) [?:1.8.0_102]
	at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:617) [?:1.8.0_102]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_102]
Forgot to mention - this is on Graylog 3.0.0 - I should give it an upgrade, but wasnt sure if folks who have more knowledge could identify something in that stacktrace that may be an issue.
did you have an admin account in your LDAP? Try set the root_username to something like graylog-admin (that is not used in your ldap)…
at least that would be the first I try.
Hey, thanks for taking a look @jan!
I bumped Graylog to 3.0.2 and changed the admin username. I dont have any users named admin (at least, not in those search bases I listed) but I changed the username to gladmin anyways.
This stack trace looks similar, pasting it here in case i’m missing something:
2019-06-03T15:29:21.976Z WARN  [LdapNetworkConnection] null
