Graylog Alerting Question
Hello community !
I want to know if it is possible to create an alert and apply it to a time slot
Exemple: have an unsuccessful ssh connection between 00:00 and 06:00
Does anybody know if this is possible ?
Thanks for your feedback
you would work with the processing pipelines to get this work.
the when condition would check on the time of the day and then you write a field alert and in the actuall alert you just check on the existance of the field.
Hello community !
Thank you for your answer
Would it be possible to have a syntax to use for tchecking on the time
For exemple : tchecking between 00:00 and 06:00 every day
