Graylog AESTools
get issues on ldap … running 3.3.11
java version
openjdk version “1.8.0_282”
OpenJDK Runtime Environment (build 1.8.0_282-b08)
OpenJDK 64-Bit Server VM (build 25.282-b08, mixed mode)
also imported the ldap servers cert to keytool
2021-03-29 07:00:02,552 ERROR: org.graylog2.security.AESTools - Could not decrypt value.
javax.crypto.BadPaddingException: Given final block not properly padded. Such issues can arise if a bad key is used during decryption.
at com.sun.crypto.provider.CipherCore.unpad(CipherCore.java:975) ~[sunjce_provider.jar:1.8.0_282]
at com.sun.crypto.provider.CipherCore.fillOutputBuffer(CipherCore.java:1056) ~[sunjce_provider.jar:1.8.0_282]
at com.sun.crypto.provider.CipherCore.doFinal(CipherCore.java:853) ~[sunjce_provider.jar:1.8.0_282]
at com.sun.crypto.provider.AESCipher.engineDoFinal(AESCipher.java:446) ~[sunjce_provider.jar:1.8.0_282]
at javax.crypto.Cipher.doFinal(Cipher.java:2168) ~[?:1.8.0_282]
at org.graylog2.security.AESTools.decrypt(AESTools.java:88) [graylog.jar:?]
at org.graylog2.security.ldap.LdapSettingsImpl.getSystemPassword(LdapSettingsImpl.java:135) [graylog.jar:?]
at org.graylog2.security.ldap.LdapSettingsServiceImpl.load(LdapSettingsServiceImpl.java:57) [graylog.jar:?]
at org.graylog2.security.realm.LdapUserAuthenticator.isEnabled(LdapUserAuthenticator.java:162) [graylog.jar:?]
at org.graylog2.security.realm.LdapUserAuthenticator.doGetAuthenticationInfo(LdapUserAuthenticator.java:90) [graylog.jar:?]
at org.apache.shiro.realm.AuthenticatingRealm.getAuthenticationInfo(AuthenticatingRealm.java:571) [graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doMultiRealmAuthentication(ModularRealmAuthenticator.java:225) [graylog.jar:?]
at org.apache.shiro.authc.pam.ModularRealmAuthenticator.doAuthenticate(ModularRealmAuthenticator.java:275) [graylog.jar:?]
at org.apache.shiro.authc.AbstractAuthenticator.authenticate(AbstractAuthenticator.java:198) [graylog.jar:?]
at org.apache.shiro.mgt.AuthenticatingSecurityManager.authenticate(AuthenticatingSecurityManager.java:106) [graylog.jar:?]
at org.apache.shiro.mgt.DefaultSecurityManager.login(DefaultSecurityManager.java:275) [graylog.jar:?]
at org.apache.shiro.subject.support.DelegatingSubject.login(DelegatingSubject.java:260) [graylog.jar:?]
at org.graylog2.shared.security.ShiroSecurityContext.loginSubject(ShiroSecurityContext.java:107) [graylog.jar:?]
at org.graylog2.shared.security.ShiroAuthenticationFilter.filter(ShiroAuthenticationFilter.java:48) [graylog.jar:?]
at org.glassfish.jersey.server.ContainerFilteringStage.apply(ContainerFilteringStage.java:132) [graylog.jar:?]
at org.glassfish.jersey.server.ContainerFilteringStage.apply(ContainerFilteringStage.java:68) [graylog.jar:?]
at org.glassfish.jersey.process.internal.Stages.process(Stages.java:197) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime$2.run(ServerRuntime.java:318) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:271) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors$1.call(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:315) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:297) [graylog.jar:?]
at org.glassfish.jersey.internal.Errors.process(Errors.java:267) [graylog.jar:?]
at org.glassfish.jersey.process.internal.RequestScope.runInScope(RequestScope.java:317) [graylog.jar:?]
at org.glassfish.jersey.server.ServerRuntime.process(ServerRuntime.java:305) [graylog.jar:?]
at org.glassfish.jersey.server.ApplicationHandler.handle(ApplicationHandler.java:1154) [graylog.jar:?]
at org.glassfish.jersey.grizzly2.httpserver.GrizzlyHttpContainer.service(GrizzlyHttpContainer.java:384) [graylog.jar:?]
at org.glassfish.grizzly.http.server.HttpHandler$1.run(HttpHandler.java:224) [graylog.jar:?]
at com.codahale.metrics.InstrumentedExecutorService$InstrumentedRunnable.run(InstrumentedExecutorService.java:181) [graylog.jar:?]
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1149) [?:1.8.0_282]
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:624) [?:1.8.0_282]
at java.lang.Thread.run(Thread.java:748) [?:1.8.0_282]
@dio99
Was this an upgrade to GL 3.3? Seams like it complaining about your key.
I did a quick search maybe this might help.
Hope that helps.
i did remove the ldap_settings in mongo db but still we get the issues after readd the ldap settings in GUI
Can I ask how you removed
I believe you can remove those settings right from the GUI, not sure why you had to go into MongDB to do that.
because if i remeber it right there are mapping with password_secret with the settings for ldapsettings and that can be issues when u change pwd. sot thats why i removed it in mongob
