Graylog 7.0 unable to start
 Hi, All
    I followed the official Graylog installation guide and could access http://admin:IoixcXMvMs@0.0.0.0:9000 normally at first. After clicking "create CA" button, initializing the CA, I can no longer access the web page successfully. From the server.log, it's a certificate-related issue. Any help would be appreciated!
  • OS Information: ubuntu 24.04.3 LTS
  • Package Version:
2025-12-20T08:46:56.041Z INFO  [PreflightJerseyService]
It seems you are starting Graylog for the first time. To set up a fresh install, a setup interface has
been started. You must log in to it to perform the initial configuration and continue.
Initial configuration is accessible at 0.0.0.0:9000, with username 'admin' and password 'IoixcXMvMs'.
Try clicking on http://admin:IoixcXMvMs@0.0.0.0:9000
2025-12-20T08:47:36.201Z INFO  [CustomCAX509TrustManager] CA changed, refreshing trust manager
2025-12-20T08:47:43.159Z INFO  [PreflightJerseyService] Shutting down HTTP listener at <0.0.0.0:9000>
2025-12-20T08:47:43.161Z INFO  [Periodicals] Shutting down periodical [org.graylog2.bootstrap.preflight.GraylogCertificateProvisioningPeriodical].
2025-12-20T08:47:43.162Z INFO  [Periodicals] Shutting down periodical [org.graylog2.events.ClusterEventPeriodical].
2025-12-20T08:47:43.162Z INFO  [Periodicals] Shutting down periodical [org.graylog2.events.ClusterEventCleanupPeriodical].
2025-12-20T08:47:43.175Z INFO  [NetworkListener] Stopped listener bound to [0.0.0.0:9000]
2025-12-20T08:47:43.408Z INFO  [IndexerDiscoveryProvider] Datanode is not available. Retry #1
2025-12-20T08:47:48.440Z INFO  [IndexerDiscoveryProvider] Datanode is not available. Retry #2
2025-12-20T08:47:48.502Z INFO  [CaKeystore] Signing certificate for  node de1f75af-63de-4bd0-a8ba-83777ea11cca, subject: CN=yzlogserver.mshome.net
2025-12-20T08:47:48.544Z ERROR [CertificateExchangeImpl] Failed to sign CSR for node, skipping it for now.
java.lang.RuntimeException: java.security.cert.CertificateParsingException: java.io.IOException: Parse Generalized time, invalid format
	at org.graylog.security.certutil.CaKeystore.signCertificateRequest(CaKeystore.java:76)
	at org.graylog2.bootstrap.preflight.GraylogCertificateProvisionerImpl.lambda$runProvisioning$0(GraylogCertificateProvisionerImpl.java:61)
	at org.graylog2.cluster.certificates.CertificateExchangeImpl.signPendingCertificateRequests(CertificateExchangeImpl.java:102)
	at org.graylog2.bootstrap.preflight.GraylogCertificateProvisionerImpl.runProvisioning(GraylogCertificateProvisionerImpl.java:61)
	at org.graylog2.configuration.IndexerDiscoveryCertProvisioning.onDiscoveryRetry(IndexerDiscoveryCertProvisioning.java:39)
	at java.base/java.lang.Iterable.forEach(Unknown Source)
	at org.graylog2.configuration.IndexerDiscoveryProvider$1.onRetry(IndexerDiscoveryProvider.java:117)
	at com.github.rholder.retry.Retryer.call(Retryer.java:167)
	at org.graylog2.configuration.IndexerDiscoveryProvider.doGet(IndexerDiscoveryProvider.java:122)
	at com.google.common.base.Suppliers$NonSerializableMemoizingSupplier.get(Suppliers.java:201)
	at org.graylog2.configuration.IndexerDiscoveryProvider.get(IndexerDiscoveryProvider.java:86)
	at org.graylog2.configuration.IndexerDiscoveryProvider.get(IndexerDiscoveryProvider.java:48)
	at com.google.inject.internal.ProviderInternalFactory.provision(ProviderInternalFactory.java:86)
	at com.google.inject.internal.BoundProviderFactory.provision(BoundProviderFactory.java:72)
	at com.google.inject.internal.ProviderInternalFactory.circularGet(ProviderInternalFactory.java:60)
	at com.google.inject.internal.BoundProviderFactory.get(BoundProviderFactory.java:59)
	at com.google.inject.internal.ProviderToInternalFactoryAdapter.get(ProviderToInternalFactoryAdapter.java:40)
	at com.google.inject.internal.SingletonScope$1.get(SingletonScope.java:169)
	at com.google.inject.internal.InternalFactoryToProviderAdapter.get(InternalFactoryToProviderAdapter.java:45)
	at com.google.inject.internal.InternalInjectorCreator.loadEagerSingletons(InternalInjectorCreator.java:213)
	at com.google.inject.internal.InternalInjectorCreator.injectDynamically(InternalInjectorCreator.java:186)
	at com.google.inject.internal.InternalInjectorCreator.build(InternalInjectorCreator.java:113)
	at com.google.inject.Guice.createInjector(Guice.java:87)
	at com.google.inject.Guice.createInjector(Guice.java:69)
	at com.google.inject.Guice.createInjector(Guice.java:59)
	at org.graylog2.bootstrap.ServerBootstrap.getPreflightInjector(ServerBootstrap.java:289)
	at org.graylog2.bootstrap.ServerBootstrap.runPreFlightChecks(ServerBootstrap.java:181)
	at org.graylog2.bootstrap.ServerBootstrap.beforeInjectorCreation(ServerBootstrap.java:151)
	at org.graylog2.bootstrap.CmdLineTool.doRun(CmdLineTool.java:362)
	at org.graylog2.bootstrap.CmdLineTool.run(CmdLineTool.java:287)
	at org.graylog2.bootstrap.Main.main(Main.java:57)
Caused by: java.security.cert.CertificateParsingException: java.io.IOException: Parse Generalized time, invalid format
	at java.base/sun.security.x509.X509CertInfo.<init>(Unknown Source)
	at java.base/sun.security.x509.X509CertImpl.parse(Unknown Source)
	at java.base/sun.security.x509.X509CertImpl.<init>(Unknown Source)
	at java.base/sun.security.provider.X509Factory.cachedGetX509Cert(Unknown Source)
	at java.base/sun.security.provider.X509Factory.engineGenerateCertificate(Unknown Source)
	at java.base/java.security.cert.CertificateFactory.generateCertificate(Unknown Source)
	at org.bouncycastle.cert.jcajce.JcaX509CertificateConverter.getCertificate(Unknown Source)
	at org.graylog.security.certutil.csr.CsrSigner.sign(CsrSigner.java:133)
	at org.graylog.security.certutil.csr.CsrSigner.sign(CsrSigner.java:93)
	at org.graylog.security.certutil.CaKeystore.signCertificateRequest(CaKeystore.java:72)
	... 30 more
Caused by: java.io.IOException: Parse Generalized time, invalid format
	at java.base/sun.security.util.DerValue.getTimeInternal(Unknown Source)
	at java.base/sun.security.util.DerValue.getGeneralizedTime(Unknown Source)
	at java.base/sun.security.util.DerInputStream.getGeneralizedTime(Unknown Source)
	at java.base/sun.security.x509.CertificateValidity.<init>(Unknown Source)
	at java.base/sun.security.x509.X509CertInfo.parse(Unknown Source)
	... 40 more
2025-12-20T08:47:53.551Z INFO  [IndexerDiscoveryProvider] Datanode is not available. Retry #3
2025-12-20T08:47:53.603Z INFO  [CaKeystore] Signing certificate for  node de1f75af-63de-4bd0-a8ba-83777ea11cca, subject: CN=yzlogserver.mshome.net
2025-12-20T08:47:53.639Z ERROR [CertificateExchangeImpl] Failed to sign CSR for node, skipping it for now.
	... 30 more
