Graylog 6 using opensearch needs elasticsearch for authentication?
New instal of Graylog 6 on Ubuntu 22.
Followed this guide: Ubuntu Installation
Except step 5 of the ‘edit the graylog config file’ section:
‘5. Edit the elasticsearch_hosts setting to include a list of comma-separated URIs to one or more valid OpenSearch nodes.’
Just like the warning says, i cant use my root password.
do i simply install elasticsearch and run the command? do i need to configure elasticsearch first?
  • OS Information:
    ubuntu 22
  • Package Version:
    graylog 6
verified graylog, mongod and opensearch services are running
confirm i need elasticsearch and where i can find correct configuration
Hey @cdauray
By default graylog will connect using localhost. if you are creating a OpenSearch cluster you can add user/password that has roles to connect to OpenSearch. This depends on how you set up your cluster.
For example without a user/password
elasticsearch_hosts = http://localhost:9200,http://172.168.1.100:9200,http://172.168.1.200:9200
once configured restart Graylog service, you should have OpenSearch install and reachable
