Graylog 3, Sidecar (1.0.1) WinLogEvt - No messages
Hi guys:
Having an issue with Graylog 3.0.1 and a Windows Server 2012 running Sidecar 1.0.1.
Sidecar registered and FileBeat config gets pushed out with no issues:
Content of winlogbeat.yml (generated folder) in Win Server:
Needed for Graylog
fields_under_root: true
fields.collector_node_id: anms-dc01
fields.gl2_source_collector: 5a51f09b-69d5-4f15-8f26-280ce46f6d67
output.logstash:
hosts: [“192.168.1.150:5045”]
path:
tags:
  • windows
    winlogbeat:
    event_logs:
    • name: Application
    • name: System
    • name: Security
Input also configured in Graylog server:
However, I see no messages, either via Systems - Sidecars - Show messages or directly from Input.
TCPDump run on Graylogserver and on WinServer show traffic on TCP 9000 but no conns at all on port 5055.
I’d been using “old” sidecar collectors and Graylog 2.x for a while with no issues but I don’t seem to get this one working.
Any ideas?
Thanks!
Also, the Backend Log File throws following entries:
2019-05-02T22:42:50.792-0700 ERROR pipeline/output.go:100 Failed to connect to backoff(async(tcp://192.168.1.150:5045)): dial tcp 192.168.1.150:5045: connectex: A connection attempt failed because the connected party did not properly respond after a period of time, or established connection failed because connected host has failed to respond.
2019-05-02T22:42:50.792-0700 INFO pipeline/output.go:93 Attempting to reconnect to backoff(async(tcp://192.168.1.150:5045)) with 8 reconnect attempt(s)
No local FW running on Graylog Server. A telnet from WinServer to Graylog on port 5045 works.
In screenshots Graylog server address is 192.168.252.150, in winlogbeat configuration it is 192.168.1.150
:slight_smile:
Thanks Karlis, I guess I need a new pair of glasses.
Cheers
Juan.
