Server 1 server.conf
# If you are running more than one instances of Graylog server you have to select one of these
# instances as master. The master will perform some periodical tasks that non-masters won't perform.
is_master = true
# The auto-generated node ID will be stored in this file and read after restarts. It is a good idea
# to use an absolute file path here if you are starting Graylog server from init scripts or similar.
# You MUST set a secret to secure/pepper the stored user passwords here. Use at least 64 characters.
# Generate one by using for example: pwgen -N 1 -s 96
password_secret = XXXXXXXXXXXXXXXXXXXXXXXXXX
#root_username = admin
# You MUST specify a hash password for the root user (which you only need to initially set up the
# system and in case you lose connectivity to your authentication backend)
# This password cannot be changed using the API or via the web interface. If you need to change it,
# modify it in this file.
# Create one by using for example: echo -n yourpassword | shasum -a 256
# and put the resulting hash value into the following line
root_password_sha2 = XXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
# Default is empty
#root_email = ""
# Default is UTC
#root_timezone = UTC
root_timezone = America/New_York
plugin_dir = plugin
# REST API listen URI. Must be reachable by other Graylog server nodes if you run a cluster.
# When using Graylog Collectors, this URI will be used to receive heartbeat messages and must be accessible for all collectors.
#rest_listen_uri = http://172.16.55.39:12900/
#rest_listen_uri = http://172.16.55.39:9000/api/
##rest_listen_uri = http://127.0.0.1:9000/api/
#http_bind_address = 127.0.0.1:9000
http_bind_address = 172.16.55.39:9000
# REST API transport address. Defaults to the value of rest_listen_uri. Exception: If rest_listen_uri
# is set to a wildcard IP address (0.0.0.0) the first non-loopback IPv4 system address is used.
# If set, this will be promoted in the cluster discovery APIs, so other nodes may try to connect on
# this address and it is used to generate URLs addressing entities in the REST API. (see rest_listen_uri)
# You will need to define this, if your Graylog server is running behind a HTTP proxy that is rewriting
# the scheme, host name or URI.
# This must not contain a wildcard address (0.0.0.0).
#rest_transport_uri = http://192.168.1.1:12900/
#http_publish_uri = http://192.168.1.1:12900/
# Enable CORS headers for REST API. This is necessary for JS-clients accessing the server directly.
# If these are disabled, modern browsers will not be able to retrieve resources from the server.
# This is enabled by default. Uncomment the next line to disable it.
#rest_enable_cors = false
#http_enable_cors = false
# Enable GZIP support for REST API. This compresses API responses and therefore helps to reduce
# overall round trip times. This is disabled by default. Uncomment the next line to enable it.
#rest_enable_gzip = true
#http_enable_gzip = true
# Enable HTTPS support for the REST API. This secures the communication with the REST API with
# TLS to prevent request forgery and eavesdropping. This is disabled by default. Uncomment the
# next line to enable it.
#rest_enable_tls = true
#http_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the REST API.
#rest_tls_cert_file = /path/to/graylog.crt
# The PKCS#8 private key file in PEM format to use for securing the REST API.
#rest_tls_key_file = /path/to/graylog.key
# The password to unlock the private key used for securing the REST API.
#rest_tls_key_password = secret
#rest_max_header_size = 8192
#http_max_header_size = 8192
# The maximal length of the initial HTTP/1.1 line in bytes.
#rest_max_initial_line_length = 4096
#http_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the REST API.
#rest_thread_pool_size = 16
#http_thread_pool_size = 16
# Enable the embedded Graylog web interface.
# Default: true
#web_enable = false
# Web interface listen URI. It must not contain a path other than "/".
#web_listen_uri = http://127.0.0.1:9000/
#web_listen_uri = http://172.16.55.39:9000/
# Web interface endpoint URI. This setting can be overriden on a per-request basis with the X-Graylog-Server-URL header.
# Default: $rest_transport_uri
#web_endpoint_uri =
#http_external_uri =
# Enable CORS headers for the web interface. This is necessary for JS-clients accessing the server directly.
#web_enable_cors = false
# Enable/disable GZIP support for the web interface. This compresses HTTP responses and therefore helps to reduce
#web_enable_gzip = false
#http_enable_gzip = false
# Enable HTTPS support for the web interface. This secures the communication of the web browser with the web interface
# using TLS to prevent request forgery and eavesdropping.
# This is disabled by default. Uncomment the next line to enable it and see the other related configuration settings.
#web_enable_tls = true
# The X.509 certificate chain file in PEM format to use for securing the web interface.
#web_tls_cert_file = /path/to/graylog-web.crt
#http_tls_cert_file = /path/to/graylog-web.crt
# The PKCS#8 private key file in PEM format to use for securing the web interface.
#web_tls_key_file = /path/to/graylog-web.key
#http_tls_key_file = /path/to/graylog-web.key
# The password to unlock the private key used for securing the web interface.
#web_tls_key_password = secret
#web_max_header_size = 8192
#web_max_initial_line_length = 4096
# The size of the thread pool used exclusively for serving the web interface.
#web_thread_pool_size = 16
# Configuration file for the embedded Elasticsearch instance in Graylog.
# Pay attention to the working directory of the server, maybe use an absolute path here.
# Default: empty
#elasticsearch_config_file = /etc/graylog/server/elasticsearch.yml
# Graylog will use multiple indices to store documents in. You can configured the strategy it uses to determine
# when to rotate the currently active write index.
# It supports multiple rotation strategies:
# - "count" of messages per index, use elasticsearch_max_docs_per_index below to configure
# - "size" per index, use elasticsearch_max_size_per_index below to configure
# valid values are "count", "size" and "time", default is "count"
# to your previous 1.x settings so they will be migrated to the database!
rotation_strategy = count
# 1w = 1 week
# 1d = 1 day
# 12h = 12 hours
#no_retention = false
elasticsearch_max_number_of_indices = 240
# - delete # Deletes the index completely (Default)
# - close # Closes the index and hides it from the system. Can be re-opened later.
retention_strategy = delete
elasticsearch_shards = 1
elasticsearch_replicas = 0
# # Default: graylog-internal
# be enabled with care. See also: https://www.graylog.org/documentation/general/queries/
allow_highlighting = false
# settings to be passed to elasticsearch's client (overriding those in the provided elasticsearch_config_file)
# all these
# this must be the same as for your Elasticsearch cluster
#elasticsearch_cluster_name = graylog
# The prefix being used to generate the Elasticsearch node name which makes it easier to identify the specific Graylog
# server running the embedded Elasticsearch instance. The node name will be constructed by concatenating this prefix
# and the Graylog node ID (see node_id_file), for example "graylog-17052010-1234-5678-abcd-1337cafebabe".
# Default: graylog-
#elasticsearch_node_name_prefix = graylog-
# A comma-separated list of Elasticsearch nodes which Graylog is using to connect to the Elasticsearch cluster,
# see https://www.elastic.co/guide/en/elasticsearch/reference/2.3/modules-discovery-zen.html for details.
# Default: 127.0.0.1
#elasticsearch_discovery_zen_ping_unicast_hosts = 127.0.0.1:9300, 127.0.0.2:9500
#elasticsearch_discovery_zen_ping_unicast_hosts = 172.16.55.43:9300, 127.0.0.2:9500
elasticsearch_hosts = http://172.16.55.42:9200, http://172.16.55.45:9000
# we don't want the Graylog server to store any data, or be master node
#elasticsearch_node_master = false
#elasticsearch_node_data = false
# use a different port if you run multiple Elasticsearch nodes on one machine
#elasticsearch_transport_tcp_port = 9350
# we don't need to run the embedded HTTP server here
#elasticsearch_http_enabled = false
# Enable Elasticsearch multicast discovery. This requires the installation of an Elasticsearch plugin,
# see https://www.elastic.co/guide/en/elasticsearch/plugins/2.3/discovery-multicast.html for details.
# Default: false
#elasticsearch_discovery_zen_ping_multicast_enabled = false
# Change the following setting if you are running into problems with timeouts during Elasticsearch cluster discovery.
# The setting is specified in milliseconds, the default is 5000ms (5 seconds).
#elasticsearch_cluster_discovery_timeout = 5000
# the following settings allow to change the bind addresses for the Elasticsearch client in Graylog
# these settings are empty by default, letting Elasticsearch choose automatically,
# override them here or in the 'elasticsearch_config_file' if you need to bind to a special address
# refer to http://www.elasticsearch.org/guide/en/elasticsearch/reference/0.90/modules-network.html
# for special values here
#elasticsearch_network_host = 172.16.55.39
#elasticsearch_network_bind_host =
#elasticsearch_network_publish_host =
# The total amount of time discovery will look for other Elasticsearch nodes in the cluster
# before giving up and declaring the current node master.
#elasticsearch_discovery_initial_state_timeout = 3s
# Elasticsearch documentation: http://www.elasticsearch.org/guide/reference/index-modules/analysis/
# Global request timeout for Elasticsearch requests (e. g. during search, index creation, or index time-range
# calculations) based on a best-effort to restrict the runtime of Elasticsearch operations.
# Default: 1m
#elasticsearch_request_timeout = 1m
# Default: 1h
output_batch_size = 500
output_flush_interval = 1
#processbuffer_processors = 5
processbuffer_processors = 15
#outputbuffer_processors = 3
outputbuffer_processors = 6
# Possible types:
# - yielding
# Compromise between performance and CPU usage.
# - sleeping
# Compromise between performance and CPU usage. Latency spikes can occur after quiet periods.
# - blocking
# High throughput, low latency, higher CPU usage.
# - busy_spinning
# Avoids syscalls which could introduce latency jitter. Best when threads can be bound to specific CPU cores.
ring_size = 65536
inputbuffer_ring_size = 65536
inputbuffer_processors = 2
# Enable the disk based message journal.
# The directory which will be used to store the message journal. The directory must me exclusively used by Graylog and
message_journal_dir = data/journal
message_journal_max_size = 4gb
# Length of the interval in seconds in which the alert conditions for all streams should be checked
# and alarms are being sent.
#alert_check_interval = 60
# messages end up.
#stale_master_timeout = 2000
#shutdown_timeout = 30000
# MongoDB connection string
# See http://docs.mongodb.org/manual/reference/connection-string/ for details
#mongodb_uri = mongodb://localhost/graylog
mongodb_uri = mongodb://172.16.55.39/graylog
#mongodb_uri = mongodb://grayloguser:secret@localhost:27017,localhost:27018,localhost:27019/graylog
# http://api.mongodb.org/java/current/com/mongodb/MongoOptions.html#threadsAllowedToBlockForConnectionMultiplier
# Drools Rule File (Use to rewrite incoming log messages)
# See: https://www.graylog.org/documentation/general/rewriting/
rules_file = /etc/graylog/server/rules.drl
# Email transport
#transport_email_hostname = graylog.laurens55.org
transport_email_hostname = localhost
#transport_email_port = 587
transport_email_use_tls = false
transport_email_from_email = root@graylog.laurens55.org
#transport_email_web_interface_url = http://172.16.55.39:9000
#transport_email_web_interface_url = https://172.16.55.39
transport_email_web_interface_url = https://graylog.laurens55.org
# Default: 5s
#http_connect_timeout = 5s
# Default: 10s
#http_read_timeout = 10s
# Default: 10s
#http_write_timeout = 10s
#http_proxy_uri =
# Disable the optimization of Elasticsearch indices after index cycling. This may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is to optimize
# cycled indices.
#disable_index_optimization = true
# Optimize the index down to <= index_optimization_max_num_segments. A higher number may take some load from Elasticsearch
# on heavily used systems with large indices, but it will decrease search performance. The default is 1.
#index_optimization_max_num_segments = 1
# The threshold of the garbage collection runs. If GC runs take longer than this threshold, a system notification
# will be generated to warn the administrator about possible problems with the system. Default is 1 second.
#gc_warning_threshold = 1s
# Connection timeout for a configured LDAP server (e. g. ActiveDirectory) in milliseconds.
# Enable collection of Graylog-related metrics into MongoDB
# WARNING: This will add *a lot* of data into your MongoDB database on a regular interval (1 second)!
# DEPRECATED: This setting and the respective feature will be removed in a future version of Graylog.
#enable_metrics_collection = false
# Disable the use of SIGAR for collecting system stats
#disable_sigar = false
# The default cache time for dashboard widgets. (Default: 10 seconds, minimum: 1 second)
# Automatically load content packs in "content_packs_dir" on the first start of Graylog.
#content_packs_loader_enabled = true
# The directory which contains content packs which should be loaded on the first start of Graylog.
#content_packs_dir = data/contentpacks
# A comma-separated list of content packs (files in "content_packs_dir") which should be applied on
# the first start of Graylog.
# Default: empty
