Graylog 3.2.4 migration
I am running graylog 3.2.4 in EKS with a Elasticsearch cluster in AWS, and I need to move the graylog to a new EKS cluster.
Is there a way to migrate user config/data from old EKS to new EKS? I assume this will be similar to migration config/data from old server to new server?
Thanks,
Wei
I am going to answer my own question. Below worked out for me:
  • mongodb dump on older deployment, do below from mongodb pod console
    mkdir /var/tmp/backup
    mongodump --db graylog --out /var/tmp/backup/
    tar czvf /var/tmp/graylog_backup.tgz /var/tmp/backup/graylog
  • copy backup to local
kubectl cp graylog/graylog-mongodb-replicaset- 0 :/var/tmp/graylog_backup.tgz ./graylog_backup.tgz
  • copy backup to new mongodb pod deployment
    kubectl cp ~/graylog_backup.tgz graylog/graylog-mongodb-replicaset- 0 :/var/tmp/graylog_backup.tgz
  • restore
cd /var/tmp
tar xzvf graylog_backup.tgz
mongorestore -d graylog --drop ./graylog
