With the older version, when we search logs, we could customize the graphical representation.
In 2.4 version, how to do this ?
What exactly do you mean?
Hi
I can create a counter, histogram but I can’t create others (example in image)
It’s resolved.
Thanks all
So, what was the problem?
My guess would be a non-numeric type of the message field you were trying to create a graph for…
Hi @jochen
It’s a graphical bug with the left frame that not have chart proposal with field logs.
If you think you’ve found a bug, please open a bug report at https://github.com/Graylog2/graylog2-server/issues/
