GL2 Source Info
I’m currently dealing with a number of input sources; Each input has a unique string (gl2_source_input).
Is it possible to give it a more friendly name?
Yes, you can either use a Copy Input extractor or a pipeline rule to copy/rename the gl2_source_input field.
http://docs.graylog.org/en/2.4/pages/pipelines/functions.html#rename-field
http://docs.graylog.org/en/2.4/pages/extractors.html
